Old Jun 23, 2005, 04:08 AM
rc-eflyer is offline
Find More Posts by rc-eflyer
T:W>1= :>)
rc-eflyer's Avatar
St. Louis, Missouri, United States
Joined May 2002
Ikarus Yak-54 with PPS Build
Since there doesn't seem to be a lot of info yet on the Ikarus PPS
system (at least I haven't seen much) , I thought I would
share my first experience trying to build a "4D" plane using one.
I ordered mine through Ohio Model Products and bought the "Combo"
system which includes the brushless motor, the variable pitch unit, and
the prop blades. First off let me say I'm very impressed with the quality
of this combination. Everything fits with precision and it's fully
bearinged including thrust bearings on the pitch slider . Also it's
really neat the way the blade grips attach right to the hub on the front
of the motor. Here's a couple of pictures, front and back.
rc-eflyer is offline Find More Posts by rc-eflyer
Old Jun 23, 2005, 04:13 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Now, getting to actually putting it into something, I chose the Ikarus
Yak-54. I always wanted one and it's also the plane pictured with the
unit on the OMP website. Using that (very small BTW) picture I've started
my builld trying to copy what it looks like they did. Here's what I've done
so far as cutting the fuse for the unit.
Old Jun 23, 2005, 04:16 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
This picture shows how I mounted the pitch servo and how the Ikarus
adaptors are going to be used.
Old Jun 23, 2005, 06:11 AM
mike3976 is offline
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
Have you seen the 1/8" dia. carbon tube motor mount method, shown in the Aug? issue of fly-rc, looks like the way to go for shockies
mike3976 is offline Find More Posts by mike3976
Old Jun 23, 2005, 12:50 PM
rcplaneguy is offline
Find More Posts by rcplaneguy
rcplaneguy's Avatar
Chapel Hill, NC
Joined Nov 2004
Interesting servo placement (offset). How much throw does the Inkarus unit take to pitch the blades? Some of the others require a servo horn that has a hole very close to the center of the servo horn, much closer than what your photo shows.
Thanks for the build pics!!!
rcplaneguy is offline Find More Posts by rcplaneguy
Old Jun 23, 2005, 02:23 PM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Mike, no haven't seen it yet. Hope my issue comes in the mail soon.
rcplaneguy, I might move it down one more hole but I'm hoping to
be able to use the radio to set the travel endpoints.
The reason I placed the servo where I did was to try and keep the
plane from being nose heavy. Seems like the linkage works smoothly
so far
Steve
Old Jun 23, 2005, 09:55 PM
mike3976 is offline
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
Steve, I'm going to use the carbon tube mount on my next Shockflyer. four 1/8" carbon tubes embeded in fuss from nose to just aft of wing, the motor mount "X" is screwed into the tubes. Suspose to really stiffen/strenghten the whole nose for a few grams of cf tube. The vari-prop set-up is detailed in the same article, if you suscribe to the mag, you should have it by now.
Old Jun 24, 2005, 05:31 PM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
I do have a subscription, have had for several years and they've never
missed a delivery. I think it's a great mag and hope the mail hasn't lost
my issue . Still not too late to change mine if I can see a picture of
how it works, hint....hint.....
Steve
Old Jun 24, 2005, 06:21 PM
bamm is offline
Find More Posts by bamm
bamm's Avatar
Planet Jupiter
Joined Jan 2005
Ok......... That Ikarus motor looks just like the AXI 2204. I wonder if I can buy the PPS and put it on like how it comes from Ikarus
bamm is offline Find More Posts by bamm
Old Jun 24, 2005, 06:53 PM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Yes and No . The front bell and propsaver are different in that
the propsaver is farther fron the bell to make room for the pitch mechanism.
You can use a 2204 with a hollow shaft but the shaft will have to extend
out past the propsaver so you can use the hub included with the PPS.
In other words the blade grips will attach to the hub instead of to the
prop saver.
Steve
Old Jun 24, 2005, 07:33 PM
bamm is offline
bamm's Avatar
Planet Jupiter
Joined Jan 2005
Thanks Steve for telling me that I am glad I did that befor i whent out and bought one
Thanks. Danny
Old Jun 30, 2005, 02:26 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Making Progress.......
Got the airframe basically done and the PPS installed . Here's some
shots to show how I strengthened the nose with flat CF and the unit at
extreme positve and negative pitch.
Old Jun 30, 2005, 02:34 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Looks great...mind if I steal some of your ideas?
blucor basher is offline Find More Posts by blucor basher
Old Jun 30, 2005, 02:39 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Help yerself, just don't blame me if they turn out to be bad ideas .
Steve
Old Jun 30, 2005, 02:40 AM
TeamSME is offline
Find More Posts by TeamSME
40%, 5% whats the diff?
TeamSME's Avatar
Baltimore Greenbelt, Maryland, United States
Joined Jul 2003
Sweet looking setup
VIDAGE NOW! I have to see this setup in action!
Find some street lights, it doesnt matter that it's almost 3 in the mornig on the east coast!
TeamSME is offline Find More Posts by TeamSME
For Sale New CMP Yak 54 with TT91 Four Stroke Stewby Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2005 05:04 PM
Ikarus Yak 54 AWSOME! 2talented Foamies (Kits) 0 Jun 07, 2005 03:17 PM
Ikarus Yak 54 maverick2 3D Flying 1 Jan 19, 2005 08:05 AM
Yippee! Ikarus Yak 54 Video Armin Mangelmann 3D Flying 4 Dec 24, 2004 01:45 PM
Yak 54 beta plans/build DesertRC Foamies (Kits) 237 Jan 15, 2004 11:39 AM
