Old Jun 28, 2005, 10:13 AM
Fishmasterdan is offline
Find More Posts by Fishmasterdan
Stanwood WA
Joined Jul 2003
On board glow plug switch?
First of all I want to say I am experimenting with Gasser Motors. Right now I prefer not to run any ignition. I am using a glow plug and methanol/oil?
I can get the motor to run at idle if the glow plug is hot all the time, and at higher rpms I dont need the plug on.
I was hoping there was something available or simple to build where I could switch the plug on and off with my landing gear switch?
Do you think it will work?
Here is a picture of how I have the glow plug attached.
Fishmasterdan is offline Find More Posts by Fishmasterdan
Old Jun 28, 2005, 11:08 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
On a typical methanal fueled engine with glow plug, once started, you do not need the plug connected even at idle. If you feel you must, it is easy to mount a cam on a servo and have the cam turn a pushbutton switch on or off.
Rodney is offline Find More Posts by Rodney
Old Jun 28, 2005, 12:38 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Ther are methods that pass a small current through the plug, and try and control the voltage - it the plug gets cooler, the voltage falls and current is applied to heat it up again.
However its better to pulse it and measure the voltage on a lower current, and use the implied resistance to control a higher current pulse.
Ther are circuots about to do this, and a seasrch in this forum may reveal one.
Old Jun 28, 2005, 12:55 PM
Stanwood WA
Joined Jul 2003
It dies at idle when I remove the glow power.
I will do some more searching.
Old Jun 29, 2005, 06:53 AM
lazy-b is online now
Find More Posts by lazy-b
Manila, Philippines
Joined Jul 2004
Yes, saw an article in RCM magazine, its Automatic Glow Plug Switch, automatically turn on the glow plug when it detect a cold glow plug.....no need to make a separate channel to turn ON/OFF the glow plug switch.
lazy-b is online now Find More Posts by lazy-b
Old Jun 29, 2005, 07:24 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
HI, Ellion
Have a link ???
Two novelties here : the "Gas-Brain" ... The Brain for Gas Engines !!! and "the Magic Box" or how to parallell two servos ( rotation, neutral and 1/2 throws adjustable for the second servo ) ... a differential version is on the bench !!! may be exponential travel further.
Alain
Hi, Fishmasterdan
"The Brain" an electronic Glow Heather, plus fail safe, plus glitch filtering ...
http://aeronews.free.fr/anciensnum/1...ropratique.zip
... The most achieved glow device to the day ...
Acetronics is offline Find More Posts by Acetronics
Old Jun 29, 2005, 07:32 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Vintage
Have one really working well ???
I'd like to see it ... all those I saw to this day are marvellous self oscillating devices ... glow blinkers, if you've better.
Alain
Old Jun 29, 2005, 09:05 AM
FenceMagnet is offline
Find More Posts by FenceMagnet
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
"Yes, saw an article in RCM magazine, its Automatic Glow Plug Switch, automatically turn on the glow plug when it detect a cold glow plug.....no need to make a separate channel to turn ON/OFF the glow plug switch."
was this a tech/build article or product review?
FenceMagnet is offline Find More Posts by FenceMagnet
Old Jun 29, 2005, 09:51 AM
Stanwood WA
Joined Jul 2003
I have been searching but have not found one for sale.
Thanks for the info so far.
Dan
Old Jun 29, 2005, 11:58 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hey, Fishmaster ...
Just have a look to Graupner/JR ...
They sell ( awful word ...) such a device ,based upon the stick position ...
Alain
Old Jun 29, 2005, 02:22 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Maybe this is a stupid idea, but I'll post it anyhow.
Why not just take a brushed ESC and servo reverse it from the throttle servo?
As throttle goes up, the plug power goes down, and as throttle goes down, voltage to the plug goes up.
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Jun 29, 2005, 02:51 PM
Stanwood WA
Joined Jul 2003
hmm that sounds like it might work.
I think to disable the power that is feed to the reciever (from the esc) I will simply cut the black and red. But how to set up 2 throttles? I have an eclipse 7 I wonder if I can mix the gear channel to the throttle channel. Interesting.
Old Jun 30, 2005, 02:47 AM
Manila, Philippines
Joined Jul 2004
Alain, I will the check the RCM issue.....will post it here.
FenceMagnet, its an DIY project with the schematic and PCB Artwork, it. uses a common ICs that can found on most electronics store.
Guys, I also interested in this GLOW PLUG igniter....but my interest is using the RECEIVER BATTERY pack to power the GLOW PLUG, I already have the circuits from MAXIMS, its a DC to DC switching ICS, that can convert a 3.6 Volts to 6 Volts to 1.5 Volts at 3 AMPS.......I already ask the sample, 6 months ago, but never got any yet.
FUTABA has this units already call GH-1, infact I already using one in my Scale Helicopter. I install a micro-Switch near the starting insert, upon inserting the starting shaft, this will active the GLOW Igniter.
Old Jun 30, 2005, 10:37 AM
wildnloose is offline
Find More Posts by wildnloose
Tulsa Int, Oklahoma, United States
Joined Oct 2003
I'm new to gas engines too, just starting to experiment...
If you are into building your own ckt, the optiglo II may fit the bill, check it out at www.cliftech.com.
If you want to purchase, www.ch-ignitions.com makes a jump start system that may work.
wildnloose is offline Find More Posts by wildnloose
Old Jun 30, 2005, 11:04 PM
Manila, Philippines
Joined Jul 2004
Yes, OptiGlow is also a simple circuit to contruct but this need extra channel to manually turn-on the glow igniter.
Guys, here is the Glow Driver Circuit from RCM magazine January 2002 issue.....its automatic, no need for extra channel, the circuit just use the receiver battery to power the circuits.
here is also my FUTABA GH-1 glow igniter, its get the power from the Receiver battery pack, its so efficient, I guess its 99% efficient....been thinking of making the same circuits for all my scale helicopter.
Its really difficult to plug and unplug a GLOW IGNITER on scale helicopter.
Discussion Opto Isolated On Board Glow Driver/Switch pbunn DIY Electronics 9 Feb 10, 2006 10:59 AM
On Board Glow System Michael Hall DIY Electronics 3 Oct 19, 2004 09:00 AM
On board Glow smokerk1 Fuel Plane Talk 4 Sep 28, 2004 08:40 AM
FS / McDaniel Digital on board glow driver ! Tom Smith Aircraft - Fuel - Airplanes (FS/W) 4 Aug 10, 2003 02:56 PM
on board glow? t.nollett Engines 0 Jul 01, 2003 04:18 PM
