Old Jun 14, 2001, 08:22 PM
spy0o7 is offline
Find More Posts by spy0o7
CharlieR
bay area, california
Joined Nov 2000
I.F.O. mach 3
I bought this plane today. Before I start building I was wondering if there are any building tips. Also will HS-81s work for this plane? Whats the best battery?
thanks
spy0o7 is offline Find More Posts by spy0o7
Old Jun 14, 2001, 09:12 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Build it just as the instructions say... make sure to have accelerator. HS-81's are WAY to heavy, go with 55's or better yet, 50's.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Jun 14, 2001, 10:19 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
Kingjamez,
Sure you aren't thinking of the mini IFO? My Mk3 can handle HS-81's. HS-50's would only work at lower speeds- there is a lot of elevon area. I tried comparable CS-10's and had slow response when flown outside.
SpyO07,
If you are using the speed-280 with Horst G.B. I like to use 9 or 10 280/300mAH NiMH cells. I have used AAA's and bigger cells, The IFO mk3 can handle a lot of weight, you trade vertical for duration.
Keith
KeithK is offline Find More Posts by KeithK
Old Jun 14, 2001, 11:07 PM
wowsers is offline
Find More Posts by wowsers
Vancouver,wa usa
Joined Mar 2001
one very important thing is, when you put the nylon tubeing on the trailing edge just before bending the bow around to glue it, do the following.
scotch tape the spacers to the trailing edge.
This way when the bow flys out of your hand, the spacers wont go flying all over the room.
I had to cut new pieces more than once.
wowsers is offline Find More Posts by wowsers
Old Jun 15, 2001, 05:25 AM
Joined Aug 2000
Yep, I'm sure I'm not thinking of the Mini. Every ounce counts on the IFO. Sure it flies better than most airplanes when grossly heavy. But when kept ultra light it flies better than EVERY airplane....well it at least goes vertical and smiles.
-jim
Old Jun 16, 2001, 12:17 AM
Randy S is offline
Find More Posts by Randy S
Professional Dork
Randy S's Avatar
Winchester, Kentucky
Joined Jul 2000
Be aware that measurements given in the instructions DO NOT match the plans. Use the plans to cut your tubing, not the written instructions.
Randy S is offline Find More Posts by Randy S
Sold "I.F.O." Mark 3 Aerobatic R/C Slowflyer Kit. metalbuggy Aircraft - Electric - Airplanes (FS/W) 3 Aug 12, 2006 11:41 PM
I.F.O." Mark 3 Aerobatic R/C Slowflyer jjbtlb Aircraft - Electric - Airplanes (FS/W) 0 Nov 22, 2004 08:32 AM
I.F.O. mark 3 pictures needed for assembly of motor mount and battery mount spy0o7 Electric Plane Talk 2 Jun 19, 2001 02:48 AM
Comp radio needed I.F.O. spy0o7 Parkflyers 5 Jun 18, 2001 04:25 PM
O.F.O. Randy S Parkflyers 9 May 30, 2001 07:05 PM
