This thread is privately moderated by ildo, who may elect to delete unwanted replies.
Old Jun 12, 2005, 08:20 AM
ildo is offline
Find More Posts by ildo
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
For Sale
FS: Brand new Feigao brushless 12mm IPS motor & 10 am ESC Combo
Feigao 1208425L 12x30mm Brushless IPS Motor
Features:
Mini size brushless motor, ideal for upgrade from brushed motor to brushless motor, for some light model plane.
Light weight, powerful and ideal for light model plane upgrade.
Specifications:
Shaft size:1.5mm
Weight:17g(0.60oz)
RPM/V:5800
Internal Resistance:0.6ohm
Without load:0.2A
10AM ESC
Features:
Very light (7g including wires & connector).
Specifications:
Type Current FET Qty BEC Timing PWM Li-poly Ni-Mh
10-N 10A/13A 6 1.5A Auto
8K 2 or 3 cells 4-12 cells
1.Extremely Low Resistance
2.High rate PWM)
3.Sixteen cells MAX (with BEC disabled)
4.BEC (1.5A/4A) provides power to receiver and servos -
5.User Programmable Features:
Low-voltage cutoff ( 2cells or 3cell LI-PO auto setting)
Brake
Throttle Range self-adjusting
6.Soft Start ramp up
7.Runs motor in forward /reverse
8.Auto Motor Cutoff with Reset
9.Safe power on arming program ensures motor will not accidentally turn on
10.Low torque soft start.
11.Auto shut down when signal is lost or radio interference
User guide:
1.The main power cable can maximum of 20 cm length.
2.It is recommended to solder the cables directly to the power pack.
3.Plug the JR connector into the receiver throttle channel.
4.If using micro servos, it is necessary to reduce the number of servos by one.
Installing procedure:
1.Attach the motor to the motor mount with the screws provided.
2.Main power packs should be connected at one attempt. Avoid multiple touches of the connectors.
3.Power on the transmitter and check the throttle channel travel settings are +/-100% (for computer system radios.)
4.Power on the speed controller .
You must hear one 'beep'. Between switching on and hear the 'beep' the throttle stick must not be moved .If you do not hear a 'beep', power off the controller, and wait for 5 seconds then repeat the procedure again .
5.The position of 'full throttle' will be adjusted automatically.
6.The speed controller is 'brake' activated initial.If you want to turn off the brake ,you have to :
- Switch on the transmitter and move the stick to 'full throttle'.
- Connect the power pack and turn on the receiver switch .
- Wait 5 seconds.
- After 5 seconds you will hear 4 tones.
- Move the throttle stick fast to the 'stop' position; you will hear two 'beeps'.
- The 'brake' is now turned off.
7.If you want to activate the brake again, repeat step '6' again.
8.Only have to exchanging the position of any two wires connected to the motor then you can reversing the motor .
RC Group special price: US$60 shipped
we also sell apart.
Motor: US$43 shipped
ESC: US$22 shipped
Our paypal account: leo_523@hotmail.com
other items on sale now:
Brand new TowerPro Outrunner brushless motor & 18A ESC for Li-Poly Combo
New EP Li-Poly Battery 1800mah/11.1V/3-Cell
Brand new TowerPro SG50(5g) & SG90(9g) micro servo
ELE EBMC 2830 1030KV Outrunner Brushless Motor
ildo is offline Find More Posts by ildo
Old Jun 12, 2005, 01:02 PM
flyerbob is offline
Find More Posts by flyerbob
Trader Rating: 97
USA, AK, Soldotna
Joined Jul 2002
Trader Rating: 97
PM sent with offer and question
Bob
flyerbob is offline Find More Posts by flyerbob
Old Jun 12, 2005, 01:15 PM
roccobro is offline
Find More Posts by roccobro
Trader Rating: 20
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Trader Rating: 20
Is there more than one of these for sale? I might know somebody whose interested, the whole Nano EDF crew!
Justin
roccobro is offline Find More Posts by roccobro
Old Jun 12, 2005, 01:18 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
Justin
sure, we have bunch of them in stock.
just got them from the China manufacturer yesterday.
Old Jun 12, 2005, 01:22 PM
chris-miranda is offline
Find More Posts by chris-miranda
Trader Rating: 17
registered republican
chris-miranda's Avatar
In a van, down by the river
Joined Oct 2002
Trader Rating: 17
ildo where are these being shipped from and what brand is the esc?
chris
chris-miranda is offline Find More Posts by chris-miranda
Old Jun 12, 2005, 01:34 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
will ship from Texas,
the brand of the ESC is Feigao too.
chris
Old Jun 12, 2005, 02:17 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
Bob
thank you Bob.
payment received.
will ship it asap.
thanks
XUS HOBBY
Old Jun 12, 2005, 02:19 PM
Trader Rating: 17
Joined Oct 2002
Trader Rating: 17
ildo do you have any of the 4100 kv?? feiago motors
Old Jun 12, 2005, 02:23 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
no, I am sorry.
that's the only model I have right now.
but we will import more next time.
Old Jun 12, 2005, 02:45 PM
Shogun is offline
Find More Posts by Shogun
Trader Rating: 54
Shogun's Avatar
Joined Jul 2004
Trader Rating: 54
Will this ESC work with cdrom motors and 8-pack AAA NiMh batteries? If so I am interested in 1.
Thanks.
-Shogun.
Shogun is offline Find More Posts by Shogun
Old Jun 12, 2005, 03:03 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
Thanks.
-Shogun.
yes, I think you can.
here is the Specifications:
10-N 10A/13A 6 1.5A Auto 8K 2 or 3 cells 4-12 cells
Old Jun 12, 2005, 03:04 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
sorry, the brand of the ESC is TowerPro.
Old Jun 12, 2005, 11:30 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
sale will last until cancelled.
Old Jun 13, 2005, 01:15 PM
ildo is offline
Trader Rating: 67
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
Trader Rating: 67
anyone?
Old Jun 13, 2005, 03:01 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Trader Rating: 36
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Trader Rating: 36
I've searched and cannot find performance numbers for
this 5300Kv motor on DD with a 3030 prop.
Can you provide??
Volts holding, Amp draw, thrust oz, pitch speed
fb
fly_boy99 is offline Find More Posts by fly_boy99
Sold For Sale: New Feigao brushless 12mm IPS motor & 10 am ESC Combo Tiger moth Aircraft - Electric - Airplanes (FS/W) 1 Aug 05, 2005 04:17 PM
For Sale For Sale: New Feigao brushless 12mm IPS motor & 10 am ESC Combo ildo Aircraft - Electric - Airplanes (FS/W) 21 Jul 21, 2005 05:40 PM
For Sale FS: BRAND NEW FEIGAO 1208425L 5866kv 12x30mm Brushless Motor ildo Aircraft - Electric - Airplanes (FS/W) 1 Jun 28, 2005 05:24 PM
Brand New! Feigao 12 Mm Ips Replacement Brushless Motor crudpuppy Aircraft - Electric - Airplanes (FS/W) 10 Feb 06, 2005 07:18 PM
brand new Feigao brushless motor (ips replacement) $35 shipped, PHoenix 10 $45 shipp Astro30 Aircraft - Electric - Airplanes (FS/W) 5 Oct 20, 2004 08:09 PM
