Old Jun 11, 2005, 11:37 AM
GeorgeZilla is offline
Find More Posts by GeorgeZilla
GeorgeZilla
GeorgeZilla's Avatar
Spring Valley, CA
Joined Mar 2005
Yippee!
Red, White and Blue F18
Hi folks,
HELP!! I overcharged my battery and now it has swollen by 1/2 its size. Can I still use it?
SPECS: Dimensions - as per 3D Foamy plans
Motor - GWS 350C, 5:33:1 gearing
EZ-Sky aileron micro servos
Elevator servo - HITEC HS60
Airtronics VG400 transmitter/Reciever
KOKAM LiPo 11.1 volt, 1500mah battery
Material - WalMart 5mm, Blue Sturdyboard
3D Foamy Jet kit...carbon spars etc
Canopy - 3D Foamy
Hinges - DuBro barbs (excellent!!)
Prop - GWS 8X6
GeorgeZilla
GeorgeZilla is offline Find More Posts by GeorgeZilla
Old Jun 11, 2005, 11:59 AM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
Stay cool!
Donīt do much movements on the sticks!
Let her fly!
:-) Hans-Joachim
Full throttle Launch straight!
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Jun 11, 2005, 12:05 PM
GeorgeZilla
Spring Valley, CA
Joined Mar 2005
Originally Posted by Hans-Joachim
Stay cool!
Let her fly!
:-) Hans-Joachim
Thanks Hans!!
Old Jun 11, 2005, 12:10 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
First of all, I'd recommend shimming that motor to remove the up thrust angle--that will lead to all sorts of problems trimming this airplane since it will cause thrust-induced pitch changes. This model needs NO up thrust or down thrust for best results.
That said, you'll find that when set up per the plans (CG, weight, and control deflections) this model is surprisingly sedate during launch. The most important thing to remember is to launch at HALF throttle so that it doesn't torque roll at launch. Throw the model firmly and smoothly at a slight nose up angle (maybe 20 degrees up) and it should fly off smoothly in a gentle climb. If you throw it hard enough it won't drop at all after launch. Bring the throttle up to full soon after launch, get it up to altitude, and then trim it out.
Good luck!
Steve
jetset44 is offline Find More Posts by jetset44
Old Jun 11, 2005, 12:18 PM
GeorgeZilla
Spring Valley, CA
Joined Mar 2005
Good luck!
Steve
Thanks for the advice Steve. I'll shim the motor. Flight time - T minus 3hrs, 30 minutes, 10 sec and counting
Old Jun 11, 2005, 01:19 PM
Living a Dream
Joined Oct 2003
LOL, I think, now you know the same as before you have asked!
Let us know what youīve done and what happend!
Greetings and Happy Flying
Hans-Joachim
Old Jun 12, 2005, 01:43 PM
GeorgeZilla
Spring Valley, CA
Joined Mar 2005
[QUOTE=Hans-Joachim]Stay cool!
Let her fly!
:-) Hans-Joachim
Full throttle Launch straight![/QUOTE
Hans,
Took her out to the field just now. Found that my battery needed about another 45min on the charger. The wing is at 4mph from SSE. The plane wants to roll left while facing the wind at static, no power applied. Bad sign? I'm gonna launch her anyway!
JSF F-35 Ready for Launch Ken Lapointe Electric Ducted Fan Jet Talk 50 Sep 04, 2009 10:39 PM
FS: EJF F/A-18 kit for 90mm Kevin Cox Aircraft - Electric - Airplanes (FS/W) 4 May 14, 2004 02:27 PM
F-18 ready for flight, but which motor ? Niels Electric Ducted Fan Jet Talk 8 Aug 16, 2002 10:41 PM
f/a-18 ready for paint ESB Electric Ducted Fan Jet Talk 4 May 13, 2002 11:31 AM
Kevin Cox F-18 ready for duty! JasonJ Electric Ducted Fan Jet Talk 8 Oct 12, 2001 02:29 PM
