Old Jun 10, 2005, 11:33 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Built up Balsa wing - Any ideas?
I'd like to build a balsa wing... I guess something similar to the Wing-E, but bigger.
Anyone know of a free plan out there for a built up wing? I'll have a much greater chance at succeeding with this if I have a plan to follow
uproar90
msmith is offline Find More Posts by msmith
Old Jun 10, 2005, 11:47 PM
indoruwet is offline
Find More Posts by indoruwet
God's gift to mankind for flying anything.
Joined Aug 2004
Do you have any idea on what airfols it should have ?
If you can do a bit of CAD, you can generate the plans your self.
I have a small wing designed for Balsa. 32 inch span.
indoruwet is offline Find More Posts by indoruwet
Old Jun 10, 2005, 11:53 PM
DaveGherardini is offline
Find More Posts by DaveGherardini
Central Illinois
Joined Sep 2002
this is one i built last year from wood, 32"ws, Mega 3T, 10cells. i didnt make any plans, its just scratch built but it might give you some ideas if you do build your own..
http://www.rcgroups.com/forums/showt...ighlight=wood+
DaveGherardini is offline Find More Posts by DaveGherardini
Old Jun 11, 2005, 12:07 AM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
I dunno about plans. The hobby shop i work for has the famous "klingberg" wing of old kit that is super nice and has plans, though. its a seriously pretty and nice flying wing.
The kit is $70. I can get it and ship it to you if you can send me the $$ and am interested.
--Alex
raptor22 is offline Find More Posts by raptor22
Old Jun 11, 2005, 12:26 AM
msmith is offline
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
indoruet - I've looked over Profili and a few other airfoil programs... I think I could just choose an airfoil, then make it into a tapered wing instead of a straight wing...
Cut out two sets of each rib and start gluing it together...
Thanks for the offer raptor22, but thats a bit steep for me right now...
Thanks for the link Dave... I'll check it out.
Old Jun 11, 2005, 11:22 PM
Joined Aug 2004
If you do a tapered wing, layout the rib that goes in the middle somewhere on your workbench in such a manner that the rib is square with your workbench. Then decide the sweep angle of the leading edge. Now decide how "long" the rib should be at the far end of the wing. Now find the "fulcrum" point of the ribs from where they are generated. All ribs "in between" the center rib and the outer rib should now thus be the length as defined by the angles generated by the fulcrum point. The set of ribs can then be generated by Profili, as stated above. The drawings I have, also have a set of supports, that maintain relative position. They are then cut off after you glued it all together right before sheeting or glassing.
The wing I have looks very similar to the one described above.
I have done the Klingberg wing and it was not easy to get it all together in the right positions. Once it is all OK, It is quite a wing, narrow and skinny. As a matter of fact, the Klingberg wing was once built full scale and flew somewhere in So Cal.
HTH.
If you have more questions, PM me.
Discussion any foamies out there that fly like a built up balsa plane? epoweredrc 3D Flying 30 Aug 11, 2007 06:21 AM
Question Built up balsa fuse w/ fiberglass finish willyrok Sailplane Talk 15 Sep 29, 2002 04:30 AM
built up TM wing.... Arbo Parkflyers 13 Jun 04, 2002 12:44 PM
Need a low drag built up balsa airfoil. Suggestions? rsieminski High Performance 7 Mar 15, 2002 10:48 AM
