Old Jun 20, 2005, 09:36 PM
nose_first is offline
Find More Posts by nose_first
nose_first's Avatar
Riverview, FL
Joined Dec 2002
Blade CP - tail rotor retention issue
i saw in one of the other threads that people are having issues with the tail rotor coming off because of the rubber tubing coming off. well it just happened to me (but it was during my hovering practice when a gust came and the heli got up some from me) anyway - i lost the rubber grommet and was wondering what else i could use to help keep this on.
i just borrowed a piece from the battery holder until i could find a more permanent source if this is indeed the best way to keep it on.
one thing i thought about doing was using a wheel collar on the edge of the rotor shaft. this would allow the gear to have some play and spin free if it was knocked out - but keep everything on the assembly. any thoughts on this?
thanks in advance
nose_first is offline Find More Posts by nose_first
Old Jun 20, 2005, 09:48 PM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
Just find a big electric wire (big-size) and remove the wire..
Then you sitting left with only the tube to the wire !!
If that`s correct size you got 1000feet for free
liteglow is offline Find More Posts by liteglow
Old Jun 20, 2005, 10:20 PM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Keep in mind the tube is supposed to come off to avoid damaging the rotor. They sell those by themselves so you can have lots of spares.
raz is offline Find More Posts by raz
Old Jun 21, 2005, 12:19 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
You know, it looks to me like a GWS DD tail would bolt right on there... I havent seen one on person but I would put money on it, get yourself an IPS motor and a 4530 prop with adapter.... problem solved
dacaur is offline Find More Posts by dacaur
Old Jun 21, 2005, 01:12 AM
flying camel is offline
Find More Posts by flying camel
'cus I fly a long time
flying camel's Avatar
United States, UT, Lehi
Joined Jul 2004
tail rotor problems
Mine has come off many times too I now use heat shrink and it is on good now. if you need to replace it you slice the heat shrink off and put a new one on.
Flying camel
flying camel is offline Find More Posts by flying camel
Old Jun 21, 2005, 08:13 AM
bwarkent is offline
Find More Posts by bwarkent
Houston Texas
Joined May 2005
If you have a daughter by chance, you can use her little hair rubber bands. I put one on in a pinch the other day and never took it off.
bwarkent is offline Find More Posts by bwarkent
Old Jun 21, 2005, 09:02 AM
nose_first's Avatar
Riverview, FL
Joined Dec 2002
thanks all for the suggestions..
i want a solution that will allow me to lose the rotor in the event of a crash - so i think i will try to find the correct wire size snd pull the insulation off. that sounds like the quickest fix. on other thing i thought about was get a rubber band (large size about 1/4" thick) and cut it into small squares. this could be used as a crude sort of lock washer. still allows it to come off in a less than optimal landing - but holds it together in the air.
dacaur- the guy at the LHS has put a GWS DD ips motor on one and likes the results. says its a little louder than the stock setup, but likes it a it better.
Old Jun 21, 2005, 09:27 AM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Oh yea, forgot to mention the "hive of angre bees" sound you will get with the DD tail and 4530 prop, I dont even notice it anymore, I think it sounds kinds cool.... Its definatly more durable than the stock setup I can tell you that, as the stock setup looks identicle to my walkera # 4's stock setup, and even using the little bit of tubing, I broke a couple stock props, I have only broken one 4530 prop, and that was after hitting the ceiling and dropping to the floor.
Old Jun 21, 2005, 09:49 AM
nose_first's Avatar
Riverview, FL
Joined Dec 2002
being new to helis (and yes i know everyone says this isnt a trainer) i want what will make it fly the best.
hey - i made some training gear and had it floating around last evening. got a little wobbly so i think i understand the ground effect i read about. and i learned one very important thing.. the little toggle switch on the right is the heart attack switch.. and boy does it take off when you hit it while trying to move around on the ground.
Old Jun 21, 2005, 10:16 AM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
Originally Posted by dacaur
Oh yea, forgot to mention the "hive of angre bees" sound you will get with the DD tail and 4530 prop.
Pah, the 4530 props are silent compared to the 3020 props!
But yes, I would recommend getting the DD tail and 4530 prop, said to be the best tail set up, even better if you can afford a BL DD tail motor... (I cant... )
Duane
Minimole is offline Find More Posts by Minimole
Old Jun 21, 2005, 10:45 AM
Biffa is offline
Find More Posts by Biffa
Multi rotors and foamy planks
Biffa's Avatar
Bedford, UK
Joined Dec 2004
Yeah, you wait till you put on a 0320 prop and do some piro's, then you'll know what angry bees sound like
Biffa is offline Find More Posts by Biffa
Old Jun 21, 2005, 01:26 PM
nose_first's Avatar
Riverview, FL
Joined Dec 2002
piro's? im looking to hover through a whole pack
Old Jun 21, 2005, 02:10 PM
someone1111 is offline
Find More Posts by someone1111
Joined May 2005
You can also use some small fuel line from the hobby store...
I just bought a couple of feet of it and use wire cutters or scissors to snip off little bit when I need a new grommet.
someone1111 is offline Find More Posts by someone1111
Old Jun 21, 2005, 02:17 PM
nose_first's Avatar
Riverview, FL
Joined Dec 2002
well all of the fuel line they had was too large - or lid too easily - so they gave me a gws package of mabe 20 of them. for about a buck i am happy. since i am learning still, i expect to knock around the tail, but once i am a somewhat more proficient pilot, i will likely do some of the more permanent solutions
Blade cp tail rotor bearings - wrong ones from factory? nose_first Micro Helis 1 Aug 14, 2008 10:03 AM
Discussion Blade CP tail rotor acting up technician Micro Helis 7 Mar 21, 2006 09:39 AM
Question Blade CP Tail rotor problem... BeechSkipperDude Micro Helis 14 Oct 25, 2005 02:51 AM
Sold DD (Direct Drive) Kit for Blade CP Tail Rotor Harv Aircraft - Electric - Helis (FS/W) 2 Oct 19, 2005 05:46 PM
Alert Blade CP tail rotor problem Jim Bacus Micro Helis 7 Sep 03, 2005 04:46 PM
