Old Jun 22, 2005, 10:40 PM
DanL is offline
Find More Posts by DanL
DanL's Avatar
United States, MN, Brainerd
Low amp smoke generator
I've built and tested a low amp glycol "smoke" unit that works pretty well. Wrote a construction article for our club including pics and would like to post it here. Its a long article , but I'll give it a shot. Will reduce the pic size for posting. The parts list is based on parts available at a local surplus store, but I'll include it anyway. Here goes...
DanL is offline Find More Posts by DanL
Old Jun 22, 2005, 10:50 PM
DanL is offline
DanL's Avatar
Additional pics
more pics:
Old Jun 22, 2005, 11:50 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Very nice Dan.
Thank you so much for all the reseach, and materials condensed into a single article.
Now, what project to try this on...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jun 23, 2005, 04:09 AM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
DanL,
Your timing couldn't have been better. Thanks for the article and excellent pics!
RGinCanada is offline Find More Posts by RGinCanada
Old Jun 23, 2005, 08:39 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Great work!
On my smoker, I'm pulling 10A on 6v... looks like you've shown that a shorter bit of wire of appropriate gage can do the job at lower current. What I found was that the wire needed to glow dull red in free air to be hot enough to do the job. For a given voltage, there are all sorts of possible solutions- different combos of wire diameters and lengths can give the resistance needed to make a dull red glow. You can use tables and calculations, or just get a piece of wire and slide a pair of alligator leads along it till the color is right, measuring the current as you go.
Another hint- do a "failure test". While you are boiling off fluid, the unit will stay relatively cool. When it runs dry, heat will build up FAST inside the unit... I nearly burned down my tug this way. When you build your fog machine, do a test at full current with no fluid and the fan off, and check that nothing cracks or burns!
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Jun 23, 2005, 08:43 AM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Another hint- the crimped wire connection can work, but it also can work loose with thermal cycling, especially if you run the nichrome wire to red hot. Silver solder (the real stuff, not that 2% stuff sold at Radio Shack) will hold the joint at these high temps.
Pat M
Old Jun 23, 2005, 09:14 AM
DanL is offline
DanL's Avatar
smoker
Thanks much. Some additional info below...
Originally Posted by patmat2350
Great work!
On my smoker, I'm pulling 10A on 6v... looks like you've shown that a shorter bit of wire of appropriate gage can do the job at lower current. Actually, your work was the basis for this design. The airflow you stressed is the real trick. The other key here is the use of a "percolator" effect to pump and evaporate the fluid inside a tight insulated tube for efficient energy use. What I found was that the wire needed to glow dull red in free air to be hot enough to do the job. On this unit, you can look at the inner capillary to see if the coil is hot enough to boil and percolate the fluid up thru the tube. If too hot, it sputters out the top as hot liquid . If just right, yoe see bubbles boiling at the bottom of the tube and wispy fog comes out the top of the tube. For a given voltage, there are all sorts of possible solutions- different combos of wire diameters and lengths can give the resistance needed to make a dull red glow. You can use tables and calculations, or just get a piece of wire and slide a pair of alligator leads along it till the color is right, measuring the current as you go. Exactly right
Another hint- do a "failure test". While you are boiling off fluid, the unit will stay relatively cool. When it runs dry, heat will build up FAST inside the unit... I nearly burned down my tug this way. When you build your fog machine, do a test at full current with no fluid and the fan off, and check that nothing cracks or burns! Right - od the test. The glass parts to use are high temp "chemistry lab" glassware. This unit is somewhat "triple insulated". When dry, the hot coil is fully enclosed in a glass capillary tube, which is enclosed by the glass preheat tube, which is enclosed by the glass reservoir tube/jar. Still not preferred to run dry, but at least some protection. Also, unit only runs at about 12 watts (12V x 1A) vs 60W (6V x 10A), so max T possible is probably lower.
