Old Jun 14, 2005, 05:05 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
ECO 8: keep breaking Head bolt (jesus bolt) and Phx 45 start up problem?
I have my brothers Eco 8 for trimming and tunning. I have the latest Phx software 1.14 installed on the Ph45 in gov mode and start up set at softest. When I spool up it does a quick "jerk" and then spools up slowly to set throtlle setting of 90% before switching to idle 1 of 90%.
I would assume that the head bolt is breaking due to the start up problem.
Any thoughts/help?
UAVProducts is offline Find More Posts by UAVProducts
Old Jun 14, 2005, 08:07 PM
DavidB. is offline
Find More Posts by DavidB.
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
The head bolt is garbage. Replace it with something harder and you shouldn't have problems.
DavidB. is offline Find More Posts by DavidB.
Old Jun 14, 2005, 08:53 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Any thoughts/help?
I'll bet you have a Mega 22/20/3H.
I reported this problem to Castle Creations many times in the past, went through about three firmware versions waiting for it to be fixed, was never fixed, so replaced it with a Schulze 18.46k.
This was three years ago...looks like they still haven't fixed it.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jun 14, 2005, 09:11 PM
Joined Mar 2004
I'm running a Hacker B50 14L. I switiched to fixed throttle and didn't change any other settings and I do NOT get the 'jerk".
So it has to do with the Gove mode.
Old Jun 14, 2005, 09:33 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
I couldn't get mine to stop the "jerk startup" (Px-45) until a softened the throttle curve on the low end, now it starts very smooth. But I'm using fixed throttle mode.
Art Newland is offline Find More Posts by Art Newland
Old Jun 15, 2005, 09:09 AM
Joined Mar 2004
I guess I will just have to set it at Fixed pitch. In Gov mode the startup is so violent that it eats the main gear and breaks the bolt. Its to bad I really wanted to use Gov mode.
I'll just set the TC at 100 95 90 95 100 in idle 1
Norm will be 0 inn 90 90 90
Old Jun 15, 2005, 12:34 PM
Chachin is offline
Find More Posts by Chachin
Powered by ThunderPower
Chachin's Avatar
United States, FL, Cocoa
Joined Sep 2001
Hello, it sounds like you guys need some Kontronik ESC's . They're as smooth as they get in soft starts and just about everything else. I've used the garbage bolt together with this ESC and never broke it during start up.
When I first started though I had a real violent JetiESC/Phasor combo. My fix was to spool up the blades by hand (just a bit) and then start up the throttle. Much better; should work with your CC too.
Good luck!
Chachin..
Chachin is offline Find More Posts by Chachin
Wanted Ikarus ECO 8 Red Aluminum Head Spidious Aircraft - Electric - Helis (FS/W) 0 Jul 10, 2007 10:36 PM
Sold IKARUS Eco 8/16 alum head and swash w/ hardened shafts on E-bay litespeed Aircraft - Electric - Helis (FS/W) 0 Mar 12, 2006 07:43 AM
Dragonfly - Keep breaking head links Shanman3us Micro Helis 4 Jun 08, 2004 12:59 AM
Eco 8 rotor head bolt P-bar Electric Heli Talk 4 Apr 12, 2004 08:59 AM
Eco 8 max rotor head speed BillH Electric Heli Talk 2 Mar 02, 2002 11:40 PM
