Old Jun 28, 2005, 11:37 PM
SargeNZ is offline
Find More Posts by SargeNZ
Dizzying Heights
SargeNZ's Avatar
New Zealand, Southland, Invercargill
Joined Feb 2003
Blade XL Build thread.
Look at what just arrived in the mail!
She's a big'un!
Also shown are the Hyperion Z3025/10 and 4S Tanic 2450mah (in 2 packs of 2)
More to come.
SargeNZ is offline Find More Posts by SargeNZ
Old Jun 28, 2005, 11:44 PM
Zimbo is offline
Find More Posts by Zimbo
Papa Alpha Uniform Lima
Zimbo's Avatar
Ashburton, New Zealand
Joined Jul 2004
Nice one marcus, I better organise another indoor so I can see it!
Paul
Zimbo is offline Find More Posts by Zimbo
Old Jun 29, 2005, 12:22 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
Tail feathers hinged and on fuselage.
I elected to use Du-bro pinned mini hinges on the rudder as they were more free than the sheet plastic MPJet ones supplied with the kit.
Old Jun 29, 2005, 12:23 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
Paul. Another indoor meeting would be great. Just make sure its bigger than the basketball court supplied last time lol.
Old Jun 29, 2005, 12:41 AM
NZBandit is offline
Find More Posts by NZBandit
NZBandit's Avatar
Auckland, New Zealand
Joined May 2003
Good Job Marcus
Here are some photos of some flying in NZ.
NZBandit is offline Find More Posts by NZBandit
Old Jun 29, 2005, 01:18 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
Hey Matt, What are you guys using to hold down your canopies so that they are removable? Im thinking velcro tabs.
Old Jun 29, 2005, 01:24 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
Moving onward:
Here we see the fibreglass plate with locates the carbon rod, tabs for securing the wing, and substantial ali tube to keep the wings in check.
Old Jun 29, 2005, 01:35 AM
NZBandit is offline
NZBandit's Avatar
Joined May 2003
Magnets on the outside of the canopy and tin glued to the foam. Works really well.
Old Jun 29, 2005, 02:11 AM
Zimbo is offline
Zimbo's Avatar
Joined Jul 2004
Matt, do you sell these things unpainted?
Marcus, Yeah, lol, I will try but here in AshVegas theres not to many places that are bigger than the gym!
Paul
Old Jun 29, 2005, 02:41 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
The wings locates into pre-cut holes in the fuse, I had to enlarge most of these holes to get a snug fit. On the inside of the fuse is a fibreglass material with the holes cut in it, the same material that is on the wing roots. Looks like G10 to me.
Old Jun 29, 2005, 02:43 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
The firewall is pinned onto protruding pieces of G10 with holes in them, these are the same piece of fibreglass the is inside the fuse between the wings, so the result is very strong, I was skeptical at first but after giving the firewall the pull test I am confident it will stay put.
Old Jun 29, 2005, 02:51 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
I like the landing gear alot, It is stiff enough for the strain of ground running but flexible enough to absorb firm landings of which Im sure there will be a few.
Once again It is as easy as sliding the unit into pre cut slots in the fibreglass inside the fuse. The light 3 Inch wheels are supplied too.
Old Jun 29, 2005, 02:53 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
And here we are. Ready for radio installation in only 3 and a half hours. Not to shabby.
The cap was a freebe from Matt Lord after I bought the Blade XL off of him. Cheers dude!
Old Jun 29, 2005, 02:56 AM
SargeNZ is offline
Dizzying Heights
SargeNZ's Avatar
Joined Feb 2003
Hmmm may have to try the magnet idea, thanks.
Stay tuned for radio installation and test run up tomorrow if all goes to plan.
Old Jun 29, 2005, 03:32 AM
NZBandit is offline
NZBandit's Avatar
Joined May 2003
Things are looking good Marcus. They build really easily don't they!
Here's a couple of things that you should know. The COG as mentioned in the instructions is a bit far forward for 3D. Its a safe place to start but don't be shy in moving it back a bit. Also make sure that you've got plenty of rudder throw as she loves it when you throw the tail around. Also when you drill the hole in the wing joiner to allow the bolt access, don't make it too tight. If you do it tends to pull the leading edge of the wing away from the fuse at the root.
Paul, they don't come unpainted, however they look crap on the ground but really good in the air. We've got a fleet of them flying up here in Auckland and they all look great in their camo colour scheme once they are off the ground.
Blade Dancer EPP Build thread Leif Foamies (Kits) 58 Jul 03, 2015 02:11 PM
Build Log RC-Tek Phantom 450 XL Build Thread Sonex128 Mini Helis 57 Dec 28, 2007 03:39 AM
MS CH46 3 Blade vonversion Build/pic thread meatbomber Coaxial Helicopters 49 Dec 18, 2007 01:47 AM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
