Old Jun 21, 2005, 09:14 AM
nyrangers995 is offline
Find More Posts by nyrangers995
Joined Jun 2005
upgrade reef racer 2 ?
Im pretty new to electric boats and was wondering which motor would anyone in the forum recommend for upgrading my reef racer. I see that it has been done before but Im kinda hesitating on doing it myself. any suggestions, links with info. is really appreciated....
the faster the better......
nyrangers995 is offline Find More Posts by nyrangers995
Old Jul 02, 2005, 05:59 AM
mob58 is offline
Find More Posts by mob58
Wild Hawk Fanatic
Merritt Island, Florida
Joined Jul 2005
Hi!
I'm new to this forum and a neophyte to electric boating, so my suggestions must be taken with a grain of salt.
I have two of these on order and am also interested in upgrading them.
Motor Upgade
I'm not quite ready to perform surgery on them so I have been trying to find a direct replacement motor. It looks like the Graupner 480BB
might fit directly with a diameter of 29.3mm. Can you tell me the actual diameter of the stock motor?
Prop Upgrade
Going to a slightly larger, better quality prop (esp if the motor is already upgraded). I'm looking at these (also at offshore electric):
Beryllium Copper Metal Props
X427 (1.06") 1.4x1.06=1.484" 1/8"
X430 (1.18") 1.4x1.18=1.652" 1/8"
X432 (1.26") 1.4x1.26=1.764" 1/8"
Downside is that these are quite expensive.
On the cheap side I just ordered (Tower Hobbies):
LXCTD0 Hobbico Propeller Nitro Hammer & ProFisherman (2) $4.49
I'm hoping they will fit.
Carbon fiber props seem like a good choice, but I have not found any to fit.
Trim Tabs
Also trim tabs might be useful at a later stage (Tower Hobbies):
LXGRW5 Hobbico Trim Tabs w/Screws Hammer EP $2.69
Battery Pack Upgrade to 8.4v
Haven't found a stock replacement yet, may have to build one.
That's about all the ideas I have about it at this time. Any suggestions from anyone would be much appreciated.
mob58 is offline Find More Posts by mob58
Old Jul 02, 2005, 06:49 AM
Joined Jun 2005
Thanks for the info. I ended up buying a 400 motor from towerhobbies.com for like $10 and it works great....alot faster! does anyone know if a 550 motor would work?
Old Jul 02, 2005, 07:11 AM
mob58 is offline
Wild Hawk Fanatic
Joined Jul 2005
Which motor did you buy?
Old Jul 02, 2005, 02:19 PM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
The 480BB should fulfil your performance expectations .... until the esc burns up. You'll need a 20/25 amp capable esc. for that motor especially if upping the no. of cells Graupner do a 29 mm carbon prop which is about as much as the 480 will take. The ocyura x427 would be a safer bet but it needs balancing, sharpening and polishing to give its full potential.
martin richards is online now Find More Posts by martin richards
Old Jul 02, 2005, 03:09 PM
mob58 is offline
Wild Hawk Fanatic
Joined Jul 2005
Thanks for the input. I was beginning to suspect as much just looking at the guage of the wires that come with that motor, and others of similar calibre - much thicker than the standard wires in the RR2.
Right now I'm looking at getting either a Multiplex Permax 400 6V Motor
or a Speed 400 6.0V Motor
That way I'm already overvolting it with the standard battery pack without having to build a new one, though I'm sure the runtime will be a bit decreased.
Old Jul 04, 2005, 05:35 PM
Joined Jun 2005
yeh i ended up blowing my controls on the reeef racer cause i guess the motor was too powerfull. can anyone give me some insight as far as the speed controls i can put in to solve this problem. i just upgraded to a standard 400 motor from towerhobbies.com...any help is really appreciated thanks!
Old Jul 04, 2005, 09:53 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
A speed 400 should pull about 10 amps at max power. Playing safe, any 15 amp rated esc should work. You might want to consider water cooling the motor as well.
Old Jul 05, 2005, 11:46 AM
Joined Jun 2005
the reef racer is water cooled but im not understand the esc. Here is what is in there right now....
http://www2.towerhobbies.com/cgi-bin...?&I=LXJRV4&P=7
I maybe wrong (Im new to this stuff) but that unit connects the controler to the boat. Can i just relace the unit with something like this....
http://www2.towerhobbies.com/cgi-bin...?&I=LXBNC5&P=7
Old Jul 05, 2005, 12:51 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
The Reef Racer unit is listed as a combo reciever/esc. To install a new ESC, you would also have to install a separate reciever.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jul 05, 2005, 03:06 PM
Joined Jun 2005
Thanks for all the help....so your saying something like this would work with a new esc?
http://www2.towerhobbies.com/cgi-bin...I=LXASX2**&P=0
Old Jul 05, 2005, 09:46 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
You just need a new receiver and an ESC. Something like these:
Futaba rx
Tower Hobbies rx
Novak rx
Trinity ESC/RX unit
Novak Spy ESC
CG Bob is offline Find More Posts by CG Bob
Old Jul 05, 2005, 10:39 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
The Futaba transmitter and reciever should work.
If you decide to buy the reciever only, make sure you match the 27mhz frequency that the Reef Racer came with. There are typically six available. So Check your Transmitter Frequency down to the last decimal point before you order.
The Reverse option of the Novak Spy ESC might be nice...
Old Jul 05, 2005, 11:54 PM
Marv829 is offline
Find More Posts by Marv829
Occasional Flyer
Iowa
Joined May 2004
Don't forget the Reef Racer 2 is a "FM" radio on 27mhz.
Marv829 is offline Find More Posts by Marv829
Old Jul 06, 2005, 09:23 AM
Joined Jun 2005
I think im getting it now...this is my order im going to place. Let me know if it looks good.
1. http://www2.towerhobbies.com/cgi-bin...?&I=LXBNC5&P=7
2.http://www2.towerhobbies.com/cgi-bin...?&I=LXFAG7&P=0
3.http://www2.towerhobbies.com/cgi-bin...I=LXASX2**&P=M
does this sound right? I dont think Im missing anything.
Again thanks for all the help....
Discussion Turbo Vee 3 vs. Reef Racer 2 makg Racing Boats - Electric 6 Jun 28, 2008 02:16 AM
Discussion Reef Racer 2 sci-flyer Dock Talk 6 Jun 20, 2006 06:50 PM
For Sale Hobbico Reef Racer 2 (Yellow) Marv829 Boats (FS/W) 1 Oct 23, 2005 11:37 AM
Reef Racer vs. Reef Racer 2 ? plasticjoe Racing Boats - Electric 1 Sep 29, 2005 09:43 PM
Reef Racer 2 vs. Zig Zag 2 MrToes Dock Talk 7 Aug 15, 2005 01:11 PM
