Old Jun 15, 2005, 08:32 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Foamie Flying Boat Design Group...
Seems like the flying boat is all the rage now , lots of folks begging for plans .... So why don't we make a list of the parameters and design a few of our OWN flying boats .... Let's learn what works and what doesn't ... and by combining our ideas/experience , we can develop a better looking/flying /building vehicle , schmaybe' even apply it to some full scale stuff.... wouldn't you want to pilot your own flying boat ????? We have the resources , just need to hear from you guys .... all ideas /designs gratefully accepted ...
gpw is online now Find More Posts by gpw
Old Jun 15, 2005, 08:38 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
First, I'd like to comment on the sponson design .... being an old boat guy from way back on the bayou , I really believe that slanting the botton surface outward and UPward would not only get the hull out of the water quicker , but would even add a small dihedral effect to the flying qualities ... a "stepped" sponson would be even better ... look at some real boats .... same thing ...
Old Jun 15, 2005, 08:53 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Glen: Is there an optimal amount for the "dihedral"? I'm thinking about 10° on each sponson myself.....I'm doing my own version 2.0 right now, but I'll hold off until there's an answer to this one...V2.0 will have an airfoil for the deck - gonna use ~2mm / 3/32" foam for the skin (I strip my own foam).
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jun 15, 2005, 08:55 AM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
I agree with GPW.
jforkner is offline Find More Posts by jforkner
Old Jun 15, 2005, 09:00 AM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
I have Proper's boat printed out and ready to cut but maybe I can incorporate this into his. I'll look at the plans tonight and see what I can do to make some changes.
TM
JAM is offline Find More Posts by JAM
Old Jun 15, 2005, 09:03 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
A&S... There is always an optimal amount , but unfortunately , I don't know it , but I'll bet someone out there does and would be willing to disclose such an obviously secretive amount .... Meanwhile , back at the docks , we could try different things ... the principle is : as the sponson rides through the water , the faster it goes the higher the hull rises in the water , resulting in less "wetted-area" and therefore less DRAG , resulting in more speed , etc, and eventual take off .. That's the principle .... you can see a flat bottomed sponson has a flat wetted area that must drag across the water like a flat bottom boat ...
You can see why a stepped sponson is a better compromise ... the faster you go , boat hull rises one step at a time ... till...
I think we need to establish some proportions , to enable us to build bigger or smaller ones ( I have some old Astro cobalt motors which I wouldn't mind dunking ....) Like an aspect ratio .... 3/1 , 4/1 , the Biblical 6/1...????
Old Jun 15, 2005, 09:06 AM
Joined Dec 2003
Well, it looks like 1:1 for wing loading, or about 3:2 (L:W) if'n looks are more important....
Brad
Old Jun 15, 2005, 09:20 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
A&S, Please explain .... I was thinking more graphic like this ...<> , < >, < >, < >...???? Hmmm that was vague .... how about considering the vessel/ aircraft is currently like three squares laid end to end , with the first square mostly missing (canard as planes see it ) ....
we know too long doesn't handle well (rolls too easy ) and too wide looks like a floating /flying picnic table .... so 1 square (1:1), 2 squares (2:1) , 3 squares (3:1)... sorry about being so anal about this ,I'm just trying to get on the same page with our "terms" ... Thanks !!!
Tow , try cutting 1/4"(or so ) off the outside sponson wall bottom so the bottom will rise towards the outside , that should work .... Please keep us posted as to the progress....
fork , thanks !!!
Old Jun 15, 2005, 09:39 AM
Dongledell is offline
Find More Posts by Dongledell
and this wire goes where?
Southampton Eastleigh, Great Britain (UK)
Joined Jun 2003
I have no idea what a sponson is (sorry! ), so I may be way off mark, but I'm thinking you mean the bit that sticks into the water like twin boat hulls?!
If so, have a search about for info on "water aircraft floats" on google - I'll see if I can dig it back up later but a while back I found some very useful links n stuff on calculating the stepping etc.
Dongledell is offline Find More Posts by Dongledell
Old Jun 15, 2005, 09:45 AM
Joined Dec 2003
sponson = "pontoon" I'm thinking if we're doing boats, we should probably use the right terms......then other people will think we know what the heck we're talking about
Brad
Old Jun 15, 2005, 09:46 AM
Joined Dec 2003
I was just thinking; there's no reason we have to limit ourselves to a tunnel hull type boat. What about an outrigger?
Brad
Old Jun 15, 2005, 09:50 AM
Joined Jun 2003
LOL I've always failed when I try that approach, so I prefer to admit stupidity now
Only thoughts on the tunnel hull type is it's very easy to make it look like a boat rather than a plane, other designs will probably end up looking more like planes modified to go on water.
Just been having a look for that info on the stepping, cant find it here, might be at home though.
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
A&S,That would be a FIRST !!!!hahahahahaha
Dongle dingle dangle ole' biscuit barrell of Ulm , Sorry Eastleigh .... the outer bits that rest in the water and preceed the rest of the boat ... The real trick is making it look like neither boat ,nor plane .... what about that one ...???
Old Jun 15, 2005, 09:53 AM
Joined Dec 2003
Ailerons on the outriggers??? Hmmmm....
Brad
Old Jun 15, 2005, 09:56 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
I think we should keep it simple at first , before we go creative....
"SKUNKWORKS"...Unlimited Foamie Design Group gpw Foamies (Scratchbuilt) 406 Sep 16, 2009 01:06 PM
FOAMIE F-22 Raptor COOP Design Group meeting -> gpw Foamies (Scratchbuilt) 540 Jul 28, 2008 10:48 PM
The Skimmer, a Depron foamie indoor/park flying boat Thomas B Foamies (Kits) 11 May 21, 2004 06:24 PM
new flying boat design Kuni Scale Kit/Scratch Built 7 Mar 28, 2004 05:10 AM
Flying Boat Design... Where to start? All_talk Waterplanes 3 Nov 05, 2003 12:31 AM
