Old Jun 18, 2005, 03:25 PM
presslab is offline
Find More Posts by presslab
presslab's Avatar
Joined Dec 2004
Another ION newbie
I have a couple flights in on my new ION now, it is great! I have a geared motor I made myself, pulling 45 amps on 10 GP2000 cells. AUW is 1300 gm. Nice vertical with a 13x11 CAM prop.
So I have a couple questions.
I'm using regular HS-81 servos for everything, should I get the metal gear ones for the ailerons? The reason I ask is because I tried a 10 cell IB3600 pack which is a lot heavier, and I think I heard the ailerons flutter during a dive. It was cooking though! However I like it lighter with the GP2000 cells, and I haven't heard the flutter with these.
I notice some adverse yaw during a roll, especially at slow speeds. Is this normal? Ailerons are 15mm up, 8mm down. Should I have more differential?
Other than that it is awesome. CG at 90mm, nice roll rate, predictable stall, really a cream puff.
Ryan
presslab is offline Find More Posts by presslab
Old Jun 18, 2005, 05:26 PM
BING! is offline
Find More Posts by BING!
BING!'s Avatar
usa
Joined Mar 2003
Any slop in the connections? The metal gears wont really reduce flutter if the torque is the same. If you need to upgrade, the 85BBs have more torque, speed and beefeir gears than the 81s. i have busted 81s enough to opine that the 85 are worth the money. I also own the 125s and they dont fit the ION without cutting into the servo well in the wings. Ask me how I know.
I personally dont like metal gear servos because they wear and need replacing. Otherwise, slop will become a problem.
BING! is offline Find More Posts by BING!
Old Jun 18, 2005, 05:57 PM
presslab is offline
presslab's Avatar
Joined Dec 2004
So how do you know about the 125s?
Thanks for the tip on the 85BBs. I've looked at it some more and I don't see any slop in the joints, I used the parts in the kit. A Z-bend on the servo side and the threaded clevis on the other.
I suspect that it might be my servo mounting method. I used some thin 3M VHB tape to secure the servos and I think it is too compliant. How do you guys mount the servos? I read of heat-shrink over the servo and then Goop it to the wing. Should I try that?
I didn't think about the metal gears wearing out. Makes sense!
Thanks for the help!
Old Jun 18, 2005, 07:28 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
You'll have far more slop in your linkages than you'll EVER see in the servos metal gears.
tic is offline Find More Posts by tic
Old Jun 18, 2005, 11:13 PM
kwilliby is offline
Find More Posts by kwilliby
Omaha, Nebraska, United States
Joined Aug 2002
I used hs81's all the way around. In the airleron servos I put zappa-dappa-goo in four corners of the servos. then a couple of balsa blocks on each side of the servo for a little extra strength (probably didn't need). I'm flying with 10 gp2200's and a 3s2p2250 lipoly. I've seen the wings flex but no airleron flutter so far.
And yes it is a sweet plane to fly!
kwilliby is offline Find More Posts by kwilliby
Old Jun 18, 2005, 11:20 PM
BING! is offline
BING!'s Avatar
usa
Joined Mar 2003
OMG, Kwilliby! What are doing that flexes the wings? I cant wait for my 2200s to finish formatting. I am looking to do some major suicide dives with those. Did you check if you pull more amps on the 2200s? My Jeti 40 is already pretty stretched at 55 amps with the 3S Li-pos. I am seeing the peak voltages of around 14+ volts on my charger.
Old Jun 18, 2005, 11:31 PM
kwilliby is offline
Joined Aug 2002
I'd have to check again but I think on the 2200's I'm pulling about 53amps. I've cycled them several times now and they are getting better. I'll check them again.
Flexing the wings? Just a little. I pull the plane veritcle on full power up till about 200', then pull a loop, roll it over and head for the ground. After buzzing the field I hit the throttle while flying level and yank the elevator to head up again. That's when the wings flex a 'little'. . I actually don't see it much but my friends that are watching are telling me how the wings are flexing a bit. They are really impressed with this plane as well. One of them bought one but doesn't have it in the air yet.
