Old May 19, 2007, 06:20 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
I thought of that somewhere in the middle of the field puffing toward the "landing site". Course that would have meant staring into the setting sun, but I would have lost it and found it sooner with probably less exertion!
springer is online now Find More Posts by springer
Old May 19, 2007, 06:54 PM
Prop stitches is offline
Find More Posts by Prop stitches
Prop stitches's Avatar
United States, WI, Avoca
Joined Dec 2003
Johnson Motors very cheap
You can buy johnson motors....there are three different rpm models, but they all look the same. Go to the website is: www.jameco.com/
This is harder than I thought, but it works, and it is worth it, the motors are only about a buck fifty each, and there are a million other motors you can look at too.
OK here goes: www.jameco.com you get the home page, click on Electro mechanical, then when new page comes up, click on Electric Motors, then on the next page, click on MOTORS, then click on Direct Drive, then you will have a chart with mostly just numbers on it. Just below that chart there are three choices in red..You pick the middle one..DISPLAY ITEMS..now you will have a list of motors and their specs, and manufacture. The johnson 280 is on that list.
What ever you do, once you get to this page, save this address to MY FAVORITES, and you don't have to go through this crap again.
I'm sorry I didn't get it right the first time, but I bought about thirty of the motors at various RPM's.
Prop
Prop stitches is offline Find More Posts by Prop stitches
Old May 19, 2007, 07:04 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Try that link again Prop...
didn't come through... or, tell us the keyword you searched on and how to find the motor on the website... I'm personally set, but I know many folks here still look for these motors.
-ms
msmith is offline Find More Posts by msmith
Old May 19, 2007, 08:26 PM
Joined Dec 2003
-ms
I just corrected my directions to the Johnson 280's .
Try my comments again.
Prop
Old May 19, 2007, 10:31 PM
brucej is offline
Find More Posts by brucej
Good glue is evil
melbourne australia
Joined Sep 2003
hey All
on another rcgroups thread they are talking about this jameco site for j250's
from the comments there " the site shows stock, but they are out ".
It may pay to check with them before you make the order, to save some heartache
Which one is the j280 from that big list ?
brucej is offline Find More Posts by brucej
Old May 19, 2007, 11:53 PM
msmith is offline
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Attn J250 Seekers... http://www.rcgroups.com/forums/showthread.php?t=688064
This guy has 6 for sale for $5.00
Someone should jump on this... I would if I didn't have a handful already...
-ms
Old May 21, 2007, 06:37 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
I'd really like to try the C-20 on a T-1 ... lighter than a j250 (easier balancing) and plenty of power with 3s ... better prop range too ...
gpw is online now Find More Posts by gpw
Old May 22, 2007, 09:02 PM
webdragon is offline
Find More Posts by webdragon
glider pilot in training
webdragon's Avatar
United States, AR, Searcy
Joined Aug 2006
My father wants to get into flying with my son and me So i have decided to build him a T1. He's never flown much more than a AA bipe so i feel it will be a good started for him.
After going through my spare parts i came up with a little 280 motor but the only prop i have on hand is a 5X5, Also i have a bunch of 900 mah triple A cells i make make him some 6 or 7 cell packs.
I can change the prop if needed but i am curious to if anyone has actually built one with a 280 yet.
webdragon is offline Find More Posts by webdragon
Old May 23, 2007, 07:31 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
Web , the 280 works , and you can run it on 3s , so a 7c nimh should be fine ...
Old May 23, 2007, 08:19 AM
magic612 is offline
Find More Posts by magic612
Bernoulli+Newton=Lift
magic612's Avatar
Somewhere south of Chicago, IL
Joined Jan 2006
webdragon - I built mine with a GWS 280 direct-drive motor on it. I decided to scale up the plans by 35% to account for the extra weight I knew I'd be dragging around with it, but I'm not sure that's entirely necessary either. I think my prop was a 5x3. For some pics of it, check out this thread:
http://www.rcgroups.com/forums/showthread.php?t=686476
magic612 is offline Find More Posts by magic612
Old May 23, 2007, 03:19 PM
webdragon's Avatar
Joined Aug 2006
i'll hit the hobby shop for a 5X3 prop this afternoon and get to building him his own T1.
might make myself a 1.5, my bp-21 is needing a good home and i want something to send a camera up on.
Old May 24, 2007, 06:26 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
The T-150% is really a large smopoth flier , perfect for AP .... It was proposed to build a 200% (T-200 I guess) to haul a 5 lb infared camera around...Hmmm??? Big motor ... Possible !!!
Old May 24, 2007, 08:48 AM
webdragon's Avatar
Joined Aug 2006
Uhm, What would be the wing span of a 200% sized monster?
Old May 24, 2007, 09:26 AM
tometech is offline
Find More Posts by tometech
Longmont Co.
Joined Jun 2003
I'm going to start my T1 and I was going to use depron. Which thickness would be most like the original plan and is everything single thickness? Also are there any videos of a T1? Thanks
Tom
tometech is offline Find More Posts by tometech
Old May 24, 2007, 10:26 AM
magic612 is offline
magic612's Avatar
Joined Jan 2006
tometech - Having used quite a bit of Depron over the last year, I'd suggest using the 6mm stuff if you are looking for some measure of less-than-ideal-landings-worthiness. Depron is lighter than most fan-fold foams (at least what I've measured), so even with a thicker material, your foam weight should be fine with the 6mm, and you'll gain a good measure of strength that way, too.
Discussion Trainer one with X-twin electronics tann200 Scratchbuilt Indoor and Micro Models 3 Aug 29, 2007 09:47 AM
