Old Jun 11, 2005, 08:08 AM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Auto Antifreeze/Coolant question-Which type??
I have a 2001 PT Cruiser & the manual says it uses a Special Antifreeze with H.O.A.T. I think that HOAT Antifreeze means that it used "organic" ingredients or something? I needed to add a little antifreeze because the car was a little low so I used some of my standard "Green" Autozone general purpose antifreeze. Are bad things going to happen now? Autozone doesn't seem to have any HOAT stuff, where can you get it? Do I really need it?
- Thanks -
mrebman is offline Find More Posts by mrebman
Old Jun 11, 2005, 08:45 AM
freeflight is offline
Find More Posts by freeflight
no place like cloudbase
freeflight's Avatar
Columbus, Ohio
Joined Aug 2002
Well I would guess you could probably find it at the dealership. With big markup of course.
Leigh
freeflight is offline Find More Posts by freeflight
Old Jun 11, 2005, 08:56 AM
mrebman is offline
Joined Nov 2000
Yes, but do I really need it? Supposedly the Organic (HOAT) stuff will last up to 100,000 Miles (I think I read) but the regular stuff will only last 50,000 Miles. However, since I change my coolant more often than 50,000 miles anyway do I really need the HOAT? Also, If I mix the organic (HOAT specificaly) with regular green antifreeze, what will happen??
-Thanks-
Old Jun 11, 2005, 10:34 AM
freeflight's Avatar
Columbus, Ohio
Joined Aug 2002
Sorry not sure. The dealer of course will tell you that you should only use thier stuff. If it was a Porsche I would say go with what the dealer uses but with most vehicles I would think aftermarket quality branded stuff is fine. Does Advance or other sell aftermarket stuff that lasts 100k?
Leigh
Old Jun 11, 2005, 10:51 AM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
I've been told by my mechanic that I should not be using the standard green Prestone anti-freeze in my all aluminum block Volvo 850T. He further asserts that although Volvo strongly recommends the expensive Euro blue anti freeze approved for Volkswagons, I can in fact use the orange Prestone product for aluminum alloy engined and radiatored domestic cars safely, but i should never mix in the green stuff.
Looee
Looooeeee! is offline Find More Posts by Looooeeee!
Old Jun 11, 2005, 11:05 AM
freeflight's Avatar
Columbus, Ohio
Joined Aug 2002
found this, might help answer your questions.
http://www.imcool.com/articles/antif...-Glysantin.htm
Leigh
Old Jun 11, 2005, 12:55 PM
mrebman is offline
Joined Nov 2000
Leigh:
Thanks for the link! If I read this correctly, My traditional Green is still compatible with the New "HOAT" stuff, just slightly different additives that will mainly extend the coolant life. (Link Below)
To give it to you straight, DaimlerChrysler (DC) has two production vehicles now using a hybrid organic acid technology coolant (HOAT). This coolantís inhibitor package is slightly different from traditional high-silicated green coolant, enough that itís expected to provide double the service life, but is still compatible with traditional
-Mike-
Old Jun 13, 2005, 12:11 AM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Gerald is offline Find More Posts by Gerald
Question which batteries work on 010 and 020 brushless motors thor4944 Batteries and Chargers 5 Dec 27, 2002 10:07 PM
which type of covering prefer? omega blood Parkflyers 14 Oct 01, 2002 07:22 PM
Which type of Antenna electrofied Electric Heli Talk 4 Jul 15, 2002 08:07 PM
Auto Upholstery + Adhesive question Fiasco Life, The Universe, and Politics 8 Jun 12, 2002 08:30 AM
Lite Stick Building Question, Which Wing Mount? mrebman Parkflyers 3 Jul 01, 2001 11:36 AM
