OK, 'nother question from a couple pages back. I understand the increase Throttle to gain altitude vs Elevator to change angle of attac, but not "Number two is to use the joystick to "Prop up" the low wing when it's coming toward you. " What does this mean?
Also, I just got my 3x3 props from FoamFly, and they are a really tight fit to the j250 shaft (like not going to go at all) What do you guys drill with? 5/64? any tips on how to hold it? |
Latest blog entry: OSE One Sheet Edge 540 Video
Just for fun, a couple days ago, I tried drilling out a prop from an ancient rubberband model. went right to 5/64, and it fit the 250 quite snug, unfortunately, it was a degree or so off true (only a couple of degrees!) and made the motor really vibrate at low speeds, so no joy. I like the idea of coming in from both side, also in the prior case, should have started with smaller bits and worked up. My drill press is also an antique radial (remember AMT in the back of Pop Sci?) and I don't think it's up to precision work. I think I'll try feeding the prop on the bit by hand from each end to insure i don't get sideways.
gpw, thanks for the explanation, I have found myself turning slightly while plane is coming toward me to insure i'm not backwards. I'll have to try the low wing method as soon as the snow melts (2"today!) and wind dies down (40mph with gusts to mach ?). I really enjoyed the Michigan summer last week, looks like an early winter though . . . . |
Drilling 3x3s
I drill with a 5/64 in my drill press...but when I'm in a hurry, I do it freehand (hold prop in one hand, drill in the other) and it still seems to work OK most of the time; if you drill slowly with a nice clean drill (one that's never been used on anything but props, NOT the one your kid used to try to drill through a stainless bolt!) it does follow the already-drill hole. Then again, I also order the 3x3s in packs of 10 so that mistakes don't cost me a day of flying.
As for prop adapters for the non 3x3s, I've had great luck with these: http://www.foamfly.com/product.php?p...&cat=23&page=1 They're cheap enough to be almost disposable, and if there's no oil anywhere on the shaft, etc., you can get away without glue (at least on a 4x2.5, for instance), so it's easy to trasnfer to a new motor/prop. I shove one end into the prop, and then press prop-and-adapter both onto the shaft, and it seems to work pretty well. --Spike |
| Thread Tools | |
| Discussion Trainer one with X-twin electronics | tann200 | Indoor and Micro Models | 3 | Aug 29, 2007 09:47 AM |
