My trike gear TS1 would ROG from soccer pitch grass with direct drive S400s and 8 cells, but acceleration was fairly slow. |
Singapore
Joined Oct 2005
Cheers Kelvin
Joined Oct 2005
A hobby store in Madrid has recommended the following battery for the TS II:
BP4600 7,4 (2S) 38x38x105 mm 235 gr. price: 87,50 Euro They explained that they call it 4600 but the pack contains two 2300mAh cells in parallel “internally”. I am not sure if I have understood what they mean with internally, is it an ordinary 2300 2S2P? Do you think its too wide for the battery compartment? Would it be possible to widen the compartment with some millimetres? |
[QUOTE=Madrid]A hobby store in Madrid has recommended the following battery for the TS II:
BP4600 7,4 (2S) 38x38x105 mm 235 gr. price: 87,50 Euro They explained that they call it 4600 but the pack contains two 2300mAh cells in parallel “internally”. I am not sure if I have understood what they mean with internally, is it an ordinary 2300 2S2P? Do you think its too wide for the battery compartment? Would it be possible to widen the compartment with some millimetres?[/QUOTE The width of the battery compartment is 28mm. It should be fairly easy to remove the 5mm per side if this is done before joining the two halves. Tony |
I fly my TS2 on Speed 400 7,2V - 11,1V 2100 LiPo Battery - Jeti 45 ESC. I tried some props: 5x4 : the white stock GUNTHER prop (4,9 x 4,3) Good in almost all case ... but they break easily (and start the big noise). I use them ... but I search some more trust. 6 x 4: the red GUNTHER prop (5,9 x 4,3). too much trust .... also at low RPM ... a lot of amperes and very hot motors. Used just one time at very low RPM and battery discharged very quick. 5,5 x 4,5 : by APC; a great delusion ! Absolutely not enough trust. Tried one time and wasnt able to launch (just go down after launch at max RPM). Next attempt: Graupner Speed Cam 5,5 x 5,5 and then: Speed 480 7,2 V and CAM SPEED 6 x 3 Lets see ! Ciao |
That should be interesting. (the video)
Wonder if anyone has tried the carbon zagi 5X5 props? http://www.zagi.com/index.php?main_p...roducts_id=114 There is a propellor test at Bumpy Green, they recommend the Windsor: 6 x 3.5 (similar to Master Airscrew) and the Kavan 6X4 yellow bendy prop. here is the link, you have to search for "prop study" then go down the results page to "Bumpy Green Model Aerodrome: Speed 400 Prop Study" and click. tt http://www.bumpygreen.co.uk/index.htm |
Singapore
Joined Oct 2005
1) Tried using GWS direct drive 5 x 4.3 prop, current drain is 24.5Amps lots of speed but not enough trust. The bird was climbing with difficulty. 2) Tried using GWS gear drive 6 x 5 prop, curent drain is 26Amps, lots of trust. The bird was climbing well enough. 3) tried using GWS direct drive 6 x 3 prop, current drain is 25Amps. Not enough trust, but the bird is flying as good as the standard prop that comes with the plane. NOTE: i am currently still flying with Speed 400 6V. Not sure if i should change to 480 7.2 as the later can only provide alot of trust and torque but not speed. Maybe i will change to Motor Max 400F brushless outrunner to try hee hee..... Will continue to explore and update all again if i am able to find the best prop for the original speed 400 6V motor. Cheers
| Thread Tools | |
| The Mpx Micro-Jet has arrived! (Part II) | flieslikeabeagle | Foamies (Kits) | 57 | May 06, 2007 10:32 PM |
| Discussion MPX Twinstar II in Australia | maxy333 | Foamies (Kits) | 1 | Feb 25, 2006 03:25 PM |
| Yippee! MPX Twinstar II maidened today!! | Chetto1965 | Electric Plane Talk | 10 | Feb 08, 2006 01:09 AM |
| Discussion MPX Twinstar II configuration? | Chetto1965 | Electric Plane Talk | 9 | Jan 05, 2006 01:20 AM |
| The Mpx Micro-Jet has arrived! | Jurgen Heilig | Foamies (Kits) | 655 | Jun 05, 2005 03:46 AM |
