Old Jun 14, 2005, 09:36 PM
Dunqun is offline
Find More Posts by Dunqun
rational exuberance
Dunqun's Avatar
USA, CA, Castro Valley
Joined Aug 2003
Rodent R3 - Build Thread
Well I was reading all of Steve's threads about the Rodents...
Higgins
Steve's OR
And then I went back and watched "Lift Ticket" again and I said, I gotta get me one of those!
I decided on the R3 because I think the beefier fuse will allow easier installation and access to equipment, and well, just to be different. So I emailed the man himself, turned out he had an R3 kit available and ready for shipping. Everybody seems to want the classic, legendary, awesome looking original Rodent. Go figure!
So a paypal and a couple business days later, here I am ready to build!
Since I've never sheeted wing cores before, or built a plane like this, I'm doing a build thread mostly to help myself out. There will be more questions asked than answered, so don't hold back with the criticism, I want this thing built right!
First off, I have this epoxy I'd like to use to sheet the wings. I've had good results with it on other things and I have a bunch of it! So somebody tell me if something else would be better.
-Duncan
Dunqun is offline Find More Posts by Dunqun
Old Jun 14, 2005, 09:45 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
That IS epoxy and not polyester resin, right? the poly will eat the cores is why I ask.
Well, get to building!!!
InTheLift is offline Find More Posts by InTheLift
Old Jun 14, 2005, 09:48 PM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
I got an R-3 too. Love that beefy fuse.
slopemeno is offline Find More Posts by slopemeno
Old Jun 14, 2005, 09:50 PM
Bill L is offline
Find More Posts by Bill L
Bill L's Avatar
San Diego
Joined Apr 2003
label says epoxy system........tsssssss
b
Bill L is offline Find More Posts by Bill L
Old Jun 14, 2005, 09:55 PM
Dunqun is offline
rational exuberance
Dunqun's Avatar
Joined Aug 2003
Well, I hope it is, I didn't know about poly and blue foam. They have a different line of "Polyester Resins."
Bill, I hope "tssssss..." isn't the sound of my cores melting?
Here's from the Tap Plastics website, looks like I'm ok, is epoxy and contains no solvents:
Tap Epoxy
Old Jun 14, 2005, 10:00 PM
this space for rent
slopemeno's Avatar
Joined Jan 2003
Thats the super-hard 4-into 1 system? I had ok success with it a few years ago on a set of wings, but I didnt mix it well enough so I had a spot where the sheeting lifted.
I plan on using Polyurethene on mine, probably probond. Make sure and reinforce the "ramp" ahead of the wings leading edge. Uh,..."if" you stick the nose in on a landing, and the wing pops the bolts and goes foreward, a layer of heavy glass and 1/8th ply inside the ramp will help preserve the fuse. Youre going to love how they fly. I flew mine last monday afternoon at Tick and it was great. Huge carving maneuvers, lots of vertical pop, loooong slow rolls. I had the slope to myself and it was amazing.
Old Jun 14, 2005, 10:04 PM
Dunqun is offline
rational exuberance
Dunqun's Avatar
Joined Aug 2003
No, this is the Marine Grade Epoxy system, I see the superhard is a different product.. I hope to avoid Probond because I used it on a foamy a while back and warped the foil.
Sounds like a winner of a plane, can't wait! I wish I had it today at Coyote hills, wind was a tad high for the Banana. Still flew great, but I was wishing for something heavier.
Thanks for the help,
Duncan
Old Jun 14, 2005, 10:06 PM
Dunqun is offline
rational exuberance
Dunqun's Avatar
Joined Aug 2003
Well what the hay, I'll slather some on some on the scap foam that came in the box and see what happens
Old Jun 14, 2005, 10:07 PM
Harry S. is offline
Find More Posts by Harry S.
Pacifica, CA
Joined Jun 2004
I really like the Tap Marine grade epoxy. I like the viscosity of this resin, it seems to wet out cloth better than West System or EZ Lam. I personally use the fast hardener because it yields a harder surface finish.
Harry
Harry S. is offline Find More Posts by Harry S.
Old Jun 14, 2005, 10:11 PM
Dunqun is offline
rational exuberance
Dunqun's Avatar
Joined Aug 2003
Harry
I did notice that the end result remains flexible, will this be an issue with skinning the cores? No big deal to pick up some fast hardener.
Duncan
Old Jun 14, 2005, 10:57 PM
Dunqun is offline
rational exuberance
Dunqun's Avatar
Joined Aug 2003
Ok, I got a pretty basic question not covered in the instructions:
Do I sheet the wing halves separately, then join them? If so how do I join them? Should I install a spar? As I recall, the Art Hobby planes don't have a spar, you just wrap some glass around the wing saddle to join the halves.
Duncan
Old Jun 14, 2005, 11:02 PM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
No spar necessary. Sheet them separately, shape the LE on each panel, then join them with some heavy fg cloth tape or a couple of layers of heavy cloth.
Reed is offline Find More Posts by Reed
Old Jun 14, 2005, 11:05 PM
Reed is offline
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Duncan
The resin should not remain flexible. Check your mixing, be sure it's exactly 1 to 1. You may need a warmer workshop to kick this stuff. I've had this same issue with this brand and I haven't quite figured out why. Sometimes it kicks perfectly and sometimes is stays gooey.
Old Jun 14, 2005, 11:20 PM
Dunqun is offline
rational exuberance
Dunqun's Avatar
Joined Aug 2003
Hmmm...maybe I'll pick up some fast hardener tomorrow. Have you used the slow or fast hardener with this brand? It says 2:1 resin to hardener, I measure it, not just eyeball it, but I'll be careful.
Thanks for the wing joining tips, sounds easy enough. Do you put any wood blocks inside the wing saddle for the bolt holes?
-Duncan
Old Jun 14, 2005, 11:39 PM
this space for rent
slopemeno's Avatar
Joined Jan 2003
Blocks in the wing root for the bolts is a great idea. The wing bolts take a pounding in these things.
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Build Log Rodent Build Thread matter_daddy Slope 22 Mar 06, 2007 07:12 PM
Build Log '"Rodent Build Thread" wackyd Slope 33 Feb 07, 2006 04:19 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
