Old Jun 23, 2005, 12:33 PM
Puff is offline
Find More Posts by Puff
Joined Jun 2005
Multiplex USB Sim Interface Cable and Futaba FC-16, need help.
I recently bought the interface mentioned in the title and featured in the attachment. The store was very unhelpful (simulator wise, I bought a beautiful glider and great accessories there). The manual says it requires a transmitter with multi-function socket (charge socket for DIN diode plug). It won't conect to my Futaba FC-16, so I just wanna ask before I try the following. Will modifying the cable so that is fits into the socket help? Thanks for listening.
Puff is offline Find More Posts by Puff
Old Jun 23, 2005, 01:23 PM
aeropal is offline
Find More Posts by aeropal
aeropal's Avatar
Joined Jan 2003
aeropal is offline Find More Posts by aeropal
Old Jun 23, 2005, 01:30 PM
Puff is offline
Joined Jun 2005
I've had this controller for 5 years. And I don't plan to tinker with it. I just wanted to ask if it's a good idea to modify the interface cable so that it fits into the charger socket on my FC-16.
Old Jun 23, 2005, 02:58 PM
Malc C is offline
Find More Posts by Malc C
UK
Joined Oct 2003
You don't want to use the charger socket
You can not use your TX with any simulator interface with out moddification as the FC-16 appears not to have a buddy box socket.
However modification appears to be a fairly simple matterm as there is a header on the TX PCB marked "trainer" so all that is needed is a 3.5mm mono socket and some cable.
If you are not confident about doing this small modification, then you will have a choice of either upgrading your TX to one with a buddy box port, or returning the interface to the shop as you are not able to use it with your current TX
The choice my friend is down to you
Malc C is offline Find More Posts by Malc C
Old Jun 23, 2005, 03:41 PM
Puff is offline
Joined Jun 2005
Beautiful. I'm fairly confident I do this, I just need some things from the store and I'll do this tommorow.
Can you please just elaborate to which pins on the trainer are which wires connected, and how to connect the switch?
Thank you very much.
Old Jun 23, 2005, 04:30 PM
Malc C is offline
UK
Joined Oct 2003
The centre pin on the header marked "Trainer" is the PPM (wire 1 in the above image) signal this should be connected to the terminal on the 3.5mm socket that makes contact with the tip of the 3.5mm plug.
Hope thats clear
The switch has nothing to do with this modification
Wanted WANTED: FUTABA USB Transmitter Interface Cable fatboy83 Aircraft - General - Radio Equipment (FS/W) 9 Jul 25, 2007 11:04 AM
Help! Multiplex USB sim interface scotty22 Simulators 9 Apr 01, 2006 01:15 PM
Help! Futaba FC-16 Q's RNAF Fuel Heli Talk 4 May 26, 2005 10:04 AM
WTB: Reflex XTR Interface cable (Futaba Round) localbuyer Aircraft - General - Radio Equipment (FS/W) 0 Dec 23, 2004 03:28 PM
Question Futaba FC-16 manual pecka Beginner Training Area (Aircraft-Electric) 8 Nov 19, 2004 02:33 AM