What surprises me it how it will thermal. Even with the 2200's this thing will thermal quite well. You just have to get used to it moving faster than a normal thermal ship. It kinda looks like a go-cart zipping around. COOL!
Old Jun 20, 2005, 02:46 PM
presslab is offline
presslab's Avatar
Joined Dec 2004
OK I'm gonna glue the servos down, I already have balsa blocks. Thanks for the tips guys!
Old Jun 21, 2005, 01:31 AM
PiNa is offline
Find More Posts by PiNa
Czech Republic, Hlavní město Praha, Prague
Joined Jul 2004
Hi, I was asking the same question in our local DF over here in CZ, when I was building my ION last year, and I have got reply with pictures attached directly from Josef Palacek who manufactures ION (Hook/Hoot) ships.
He usually heat shrinks servo, catches it with hot glue and then fixes it with pieces of hard balsa as shown on attached pictures (no heat shrink there this time).
Hope this helps.
PiNa is offline Find More Posts by PiNa
Old Jun 21, 2005, 02:15 AM
BING! is offline
BING!'s Avatar
usa
Joined Mar 2003
Hot glue? ............................ BRILLIANT!
Old Jun 21, 2005, 06:11 AM
modest-master is offline
Find More Posts by modest-master
modest-master's Avatar
Palm Bay, FL, USA
Joined May 2001
Servo Frames
Better options
Use Servo Frames
http://www.espritmodel.com/accesorie...are.html#frame
modest-master is offline Find More Posts by modest-master
Site Sponsor
Old Jun 21, 2005, 06:25 AM
PiNa is offline
Joined Jul 2004
I dont think servo frames are better option in case of ION, but in fully molded wing they are real life saver
BTW: Lot of ppl here in CZ fly ION with these servo holders...
Old Jun 21, 2005, 11:21 AM
presslab is offline
presslab's Avatar
Joined Dec 2004
Wow, what an elegant servo holder. Esprit models has these for a good price too!
Hot glue... Stiff, not too sticky, dries fast... I think I might just try it!
OK How about the motor mount? I've sort of hacked my mount a little fitting different gearboxes and such. Doesn't really seem weakened but I guess it would be nice if it were easy to change out.
I epoxy'd the FR4 mount to the fuse and I'm guessing I really can never replace it because of that. Or is there some way to change it out? Should I have used some other glue?
Thanks again all!
Old Jun 21, 2005, 11:36 AM
BING! is offline
BING!'s Avatar
usa
Joined Mar 2003
If you really feel that you need to replace the motor mount, you might try what I did to another plane. I used a small chisel point hobby knife. Using a large handled screw driver as a mallet, I sculpted my epoxied horizontal stab off a plane. Worked really well and fast too by just hitting the glue joints which delaminated the epoxy from the glass.
N.B. I wouldnt do it if you didnt really have to as some of the gel coat will likely chip off on the outside of the fuse. Painting may be necessary.
Old Jun 21, 2005, 02:46 PM
PiNa is offline
Joined Jul 2004
These servo holders are also manufactured in CZ by RCM Pelikan (www.rcm-pelikan.cz) and the price here is around 2USD for pair.
Li-Ion Newbie - Enjoy Model charger query leccyflyer Batteries and Chargers 11 Oct 26, 2005 02:54 PM
Uh...need a little help. Maybe. Yet another XRB newbie thread... Harv Coaxial Helicopters 17 Apr 02, 2005 12:51 PM
Yippee! Hi- another XRB newbie stickyfingers Coaxial Helicopters 9 Jul 03, 2004 02:36 AM
Yet another Pencam Newbie BrentLA Aerial Photography 10 Oct 01, 2003 11:15 PM
Help! Another silly newbie problem dpc Micro Helis 3 Aug 08, 2003 11:33 AM
