Old Jun 10, 2005, 09:20 AM
ecologito is offline
Find More Posts by ecologito
Spring time, planes bloom
ecologito's Avatar
near UNC Charlotte, NC
Joined May 2003
Photos of your CD winds...
Hi I've been reading a lot in this forum about CD motors and I've been practicing rewiding CD motors, but I am impressed when people talk about 22 turns with a 24 gauge wire, how in the world can you fit that many turns ! !
I'd like you guys to post some pictures of your creations. Here is my last job, 16 turns 24 gauge wire
ecologito is offline Find More Posts by ecologito
Old Jun 10, 2005, 12:20 PM
landru is offline
Find More Posts by landru
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Very neat windings you've got there. From the photo, I see you've got lots more room to fill with wire. Fill it to the rafters, as Ron van S would say.
Here's a pic of a 25mm stator. I really do need to shorten those tails, don't I?
landru is offline Find More Posts by landru
Old Jun 10, 2005, 01:15 PM
ecologito's Avatar
Joined May 2003
holy $#%#$Y how in the world.. can you fit so much wire in there.. what is the gauge wire? that looks pretty thin
Old Jun 10, 2005, 01:41 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Looks to be 2W and 8-10T of 26G... ????
fly_boy99 is offline Find More Posts by fly_boy99
Old Jun 10, 2005, 01:48 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Hi eco,
Yes, the windings are really packed in there! The stator in the photo is a 12 pole GB stator, not a 9 pole GB stator. I posted the photo just as an example. The pictured stator has been wound with 8 turns of two strands of 26 awg wire. Two strands of 26 awg is equivalent to a single strand of 23 awg—which I didn't have available, and which might have been harder to wind. You can see from the photo that I probably could have sqeezed some more wire on, too.
For a given number of winding turns, use the thickest wire you can to fill up the stator slots in order to maximize motor efficency. Neat winding (like yours) can help you fit more wire on the stator, but otherwise is of no siginificance to motor function. It does look very nice though!
One trick to fitting as much wire as possible is to wind more turns on the "outside" of the stator tooth where there's a wider stator slot due to the larger diameter. All of the open spaces in your stator slots, for instance, could have been filled with more winding turns—or the same number of turns of thicker wire.
Another winding trick is to compress each set of windings against the side of the stator tooth before you wind the adjacent tooth. I use a little flat-sided steel solder pick to force the wire against the tooth, but that's probably a little risky. Better to use a plastic or wooden tool so there's less chance of damaging the wire insulation and causing a short. Compressing the windings significantly increases the amount of wire you can fit on the stator.
Andrew
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Sharp eye! I'm impressed.
a.
Old Jun 10, 2005, 07:06 PM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
Here is mine!
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Jun 11, 2005, 05:15 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Mine FWIW the story on 22T of 24ga is not going to happen. The last 2 pics show a 17T of 24ga and it takes a particular winding sequence to get the clearance on the front of the stator. #3 pic is the front and #4 is the back.
power is offline Find More Posts by power
Old Jun 11, 2005, 01:57 PM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Originally Posted by power
Mine The last 2 pics show a 17T of 14ga Mike
Mike-
Did you mean to write "17T of 24ga"?
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Jun 11, 2005, 03:04 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
Here's 21 turns of 26g newbie wire (from the standard Gobrushless kit) - I physically couldn't get any more in but it's not as neat as the above photos (and the photos aren't nearly as good)
The second photo has been photoshopped (gimp'd actually) to try to improve the colours - in case anyone wonders about the dark circle around the stator.
RobinBennett is offline Find More Posts by RobinBennett
Old Jun 11, 2005, 04:18 PM
powerditto is offline
Find More Posts by powerditto
Former User
powerditto is offline Find More Posts by powerditto
Old Jun 11, 2005, 04:27 PM
ecologito's Avatar
Joined May 2003
Hey Ditto, where do you get your motors?
Old Jun 11, 2005, 04:42 PM
Former User
Old Jun 11, 2005, 07:08 PM
power is offline
power's Avatar
Joined Apr 2003
Originally Posted by galloping gimp
Mike-
- Jeff
Oooops Yup 24ga
Old Jun 20, 2005, 01:00 PM
Sussex, UK
Joined Jun 2004
What am I doing wrong?
> 17T of 24ga
How on earth do you get that much wire on?
Here's a photo of 12 turns of 24g (on a double stator, but I don't think that should make much difference) As you can see the last few turns are only just in place.
I get 6 full turns in the first layer on each tooth, so the first phase isn't a problem, the second phase is harder and the third is a real squeeze!
Wanted: Photos of your foam chucky glider conversions Balsa Hound Parkflyers 10 Jul 16, 2004 07:26 PM
How do you guys get such great photos of your planes? Joe Ford Life, The Universe, and Politics 14 Mar 11, 2004 10:43 AM
any photos of your home made propsavers for SS steve ypsi mi Parkflyers 5 Dec 29, 2003 07:00 PM
aerial photos of your own R/C field jbourke Aerial Photography 12 Sep 11, 2003 05:21 PM
Please post photos of your Tiger Moth carbon fiber landing gear! CheeseWing Parkflyers 9 Aug 12, 2002 06:07 AM
