Old Apr 19, 2002, 12:21 AM
D.FLinn is offline
Find More Posts by D.FLinn
London Ont. Canada
Joined Sep 2001
I need to find the CG for a swept wing
I have made a new flying wing and I need to find the CG.
The wing is as follows
Tip: 4.75
Root:11.25
Wing span:40"
total height18"
height to trailing edge 6.75
I hope this makes sense
Where is Sparky Paul when you need him?
Any help you have would be great.
D.FLinn is offline Find More Posts by D.FLinn
Old Apr 19, 2002, 08:33 AM
Flypaper is offline
Find More Posts by Flypaper
kingston Ont, Canada.
Joined Nov 2000
Might be a little hard to explain, but here goes. Take the root chord , add it to the tip leading edge. Take the tip chord, add it to the root trailing edge. Cross all 4 corners with a line. Where they cross in the middle is the mean aerodynamic chord or MAC. This is where you measure the CG from. On a flying wing the CG is between 15 and 20% from the leading edge.
Hop
this helps. If it needs more explaination let me know.
Flypaper is offline Find More Posts by Flypaper
Old Apr 19, 2002, 11:08 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
http://home.earthlink.net/~pjburke1/cg.htm
This locates the mac.
And I can't believe you haven't bookmarked the site!
For shame!
Sparky Paul is offline Find More Posts by Sparky Paul
Old Apr 19, 2002, 11:12 AM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Originally posted by Sparky Paul
. . . . For shame!
OK, it's bookmarked. BTW, most useful . . . . thanx
VP
Viper Pilot is offline Find More Posts by Viper Pilot
Old Apr 19, 2002, 12:30 PM
fregon45 is offline
Find More Posts by fregon45
Northern New Mexico
Joined May 2001
Here's one that you can use in Excel. It will also help in calculating the twist (or washout) for stable flight.
http://members.webpathway.com/patrul...ng_calc_1a.zip
fregon45 is offline Find More Posts by fregon45
Old Apr 19, 2002, 12:46 PM
D.FLinn is offline
London Ont. Canada
Joined Sep 2001
Thank you All
SP I know, I know.
You have have all been a great help!
Now do you include the control surfaces in these dimensions?
I haven't made them yet, still working out if I want them to taper
to the inside, or the outside?
Any advice?
Old Apr 19, 2002, 03:10 PM
coffey is offline
Find More Posts by coffey
Joined Feb 2002
I suggest going to http://www.b2streamlines.com/Panknin.html and downloading the Panknin twist spreadsheet. It'll tell you the twist and CG for a desired static margin among other things. Make sure you read the usage caveats. BTW, in a flying wing control surfaces are always included as part of the wing dimensions.
Elevons extending far inboard aren't nearly as effective as elevons that remain outboard. The inboard element makes the roll response sloppy. However, for ease of control surface hookup to the servo the surfaces are extended inboard so that the servo can be placed ahead of the CG.
As you get nearer the tip the control surface should be a larger percentage of the chord.
coffey is offline Find More Posts by coffey
Help! CG and a forward swept wing - need a little help sl33pdirt Slope 25 Dec 29, 2006 11:17 AM
Help , T-IFO , Need to find CG. jra111 Parkflyers 1 Mar 17, 2003 08:51 PM
help needed on CG for flying wing model bronco Power Systems 5 Apr 24, 2002 09:12 AM
How to get CG for a delta wing? (Mirage) GregG Power Systems 12 Dec 23, 2001 01:29 AM
CG for a rear wing/canard type model Jim McPherson Power Systems 3 Oct 03, 2001 09:06 PM
