Old Jun 17, 2005, 10:14 PM
timmus is offline
Find More Posts by timmus
Palestine, TX
Joined Dec 2004
Help newbie! SS propeller assembly
How does the propeller attach to the shaft on the GWS Slow Stick? Specifics: EP-400 motor, 1060 plastic prop. The instructions completely gloss over all this.
The prop has a hex recess on either side to accommodate a nut, and two nuts are packaged. Super. But then there's washers. Huh? If I try putting a washer on there, it will either block the hex recess on the prop, or it will be on the outside where it will either scoot back to the gearbox or fly off the front.
What is the correct order of assembly here?
Tim
timmus is offline Find More Posts by timmus
Old Jun 17, 2005, 10:26 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
One of the nuts is used to drive the prop, the other is to hold it tightly on the shaft. Which side of the prop (front or rear) it goes into is not important.
So..........Nut, prop, washer, (sometimes also a lockwasher), then the second nut in front tightens everything down.
Or...........Nut, washer(s), prop, nut. Tighten the nut behind the prop.
Popsflyer is offline Find More Posts by Popsflyer
Old Jun 17, 2005, 10:31 PM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
WHOA! What about a prop saver? No nut on the outside unless you like breaking props.
rutat is offline Find More Posts by rutat
Old Jun 17, 2005, 10:32 PM
Gamma is offline
Find More Posts by Gamma
Gamma
Gamma's Avatar
Newbury Park, CA
Joined Dec 2004
Hi Timmus:
1. Run one of the nuts on the shaft has far has it will go.
2. Slide the prop onto the shaft over the nut. Make sure the numbers are facing forward.
3 Put the washer on the front of the prop.
4. Pur an external toothed lock washer on next. It's not in the kit. I went to my local hardware store.
5. Run the last nut on the shaft and tighten.
6. Have fou with your SS
Gamma
Gamma is offline Find More Posts by Gamma
Old Jun 17, 2005, 10:40 PM
rutat is offline
Joined Mar 2004
Or better still...
1) Run nut to end of threads.
2) Put on washer.
3) Install prop saver
4) Secure with nut.
5) Cut shaft down to 3/16ths.
6) Install prop over last nut using rubber bads to prop saver.
Save props and enjoy.
Old Jun 18, 2005, 09:23 AM
timmus is offline
Palestine, TX
Joined Dec 2004
Thanks much! Now I need to search through the threads and find exactly what a prop saver is.
Old Jun 18, 2005, 10:41 AM
Oldie but goodie
Popsflyer's Avatar
Joined Jun 2003
Prop Saver?
Broken Props?
Old Jun 18, 2005, 04:32 PM
Jason Paul is offline
Find More Posts by Jason Paul
Jason Paul's Avatar
Joined Mar 2005
Yes, look through the threads on prop savers. Boomer just gave some quick but clear instructions today in the Ultimate SS Help thread.
It's pretty simple and very effective. I've flown my SS only 3-4 times. But, I've had the prop pop off of the plane at least 3-4 times on each flight. If I didn't have the prop saver, I'm convinced I would have broken at least 3-5 props by now. As it is, I haven't broken any.
Jason
Jason Paul is offline Find More Posts by Jason Paul
Old Jun 19, 2005, 12:13 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Unless you're using a prop saver, the correct sequence is:
1> Nut to end of threads
2> Washer
3> Prop
4> Nut
The front nut should key into the hex recess in the front of the prop. The torque of the spinning prop shaft will keep the nut tight and the prop itself becomes the prop wrench. If you have the ESC set to hard braking, the nut may come loose when the prop slams to a stop but unless the nut comes clean out of the hex recess, the freewheeling prop will reseat the nut and hitting the throttle will tighten it again.
Pete
PGR is online now Find More Posts by PGR
Old Jun 19, 2005, 12:52 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I always did it:
prop over nut
washer
other nut
The washer is there to prevent the nut from going in to the recess.
The front nut just holds the prop back against the rear one. All of the torque is applied between the rear nut and the prop.
There is no need for extra lock washers or jam nuts.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jun 19, 2005, 01:17 PM
Oldie but goodie
Popsflyer's Avatar
Joined Jun 2003
I honestly don't think it matters which way you prefer to do it. Either way seems to work just as well.
On my 3D plane with a 350 "C" ratio box, I installed the 1060HD from my 400 S.S. box. Found some little nylon bushing to adapt from 4mm shaft to 3mm and used a washer on BOTH side of the prop to lock it down. No vibrations and never came loose all the time I flew it this way.
Old Jun 19, 2005, 02:10 PM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
Originally Posted by pmackenzie
I always did it:
prop over nut
washer
other nut
That's how I used to do it too, and I had constant problems with props coming loose. Then I took the time to look at it from an engineering standpoint, started using the nut, washer, prop, nut method I already mentioned, and ceased to have problems with props coming loose.
And I always had a prop wrench.
A couple of months later I ceased using GWS gearboxes and props and a whole bunch of other problems went away too.
Pete
Old Jun 19, 2005, 02:26 PM
pmackenzie's Avatar
Joined Dec 2002
Pete
I guess there is more than one way to skin a Cat! I figured out mine from an engineering standpoint as well !
I never had any problem at all with the prop coming loose.
Pat MacKenzie
Old Jun 19, 2005, 10:04 PM
imjony5 is offline
Find More Posts by imjony5
Clarkston, MI
Joined Apr 2005
Or you could just not run into stuff, and cut power BEFORE you land. I'm still usind the original prop without a saver, with a few dozen flights or so on it.
imjony5 is offline Find More Posts by imjony5
Building from scratch-help a newbie LawnDart Electric Ducted Fan Jet Talk 19 Jan 12, 2007 12:55 AM
Wanna help with the SS newbie guide? Vanning Beginner Training Area (Aircraft-Electric) 0 Sep 07, 2004 02:43 PM
SS Propeller - Please help fastrak Aerial Photography 3 Sep 05, 2004 05:01 PM
Question Newbie need help with Slow Stick assembly CRABBYFLYER Beginner Training Area (Aircraft-Electric) 6 Apr 27, 2004 06:10 PM
Yippee! Soarstar please help newbie ElectricFlyer08 Parkflyers 7 Jan 01, 2002 06:54 PM
