Old Jun 19, 2005, 12:01 AM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
What's your favorite windy day flier?
I used to HATE windy days; I wouldn't even consider going flying. But these days if the wind is, let's say a steady 8-12 mph, as it is here in Texas frequently, I break out my Microbat:
http://www.rcgroups.com/gallery/show...cat=500&page=1
What's your favorite plane to fly on windy days? (photos would be nice)
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old Jun 19, 2005, 12:19 AM
Daniel G is offline
Find More Posts by Daniel G
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Any of my wings.
And if I really want some fun I use the slowstick. Who cares about wind, when you have enough power.
Daniel G is offline Find More Posts by Daniel G
Old Jun 19, 2005, 12:58 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
My NFCM Halfpipe slope racer! This bugger is FAST.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 19, 2005, 01:42 AM
Daniel G is offline
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
I like that one Mark.
Do you actually use the rudder, or is it just taking the place of winglets/tiplets.
Old Jun 19, 2005, 03:01 AM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
1) My RBC Kits (http://www.rbckits.com/) Delta 400 (balsa with Oracover, wingspan 53cm Speed 400 direct drive with 5x4.5 Guenther prop, Kontronik Li-Ion 7.4V (2S) 1100mAh battery resulting in flight times of 10-15min; fast and aerobatic)
2) Insulator 2 (black depron 6mm with a few carbon rods, wingspan 60cm, Multiplex Compact 180 brushless motor, APC 6x5 prop, LiIon 11.1V (3S) 1200mAh battery resulting in fight times of 10-15min, and
3) My 'reusable disposable park flyer' based loosly on the BluJeti/ZagNutz wingplan (blue 6mm depron with some carbon rods, wingspan 80cm, Typhoon Micro 6/3D with APC 6x5 prop, LiPo 11.1V (3S) 1200mAh battery resulting in flight times of 10-15min (more if gliding around a lot)). This one started life as a sort of botcat (seen in the picture of the Insulator 2), but when the tail broke of on a 'fast landing', I just moved the battery back, reconnected the servo's to the Rx, reprogrammed the Tx, put on two winglets, and now fly it as a flying wing with a rather long nose ('airbag for fast landings')).
Each is small and relatively (BlueJeti-Wing) to very (Delta 400) wind insensitive. Piling them in the back of the car in correct sequence they just fill a small corner of the boot and thus are always at hand to fly, assuming I also have Tx and batteries with me.
Arthur P. is offline Find More Posts by Arthur P.
Old Jun 19, 2005, 01:08 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Thanks. So do I!
No rudder. Elevon controls.
mw
Old Jun 19, 2005, 01:22 PM
wattman is offline
Find More Posts by wattman
wattman's Avatar
Evansville Dress Reg., Indiana, United States
Joined Jun 2004
Parkzone Stryker , best I have for the wind conditions that ground the rest .
wattman is offline Find More Posts by wattman
Old Jun 19, 2005, 03:16 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
I have to ditto what Mark said: When the wind rips, my Halfpipe zips.
Since I started sloping, I enjoy a good onshore blow every bit as much as I used to enjoy those still mornings at the electric field. On many days I can have the best of both worlds on the same day.
Pete
PGR is offline Find More Posts by PGR
Old Jun 19, 2005, 03:38 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Ronnie
My home made flying N.A.S.S (Not a Stop Sign) does well in the wind.
Here is a better picture of the Nass and my stop sign also.
epoweredrc is offline Find More Posts by epoweredrc
Last edited by epoweredrc; Jun 19, 2005 at 11:50 PM. Reason: To add a better Picture
Old Jun 19, 2005, 04:25 PM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
I like my Twinjet, on windy days. That plane just LOVES strong wind !
On the slope, then the Combat Air Model P-51 is a blast !
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Jun 19, 2005, 04:50 PM
LittleJon is offline
Find More Posts by LittleJon
LittleJon's Avatar
Laguna Beach, California
Joined Nov 2004
The Mini Bird of Prey does great in the wind. The only conditions I don't like to fly it in are when it's overcast, as my colour scheme doesn't show up well against a white sky.
LittleJon is offline Find More Posts by LittleJon
Old Jun 19, 2005, 05:32 PM
1987tc is offline
Find More Posts by 1987tc
Come fly with us in Henryetta
United States, OK, Weleetka
Joined Dec 2000
My Pizza works for me! If I can hold on to it long enough to plug in the battery and turn on the transmitter ( not in that order!) then I can fly. So far any wind I have tried to fly in I have been able to.
It aint a thing of beauty but it flys good! And brushless power sure helps!
1987tc is offline Find More Posts by 1987tc
Old Jun 19, 2005, 06:16 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I fly my e-streak and heli on windy days. The e-streak will handle about 20 mph with ease. Makes landing shorter too.
The heli i can fly in 30 mph winds..very intresting to fly though when the wind is that strong.
My next wind plane will be my EDF. That little power house should be able to handle winds very nicely.
ash
ashdec87 is offline Find More Posts by ashdec87
Old Jun 19, 2005, 09:01 PM
wattsup_kz is offline
Find More Posts by wattsup_kz
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
My brushless Formosa cuts through the wind quite well.
wattsup_kz is offline Find More Posts by wattsup_kz
Old Jun 19, 2005, 10:26 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
You fly that??!!??
Try not to laugh, but when the wind is up, the Ferias goes up! In its original form, the plane was a real slug. However, modifications to the power train turned this bird into a very comfortable flyer, especially in high wind (20 mph+) conditions. After the present Speed 400 finally smokes out, B/L upgrade will be made. Present 2100 2S1P and 3S1P TP LiPoly's, Gen II work very well on the Speed 400 with planetary gear box, 3.33:1, and 9x7.4E APC prop. Yeah, I know.........a Ferias??? Something about a silk purse from a sow's ear rings a bell. 161 flights as of today, all else is still the original.
What can I say, it has become a family pet! [..don't anyone come back with...."must be a real dog!"]
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
What's your favorite light-weight covering for balsa? CheeseWing Parkflyers 7 Jul 22, 2008 09:25 AM
Discussion What's your favorite windy weather plane? Cincy E-Flyer Electric Plane Talk 29 Mar 24, 2007 08:12 PM
What's your favorite plane? spy0o7 Electric Plane Talk 47 Aug 08, 2001 04:36 AM
What's your favorite large sailplane (8-12' wingspan), and why? DocMac Electric Sailplanes 22 Jun 12, 2001 07:35 AM
What's your favorite Heli.......................? Fred Bronk Electric Heli Talk 20 May 20, 2001 05:43 AM
