Old Jun 25, 2005, 06:51 PM
The dude is offline
Find More Posts by The dude
Joined Feb 2005
Mini IFO Power? (need for speed)
I am getting a mini to go with my MK 3 for my birthday. What motor set up to use. I would prefer direct drive as the gearbox on my Mk 3 is a pain. I will get a brushless for sure. It must make the plane fairly fast with full vertical ability. My friend usually flies at 1/4 throttle.I was also thinking of modding the tail for rudder control. Anyone think thats a good/bad idea. I've seen the mod in the forums and think I could build it that way no sweat but was wondering if it was worth it??There are some manuevers that you can't do without a rudder.I'm asking the motor question because I'm pretty new at this and don't want to invest in the wrong set up. My Mk3 flies great but I wish I would have used a different motor to get more speed out of it. I love to go fast!!!
The dude is offline Find More Posts by The dude
Old Jun 26, 2005, 09:05 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I fly several scratch built Mini IFO's which are approximaterly plus 10% size wise. They are built stronger tan stock one. I use seversl motors but my favorite is a LensRC CDR motor. 20 mm Totor 25T. I fly with a GWS EP 8X4.3 or GWS DD 8X4 Xprop and either 2S or 3S Lipolys .
LensRC is here.
Here is a photo with a APC prop on it but GWS ones do work better.
Added: You mentioned need for speed , 8X4 being turned 8,200 RPMs with 3S with is pitch speed of 31 HPH . I had to add another CF tube to the main frame to stop flexing / warping with high speed turns.
FYI : that motor has over 110 hours of run time on it since 10-19-04 and still runs like the first flight.
A post in the ParkFlyers would most likely get more responces.
Charles
Pusher Jet Power Set-Ups...Need For Speed! Tim H. Pusher Prop Jet Models 18 Aug 29, 2005 06:55 AM
"The Need for Speed" fly4fun Foamies (Kits) 22 May 16, 2003 03:25 PM
IFO / mini IFO carbon rod for sale! pval3 Aircraft - Electric - Airplanes (FS/W) 5 Nov 08, 2002 01:02 AM
Need for Speed - Sirius, Smart, ? Radek Z Electric Sailplanes 24 Jun 29, 2002 11:20 AM
Need for Speed, 480 race bb timing? JasonJ Electric Ducted Fan Jet Talk 1 Nov 13, 2001 12:29 AM
