Old Jun 16, 2005, 01:53 PM
ORLIK is offline
Find More Posts by ORLIK
ORLIK's Avatar
Stork 2 Pro - how to instal 10 cell pack (akku.)
Hallo,
I am looking for input from other modelers how they instal batter packet in their big electric moto gliders like Stratos or Stork 2 Pro or Elipse. Especialy I am interested in those big 10 -14 cell packs? For up to 6-7 cell I used velcro but 10 -14 cell packet is heavy and shifting packet will affect C.G. of the model so accident is possible.Please advise , How you secure it ,so it will not move back and forth? Do you build plywood try or not?
Any comments or pictures will be greatly appreciated.
Thank you in advance.
ORLIK is offline Find More Posts by ORLIK
Old Jun 16, 2005, 05:11 PM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
I used a plywood tongue with velcro running its length. Holds 10xgp3000 or 14x2200 with no issues in 18 months flying.
davidleitch is offline Find More Posts by davidleitch
Old Jun 16, 2005, 06:43 PM
ORLIK is offline
ORLIK's Avatar
Stork 2Pro -how to install 10 cel akku. pack
Hallo Dave,
Thank you for quick reply.Have you glued tonge in the fuslage permanently or can you remove it together with motor in nose cone? Also, is it level or at angle? For instance in Elipse 4 you can slide in and out whole nose cone with motor ,esc and akku try which come in one piece from factory and akku sits verticaly instead of horizontal position. (quiet simle and quiet good idea by Jaro Muller.)All you have to do is , just put hard foam between motor and akku and you are set to go.
Old Jun 16, 2005, 07:49 PM
flyingdogtwo is offline
Find More Posts by flyingdogtwo
.Denver, Co.
Joined Feb 2003
I use both the 7-cell & 10-cell in my graphite using the tongue method. I also run a little FG tape around the cells, besides velcroing them to the sticks. Securing the tongue in the fuse with bolt/blind nut.
flyingdogtwo is offline Find More Posts by flyingdogtwo
Old Jun 16, 2005, 09:10 PM
Tragic case
Sydney Australia
Joined Feb 2002
Mine is glued in. The plywood is bevelled at the sides to make it fit flusher with the fuselage. It works but its fairly fragile and far from artistic.
See this thread for a photo and a better way to do it.
http://www.rcgroups.com/forums/showthread.php?t=184553
FS: Sanyo 2600 NiMh, 10 cell pack with 2 extra cells Balin Aircraft - Electric - Airplanes (FS/W) 0 Jan 29, 2003 06:18 PM
CP-2400SCR 10 cell pack will not fast charge? rsieminski Power Systems 8 Jan 05, 2002 04:39 PM
What charger and 10 cell pack Brett Electric Heli Talk 1 Oct 29, 2001 05:52 PM
I want a 10 cell pack for my speed 400 e-sailpilot86 Power Systems 3 Oct 21, 2001 11:25 AM
Voltage of fully charged 10 cell pack? dvint Sport Planes 2 Oct 07, 2001 11:22 AM
