Jun 19, 2005, 09:28 PM
Fairfax, Virginia
Joined Feb 2004
@ bobsean : thanks bob for the reply. I sure hope it flies.
@ wired : you mean the vertical stab is big or the horizontal ? it looks good thats why I made it that way. but if it will affect flight performance then i will have to reduce it.
@ john : it sure is a cross between many things.
@ sad : i took balancing into consideration. i am gonna use AA size 1300 mah batteries and 1150 . with the nose too a bit longer than usual...and with the heavy batteries i hope to get proper balance.
do you think I should gear the warp 4 or just go direct drive ? from the specs the warp 4 is lister for direct drive.
I also forgot to mention, once i add ailerons, the wing chord is gonna increase by about 3/4 of an inch .
and to balance the long tail...i might have to drill a few more light'ing holes in the fuse's tail section.
should i go for tricycle kinda wheels or just two ? what do you say ?
