Old Jun 24, 2005, 12:40 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Interesting stuff on the TREXTuning site.
The TP pack tested was a 4S 2000, vs a 3S Kokam.
The TP is still lighter by 5 grams. At 10C The TP had 40% higher energy density ( WH/kg). The TP pack had a delta T of 50 degrees C, vs 31 degrees C for the Kokam.
It could be argued that one reason that the TP runs hotter is that it's lower mass results in a larger temperature change for a given amount of energy absorbed ( CMdeltaT).
The Kokam pack also has about 20% more surface area which would help in the dissipation of heat.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Jun 24, 2005, 03:06 AM
Western Iowa, United States
Joined Nov 2003
Originally Posted by electroman
<snip>
Our objective is to help everyone be successful with Li Pos and it is self evident that keeping the packs cooled and keeping the load within a safe operating range is important to that success.
<end snip>
Hi Fred,
I have a secondary question.
It’s not related to fire resistance, but the storage and use of the new stronger cells.
Specifically answer #4 (in the reply to meteor, in your forum) about the state change that can happen when LiCo 02 is stored discharged.
Some of us have been using a higher cutoff voltage (3.2-3.3v), to leave some capacity remaining at the end of a flight in an attempt to extend lipo life, and avoid the area of temptation below the knee.
Personally, I try to operate them between 3.7 & 4.2v OCV.
What is Kokam’s suggestion for the best short-term, and long-term storage “voltage” for the new formula?
Jim
IA-Flyer is offline Find More Posts by IA-Flyer
Old Jun 24, 2005, 07:17 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Your lack of objectivity is evident in your slanderous statement that relating those facts is misleading salesmanship. What is misleading and unfair is making unsubstantiated claims about running those cell at 10C and ignoring that they get so hot you can't touch them. Isn't it interesting that running them in a professional lab with professional people and professional equipment shows results so different from your subjective assessment? It is the facts you left out that really matter because they may lead an innocent newbie to make a mistake.
I was an innocent LiPoly Newbie last June when I was mislead by the statement that Kokams were the Gold Standard and wasted money purchasing over $400 worth of overweight,underporforming packs.
My cells /packs ran in flight 10C or any other C do not get above 128F to the best of my knowledge. I have always stated that running discharge test on LiPolys without cooling was not advisible or practicle. There is cooling air available during flight and would not be wise to not use it. I ran CBA Test on some cells without cooling which did reach 160F but I could still touch them in fact I could hold them without any problems.
It would be interesting to see how many Tanic,Apogee,E Tec,Thunder Power,DuraLite ,LiPoly users you could get to agree that non of the Packs they use are capable of being used above 5C without damage, as you stated in your statement.
Newbie seeking help with Kokams
Changed to Tanic and problems solved..
Charles
Old Jun 24, 2005, 08:31 AM
sneu's Avatar
San Diego USA
Joined Dec 1999
Originally Posted by Ulf Herder
Hi Steve,
that small fire looks not so dangerous as the "italian land mines" from last year.
Best Regards,
Ulf
The " land mines" were quite the thing! The fire from these cells was much "hotter" Did you see the "american welders" in York? That was nearly as nice as the Italian one!
Steve
sneu is offline Find More Posts by sneu
Old Jun 24, 2005, 08:38 AM
Space Coast
Space Coast
Joined Oct 2000
I was going to list all the summaries but it's getting very long and it's easier to just go to the trextuning site and read them
hoppy is offline Find More Posts by hoppy
Old Jun 24, 2005, 09:43 AM
USA, FL, Apopka
Joined Dec 2000
I went to the T-REx site http://www.trextuning.com/ and read through the tests and found them to be very informing. My observations are:
1.) We need to pay better attention to airflow cooling of our packs especially now that it is summer.
2.) No manufacturer seems to be taking into consideration the heating of middle cells in our packs.
3.) The Gen 4 Kokam cells handle temperature rise very well but have a weight penalty.
4.) The TP ProLites are very light but will have a heat problem if not well cooled by airflow.
5.) Polyquest is somewhere in between the TP ProLites and the Gen4 Kokams and is a very good alternative.
6.) Wow, what happened with the Tanics?
The tests by Mark Hopkins seem to be very professionally done and to be what many of us have been begging for, an independent tester that could perform the tests under labratory conditions. I have bookmarked his site and plan to refer to it often.
Brad
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old Jun 24, 2005, 01:06 PM
Walled Lake, MI, USA
Joined Feb 2000
The fact that lighter weight LiPos have more of a problem with heat than heavier weight cells may only be applicable in this single comparison, or it may be preliminary evidence of a general trend. The truth should come out as more evidence is gathered.
Previously, heavier LiPo cells have been considered inferior to lighter cells in every way. In fact, it is possible that heavier cells may have internal components that provide undocumented and yet-to-be-measured benefits. Simplistic measurements of complex systems often produce misleading results. It's possible when all the facts are known that there may be good reasons for many people to choose the heavier of two LiPo cell options. But this will require understanding all aspects of LiPo performance rather than just a few.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Jun 24, 2005, 03:57 PM
Gaithersburg, MD, USA
Joined Jun 2000
Cut off
Originally Posted by IA-Flyer
Hi Fred,
Jim
Jim,
You will find the answer to your question at
http://www.rcgroups.com/forums/forum...ysprune=&f=220
under Li Po Cut-off and storage where it will not slide off the page in a few hours.
electroman is offline Find More Posts by electroman
Old Jun 24, 2005, 04:11 PM
Space Coast
Space Coast
Joined Oct 2000
http://www.batteryuniversity.com/parttwo-34.htm
New GWS Tiger Moth 400; what to expect! sammy Parkflyers 9 Oct 25, 2009 06:30 PM
Head's up - New Low-Cost 370/400 Brushless Motors! Peter Khor Power Systems 447 Feb 14, 2005 07:39 AM
FS: New Wattage Super Cobalt 400 motor jk Aircraft - Electric - Airplanes (FS/W) 4 Oct 05, 2003 09:02 PM
new batts for speed 400? dave morris High Performance 5 Oct 01, 2002 05:44 AM
New Battery for speed 400? Richard Emholtz Foamies (Kits) 2 Sep 27, 2002 07:49 AM
