Old Jun 09, 2005, 03:00 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Alert
Avro Lancaster - Very British, isn't it!!!
ok folks; as some of you may have already read, I was searching for a new challenge
and I found documents of something that made me taking a break on my P47 built projects!
Something huge, - driven by four engines!
Very impressive ...
A DAM - BUSTER - the Avro Lancaster!!
The raw sketches are finished until now and thefirst parts are already existing
Walk around! Take a look!
Time for pics, isn't it?
Harpye is offline Find More Posts by Harpye
Old Jun 09, 2005, 04:14 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
IIRC there were plans for a depron Lanc in RCM&E a year or two ago, about 4' wing span - a club member built one and it looks (and sounds) great, even unpainted.
It wasn't heat-formed, just lots of short pieces with formers every couple of inches. I'm sure you'll do an even better job :-)
RobinBennett is offline Find More Posts by RobinBennett
Old Jun 09, 2005, 04:28 PM
Pjotrrr is offline
Find More Posts by Pjotrrr
Me likes Depron...
Pjotrrr's Avatar
Amsterdam Schiphol, Netherlands
Joined Mar 2003
Go for it, one of my favorite planes!!!
Pjotrrr is offline Find More Posts by Pjotrrr
Old Jun 10, 2005, 09:44 AM
Harpye is offline
Harpye's Avatar
Germany
I think I'll do the fuse in two halfes as usual with an inner structure to carry the wings and the accu.
The wings will be made of depron too with a 5mm CFK tube as a stabilization
The back sevo ( for elevator) will be mounted under the MG position and conected with this so the gun turns when using the elevator!!!
Old Jun 10, 2005, 10:45 AM
Dr._Gernot is offline
Find More Posts by Dr._Gernot
Germany, BY, Gersthofen
Joined May 2005
Hello,
during WW II most of the Lancasters were used by night and therefor painted in black, which gives them a unique look.
http://www.paulnann.com/images/pn_w2179.jpg
Gernot
Dr._Gernot is offline Find More Posts by Dr._Gernot
Old Jun 10, 2005, 11:13 AM
Harpye is offline
Harpye's Avatar
Germany
Mine will get the same scheme ( you defined a very dark green/ gray ( the color is called "night" in some color tables ) as black) as you will see! I'll do this one in the way of the " MIKEY THE MOOCHER"!
http://www.mg-sportcars.co.uk/XPOWER...ter%20Nose.jpg
Old Jun 10, 2005, 01:18 PM
desmo is offline
Find More Posts by desmo
United Kingdom, England, Hindhead
Joined May 2004
If you do a search in scale forums for lancaster or my name you will see the depron lank I am building from the quiet flyer plans.
Almost ready to fly now, just have to paint the turrets and apply decals
desmo is offline Find More Posts by desmo
Old Jun 10, 2005, 01:41 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Simply Awsome Harpye send over those plans and i may try it myself .. 4 edp50 motors with 3x3 props
Vyceroy is offline Find More Posts by Vyceroy
Old Jun 10, 2005, 05:30 PM
Al Dente is offline
Find More Posts by Al Dente
Joined Mar 2003
Doctor Gernow,as far as i know,all operational Lancasters were used in dark green/brown camoflage,despite the seemingly obvious suitability of black for night operations.I finished my Priory Lanc in black because i lacked the time to do a proper job;i took solace though on finding that Lancs were delivered from the factory in black,on squadron the proper camo and registration letters would be applied.Al.
Al Dente is offline Find More Posts by Al Dente
Old Jun 10, 2005, 06:43 PM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
This looks all great!!!
I have wanted to build the RCM&E S400 sized Lanc for a while now but as i have just started to work with depron, and i here there are plans out there for one i'm now really interested....
Where can i get a copy of the depron plans? 4' would be a good size....
ticketec is offline Find More Posts by ticketec
Old Jun 12, 2005, 04:13 PM
Harpye is offline
Harpye's Avatar
Germany
Plans are still not ready! - I'm also working with a special technique using
a kind of tool for forming the fuse ( check out for Parkflyer.de and choose
"how to build with depron" for to understand how!!! )The only parts I finished are the two "gear - boxes", - and the plane never flew before - if you would like to build synchronously! - You would build on full risk!!!
Avro lancaster 3-views? Paul Penney Electric Plane Talk 8 Oct 13, 2009 07:48 AM
"Fund my t--b--e" sale : Avro Lancaster Atindra Aircraft - Electric - Airplanes (FS/W) 6 Nov 21, 2003 09:20 PM
This isn't a df but the real one had jet engines, check it out!! Jeremy_D Electric Ducted Fan Jet Talk 5 Jun 30, 2002 11:12 PM
RFS-100 isn't working for me? Crasher Scratchbuilt Indoor and Micro Models 29 Mar 14, 2002 12:01 AM
Tell me this isn't so martin richards Life, The Universe, and Politics 42 Feb 28, 2002 01:14 PM
