Jul 20, 2005, 11:25 AM
Memphis, IN, USA
Joined Jan 2001
Got a chance to fly the f-14 last night.. All I can say is WOW. It does axial rolls pretty nicely, as well as fairly tight (inside) loops. Very fun to take it vertical and pull off a couple of rolls as its ascending. Almost crashed it flying inverted and got it into a tip stall, I let go of the sticks and then recovered it about 10 feet off the deck (boy that got my heart pounding). Maybe I was premature on my statement about the best way being the motor mid-ship. I do think the tailerons are a pain in the behind to get right though (I did not get them exactly right on this ship, but fairly close).
I'll post the spec sheet later tonight. I built this plane from plans I created using MS Visio. It will let me save it as a CAD file, so I'll try that and see if it is usable before posting the CAD, and then maybe someone can take that and convert to PDF. I'll also take some more pics of the setup. Maybe someone can improve upon the overall design and the tailerons!
Ok, spec sheet added. Flew it again tonight, really like this bird!
Model: FFF F-14 built from my own plans
Motor: GWS EPS350c-bs
ESC: CC pixie 20
Battery: Lipo, Polyquest 2s1p 1500
Reduction method / ratio: b gearing
Prop: GWS 9047
Amps: approx. 8.5 (not measured directly, got from GWS table)
Watts: 61.2 (from GWS table)
RPM: n/a
Thrust: approx 13.02 oz (from GWS table)
# Servos / type: (1) align 6 gram micro, (1) gws pico standard (its all I had on hand)
Control surfaces: tailerons, elevon enabled on radio
Basic airframe weight: n/a
Glue method: hot glue
All up weight (AUW): 11.6 oz (with nose repair, and 7 pennies on nose = .7oz)
C/G (measure from tip of nose): 20" from tip of nose
Typical flight duration: 10 minutes w/ some throttle management.
Comments: Fast jet design, capable of vertical flight and fairly tight loops. Will complete axial rolls with minimal loss of altitude. Due to differences in servos and tailerons, will roll to right very tightly, left rolls are a little dirty. Taileron position is critical as is amount of throw on both sides (I got neither perfect in this prototype, but it still flies well!). Doesn't like inverted flight much, but that may just be my piloting skills! Very fun, basic airframe easy to build, but taileron setup a total pain. Fairly inexpensive.
