Old Jun 19, 2005, 06:43 PM
john.631 is offline
Find More Posts by john.631
Joined Jun 2005
RC model catamaran?
I want to build an RC catamaran, so I started cruising the internet this afternoon and wound up here. I haven't seen any cats in passing through about 30 websites. Are there any?
I want to test some hull ideas for a beach cat that would be 12 ft. long full scale. Am I on my own here?
John
john.631 is offline Find More Posts by john.631
Old Jun 19, 2005, 11:43 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Try this.
http://www.rcsailing.net/forum1/forum.asp?FORUM_ID=37
MILLERTIME is offline Find More Posts by MILLERTIME
Old Jun 20, 2005, 02:48 AM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
John,
VMP (Victor Model Products) makes a catamarand. Don't have the address handy, so do a search for "Victor Model Products", shouldn't be difficult to get to. I'm sure there are other manufacturors, I'm just not aware of them...
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Old Jun 24, 2005, 11:45 PM
rcbiker is offline
Find More Posts by rcbiker
Joined Jul 2004
catcatamaran
I just order the WILD CAT from VICTOR MOLDEL the kit is95.95 Or they
will build it for you Try www.victor-model.com KJ
rcbiker is offline Find More Posts by rcbiker
Old Jun 25, 2005, 07:55 AM
Doug Lord is offline
Find More Posts by Doug Lord
rc catamarans
The rc sailing site has good info on some cats built all over the world; check out Andy Littles' Kwickie.(site appeared down yesterday)
Be wary of building a model cat as a test for a larger boat unless you build it as large as possible-say 6'. The reason is that as the multies scale down they lose pitch resistance which makes even 4 footers(mini 40/F48) hard to sail for beginners.Also a scale rig will generally be too much SA except for the lightest wind-multiple or reefing rigs are required in order to be able to sail as the wind picks up. In the model world so far tri's have proven a bit easier to sail both straightline and tacking.
If you do build a model to test the full size idea I would strongly suggest that you incorporate a movable ballast system(side to side and fore and aft) which, though expensive, will give you a more realitic assesment of performance.
Because of scale factors, again, you will have to watch your sail area and weight: I would suggest making the hulls exact scale with scale ballast(crew) and reducing sail area to less than scale.Always have access to a rescue boat when sailing any type of small multihull. You will have to make more compromises the smaller your test model..Good Luck!
Doug Lord is offline Find More Posts by Doug Lord
Old Aug 16, 2005, 11:46 AM
Hobiestoke is offline
Find More Posts by Hobiestoke
slow & draggy...
Hobiestoke's Avatar
Albuquerque, NM
Joined Jul 2004
Doug is right - Last year I built a 4 meter (14ft) Performance catamaran of my own design.
www.geocities.com/proteus_catamaran
Im currently building a model of it this summer but hulls need to be much farther apart on a model cat or it
will flip too easily! Heres a link to an old post when I started it. Im about to dust off this project again since they are almost done re-building our local boat pond
Hobie
http://www.rcgroups.com/forums/showthread.php?t=289244
Hobiestoke is offline Find More Posts by Hobiestoke
What is the cheapest laser cutter in the world,suitable for making RC model parts? bipeflyer The Builders Workshop 7 Dec 03, 2002 01:45 PM
help find rc model of C-121 roguewolf Aircraft - Fuel - Airplanes (FS/W) 0 Sep 17, 2002 07:17 PM
China Beijin RC Model Show ( Oct. 3~7) GWS4CEO Parkflyers 3 Oct 06, 2001 05:21 PM
Arado 232 free plans from RC Model World stealthy Scale Kit/Scratch Built 0 Oct 04, 2001 02:20 AM
RC Model World A-10 Plans Ralph A. D'Amelio Electric Ducted Fan Jet Talk 2 May 28, 2001 11:36 AM