Pat M
Old Jun 23, 2005, 08:15 PM
Capt_Christo is offline
Find More Posts by Capt_Christo
Mostly harmless
Capt_Christo's Avatar
Sydney, Australia
Joined Feb 2005
Hey Dan,
Do you get any condesation onnthe inside of the stack. Do you have to allow for fluid dripping or do you just align it so it goes back into the resevoir?
Is there any cleaning required for this unit and roughly what is the life of the Nichrome element?
Cheers
Capt_Christo is offline Find More Posts by Capt_Christo
Old Jun 23, 2005, 08:36 PM
DanL is offline
DanL's Avatar
Catain -
there is some condensation inside the metal tube that I call the stack liner. The tube sits aligned directly over the preheat tube and is slightly larger in diameter than that tube. The reservoir tube is larger in diameter than the stack liner, so all drips go back into the reservoir. I've run maybe a total of 40 hrs of smoke, usually in 1 to 2-1/2 hr sessions, and there have been no sloppy messes.
After each run, I pop off the outer styrene stack, the aluminum tube liner stack, pull out the heater assembly, spray all with household ammonia cleaner, rinse with hot water, shake off and set aside to dry. Takes 2 minutes.
The weak point of the heater wire is not burnout - you just don't run it that hot. The failure point is the connections to the power wires. I've had one broken connection. After fixing it, I covered the whole connection area on both power leads with Permatex hi temp RTV (see the pic). It has stabilized the connections, not allowing "jiggle" that leads to broken wire.
Note that the alignment is important to get the vapor from the top of the percolator tube into the throat of the stack, and to get the best effect of the air nozzle that generates an upward airflow thru the stack as the injected air escapes.
Old Jun 23, 2005, 09:09 PM
DanL is offline
DanL's Avatar
Captain C - some pics
Here are some pics of the actual stack on the tug Rosco
Old Jun 26, 2005, 01:25 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Anyone building a smoker? I have a pair of minature 12v computer fans, cost me $12 each, that I'm not going to use. 1.3 cfm, which is the same capacity I used on my tug, blows CLOUDS of fog out. These are square case fans, fully enclosed, but what's neat is they're only 1 inch square! Tiny and quiet.
$6 each, and I'll cover the postage in the US.
Pat M
Old Jul 14, 2005, 07:45 PM
Jameso5 is offline
Find More Posts by Jameso5
Scottsdale, AZ
Joined Jul 2005
I' ve built a smoker from Dans instructions with a few mods, and hooked the fan directly to the motor on my tug so the smoke increases with motor speed. Works fine fwd. but in rev. the cabin fills with smoke. Does anyboby know of a way to get this to work in rev. The main motor is controled by an esc.
Jameso5 is offline Find More Posts by Jameso5
Old Jul 14, 2005, 08:04 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
A diode bridge will "rectify" the current to fan. Sketch to follow.
Pat M
Old Jul 14, 2005, 11:29 PM
Jameso5 is offline
Scottsdale, AZ
Joined Jul 2005
Thanks Pat & Dan for all there info. Will work on it and see how it goes.
Jim
Old Jul 16, 2005, 02:39 PM
Tony Oliver is offline
Find More Posts by Tony Oliver
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Umi - you ask which project? - Answer is 'any project - you won't be able to see it for the smoke!
Nice one Dan.
Tony
Tony Oliver is offline Find More Posts by Tony Oliver
Low Amp Jeti Advance ?s kitfoxdrvr Power Systems 6 Feb 14, 2016 07:42 PM
Smoke generator for elctric stunt plane allen1allen Power Systems 5 Oct 22, 2003 08:14 PM
I need something that will fly low & Slow - Any Recommends? mrebman Parkflyers 20 Jan 04, 2003 11:40 AM
Low amp kwik-e? DeaninMilwaukee Sport Planes 26 Aug 23, 2002 08:20 PM
Low Amp Connectors? Toaster Parkflyers 2 Mar 26, 2002 07:11 AM
