Old Jun 12, 2005, 02:07 PM
PrOtRoN is offline
Find More Posts by PrOtRoN
Trainer Pilot
PrOtRoN's Avatar
fl
Joined May 2005
Guillows P-51 900 series conversion
just buaght all the stuff i need for my kit
PrOtRoN is offline Find More Posts by PrOtRoN
Old Jun 12, 2005, 02:52 PM
steelfaith1 is offline
Find More Posts by steelfaith1
texas
Joined Oct 2003
cool, whats the wingspan on that mustang?
thanks
steelfaith1 is offline Find More Posts by steelfaith1
Old Jun 12, 2005, 02:58 PM
PrOtRoN is offline
Trainer Pilot
PrOtRoN's Avatar
fl
Joined May 2005
17 inches
im thinking about adding rudder to it im not sure... ground take offs might be cute
Old Jun 12, 2005, 03:09 PM
speeddemon281 is offline
Find More Posts by speeddemon281
Food For The Maggots
speeddemon281's Avatar
New Waverly,Texas
Joined May 2004
oh man,those kits are soooo damn fun to build. Im only 16 now,but man when i was 12 I had so many of those!!! These are awesome,I have also thought about doing this,and putting a IPS brushless in one.
speeddemon281 is offline Find More Posts by speeddemon281
Old Jun 12, 2005, 04:48 PM
PrOtRoN is offline
Trainer Pilot
PrOtRoN's Avatar
fl
Joined May 2005
when i was purchasing the motor and prop i thought that the prop was too big for that size airplane, 10x5 prop, and the plane is only 17"!!! could i get better proformance with a different prop?
8 x 4 Direct Drive Black Electric Propeller (EP-8040)
or
3-Blade 9 x 7 Black Electric Propeller (EP-9070x3)
a scale prop is about half the size as the one the specialist gave me a my lhs.
Old Jun 12, 2005, 05:44 PM
Whacky is offline
Find More Posts by Whacky
Netherlands
Joined Jan 2005
Hi PrOtRoN,
Nice plane u bought, i'm almost finist mine today .
Just need to glue the upper stringers in the wing and fuse. And i need to make some hinges.
I was planning on making mine Rubber powerd with the rudder/elevator controled with bitgear. I want to use the rubber to take it up and control the glide back down.
One thing i dit was using lighter balsa, the stuff supplied was like hardwood so i used these as templates.
Here are some pics of the almost finist framework 10g with canopy
Good luck on your build.
Mark.
Whacky is offline Find More Posts by Whacky
Old Jun 12, 2005, 07:50 PM
PrOtRoN is offline
Trainer Pilot
PrOtRoN's Avatar
fl
Joined May 2005
nice pics
i was surprised by how the airplane came in the box. the rubber bands and prop wasnt in the lil plastic bag and they fell out first. i saw only 3 sheets of balsa wood. and then i stood over the table and thought that the box was messed up and i was missing a sheet of balsa. but no 2 sheets were the body and the wings were on the other sheet.
2 sheets of the balsa wood are thin and light, the other is heavy and thick. im going to dope the whole plane when finished for some strenght
but to know that your airplane in the pictures weigh 10 grams is great!
the weight that i thought the plane was gonna be was at most 28 grams, covered and doped,
plane - 28g
motor - 23 g
rx - 10 g
2 or 3 servos @ 6.5g each
battery - 15g
esc - 6
my total is about 95 grams
right now im trying to figure a way to mount the motor, there is no cowl to this kit so im puting the motor in after my 2nd step. here is some pictures of what im doing
Old Jun 12, 2005, 08:24 PM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
check out this thread.
http://www.rcgroups.com/forums/showt...=paul+bradley+
a plane like that deserve a good covering job and paul bradley has the way to do it!!
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Jun 12, 2005, 09:29 PM
Matt D. is offline
Find More Posts by Matt D.
Matt D.'s Avatar
Greensboro, NC
Joined Jul 2002
I think your plane will be most difficult to fly with that huge prop and gearbox.
Too much torque on too small an airframe. Take that motor out of the gearbox, pull the pinion gear off the motor and put on a gws 3x2 press on prop.
What battery? An e-tec 250?
Matt
Matt D. is offline Find More Posts by Matt D.
Old Jun 13, 2005, 08:27 AM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
plane - 28g
motor - 23 g
rx - 10 g
battery - 15g
esc - 6
Protron,
It would serve you well to read and really digest this thread:
http://www.rcgroups.com/forums/showthread.php?t=308433
The planes being built are about 17". There is much detailed info on equipment and weight. Most of the planes are comming in less than half the weight you are estimating. At 95 grams, or anything close to it, I think you are setting yourself up for dissapointment. There is nothing wrong with your equipment, but the plane you have picked is way too small to give a reasonable wing loading IMHO.
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Jun 13, 2005, 09:00 AM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hey Whacky, ziet er erg goed uit!
Kun je misschien even doorgeven wat het gewicht is als hij klaar is (met verf & bespanning, maar zonder elastiek).
Greetz,
Dave
RNAF is offline Find More Posts by RNAF
Old Jun 13, 2005, 10:26 AM
Whacky is offline
Netherlands
Joined Jan 2005
Greetz,
Dave
Zie PM,
Mark.
Old Jun 13, 2005, 04:58 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
..something about a good finish and can you tell me what the finished weight is covered and painted but without the elastic.....
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 13, 2005, 05:50 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Alot better than any of the online translators I tried.
Makes me want to quote Samuel L. Jackson in Pulp Fiction.....
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jun 13, 2005, 10:13 PM
PrOtRoN is offline
Trainer Pilot
PrOtRoN's Avatar
fl
Joined May 2005
its an electricfly 2s 340 mah lipo battery, im not sure but i think the its got a safe chip in it that saves it from explosion?
i got some balsa wood and some plywood for the servos and motor mount,
plywood is great, super thin and fits in place nicely. plywood is use for strength.
i also baught a 5x5 prop. i tried the motor out with the new prop and it has decent amount of thrust where its jsut pulling out of my hand. my dad said use the stock prop its got more pitch! so i tried it and it was pulling out of my hand so much it would take off with the wings on. so i think im gonna use the stock prop, too bad i only have the one that came with the kit and another from a stuka kit. by the way the stuka is way too small to convert, i dont know how the member here did it.
i will post some pictures of what i did today but it has gotten late. i got work tommorow so that will be the first thing i do after work.
oh yeah we had a crash today, 1 casualty... only me and my father have survied the crash.
Guillows P-51 conversion SnoJetter Parkflyers 51 Jul 05, 2012 11:16 PM
Build Log Guillows P-51 Mustang Conversion InaneCathode Scale Kit/Scratch Built 40 May 31, 2006 08:53 PM
Guillows P-51 conversion flight video! SnoJetter Scale Kit/Scratch Built 14 Mar 16, 2003 02:23 PM
Guillows P-51 conversion flight video! SnoJetter Parkflyers 19 Mar 12, 2003 03:15 PM
Guillows P-51 conversion SnoJetter Scale Kit/Scratch Built 5 Mar 03, 2003 12:23 AM
