Old Jan 25, 2013, 08:04 AM
redradar is offline
Find More Posts by redradar
United States, SC, Clemson
Joined Dec 2011
I just wanted to chime in and say i experienced this same problem with harmonic vibration. I was using turnigy brushless motors and modified the mounts to accommodate them. What I noticed is that one particular motor had more vibration than another. I was able to trace it to weak mounts. I changed out my mounts with a ply version I rigged up myself.
redradar is offline Find More Posts by redradar
Old Jan 25, 2013, 08:34 AM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Be careful not to blame the mounts too quickly - The vibration has to come from somewhere.
First of all, make sure the props are balanced. If you are still experiencing vibrations, try rotating the prop in relation to the motor by 30 degrees at the time until best setting.
Last resort is using quality props - Graupner 8x5 E-PROPs are very good, and you can even have them in a counter rotating pair.
When you have achieved a reasonably balanced motor/prop combo, then you can look into the mounts; I have secured the front part of the mount with hot glue, which can be removed if need be. Furthermore, I have added a lower foam bridge between the open, lower nacelle halfs. Also hot-glued in place. Runs very, very smoothly now
EDIT: And do NOT fly with the described vibrations!
mike_o is offline Find More Posts by mike_o
Old Jan 25, 2013, 08:43 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Harmonic resonance is something that affects EDF. The advice is to avoid the power settings that bring it on. Also, I think he said he balanced the props.
If he's balanced the props, stiffened the mounts and avoids the affected power settings, then he's done all he can do.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Jan 25, 2013, 11:00 AM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Originally Posted by Gerry__ View Post
Harmonic resonance is something that affects EDF. The advice is to avoid the power settings that bring it on. Also, I think he said he balanced the props. If he's balanced the props, stiffened the mounts and avoids the affected power settings, then he's done all he can do.
I had this problem and it turned out to be that one prop was not tracking right. The two blades were not drawing the samw arc as each other,. I finally fitted two APCs and it went all away. [But still needed more power]
So then I fitted two brushless motors (used the MPI TS II upgrade kit) and the vibration problem came back. This time it was the mounts that needed tightening up. Gorilla glue to the rescue!
And then 3 years later it came back at high rpm. This time it was a bad bearing in one motor. Buzzed a high rpm.
The TS II has some flex in the foam around the wing pod mounts. I think that mine may be getting "foam-fatigue!". If all is tight and balanced it works -- if not fit EDFs :-)
It's always something.....
Eric Henderson is offline Find More Posts by Eric Henderson
Old Jan 26, 2013, 01:10 PM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Took my TS for a maiden today .. everything went well ..
But im a little disapointed about the speed , so im gonna swap for some other motors.
What I got in it now is a pair of 2209 1130kv spinning 8,5x6 counter rotating props.
http://www.hobbyking.com/hobbyking/s...Outrunner.html
I had some 1350kv motors laying around , just finished putting them in ..
octane81 is offline Find More Posts by octane81
Old Feb 04, 2013, 02:14 PM
Viktor50 is offline
Find More Posts by Viktor50
Viktor50's Avatar
Russia
Joined May 2010
Twin star 2. movie 14 (12 min 53 sec)
Viktor50 is offline Find More Posts by Viktor50
Old Feb 08, 2013, 12:30 PM
CurrentDude is offline
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
Originally Posted by Eric Henderson View Post
.....I had this problem and it turned out to be that one prop was not tracking right. The two blades were not drawing the samw arc as each other,. I finally fitted two APCs and it went all away. [But still needed more power] .......
APC Prop is always for me. I had so many problems using el cheapo props - not worth the hassell unless you've patience and time to balance/ track etc. APC have never let me down for the last four years.
Cheers
QUESTION Mike_o's model count so far ???? Bet it's well past double figures now
CurrentDude is offline Find More Posts by CurrentDude
Old Feb 08, 2013, 02:06 PM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Cheers
I'm 100% with CurrentDude on the APC props; They even provide a wide range of counter rotating pairs, which are great for the TS. I've initially flown it with APC 8x3.8 SFs, have done a quick spin with APC 8x6 thin electric (not the best match for the motors at that time), tried out APC 7x5s for touch and goes in the snow, and currently waiting to try a set of Graupner 8x5 (also counter rotation).
The 8x3.8s are great for their climb performance. So easy to pull yourself out of trouble with these.
Model count, hmmm.. my count back in the autumn said:
Multiplex TwinStar2
AXN FloaterJet
Multiplex PicoCub
Multiplex MiniMag
Scratchbuild foamie 1 (dead)
Scratchbuild 250gr foamie 2
Scratchbuild 350gr Sopwith Camel foamie (flown, but under repair now)
Multiplex EasyStar 2
Multiplex Merlin
Multiplex Easystar 1 (modded during build to an "EasyTwin" FPV platform)
Multiplex FunJet
and since then a few more came into the hangar:
Multiplex EasyStar l FPV (non-aileron)
Mulitplex Sonic Liner
Mulitplex Twin Jet
Mini SkyWalker
During winter time, when my fingers are freezing, the latest ES1 is a pleasure to put together with it's lack of aileron cables. Flies well, still (display in meters):
FPV EasyStar flying high (17 min 16 sec)
The SonicLiner was an offer I couldn't refuse:
So was the classic TwinJet
I'm still considering the full size skywalker for longer lange FPV, but I still haven't found the limit of the ES airframe....
Just a little TS2 touch an go to get back on topic:
TwinStar 2 snow touch'n'go onboard video (0 min 0 sec)
Old Feb 08, 2013, 03:13 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Watch the rpms with APC-SF props. They are limited to 65000/diameter in inches. So just over 8100 rpm for 8" diameter ...
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 08, 2013, 03:58 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
I just put everything in my heads up cart for a Easystar setup for twin Firepower 400 BL motors for $250.00, 3S/3300 50C lipo included. All I need to fly is my RX. That's a hell of a deal for a plane of this quality, I love my Fun Cub. Yea! $254.00 shipped ..Dave/zeezee
zeezee is offline Find More Posts by zeezee
Old Feb 18, 2013, 11:52 AM
FlyingKiwi22 is offline
Find More Posts by FlyingKiwi22
U.K. or New Zealand
FlyingKiwi22's Avatar
United Kingdom, England, Clevedon
Joined Jun 2007
Woop woop Sonic Liner
Multiplex TwinStar2
AXN FloaterJet
Multiplex PicoCub
Multiplex MiniMag
Multiplex Merlin
Multiplex FunJet
Mulitplex Twin Jet
Mini SkyWalker
http://youtu.be/zxRM8knYeOY
http://youtu.be/bN0pkpflthE
FlyingKiwi22 is offline Find More Posts by FlyingKiwi22
Old Feb 24, 2013, 12:00 PM
Justapoke is offline
Find More Posts by Justapoke
aRCee Moron
Justapoke's Avatar
The Netherlands
Joined Jun 2012
Just got myself a Twinstar kit and trying to figger out what aditional hardware I need.
So what motor / ESC to use... I allready have a single NTM Prop Drive Series 28-26A + Plush 25amp laying around and these seem to fit. Good choice to go with these to end up with plenty of power?
Kv (rpm/v) 1200
Weight (g) 57.6
Max Current (A) 18
Power(W) 250
Prop Tests:
7x6E - 11.1v - 90W - 8A
7x6E - 14.8v - 192W - 13A
8x4E - 11.1v - 100W - 9A
8x4E - 14.8v - 222W - 15A
8x6E - 11.1v - 145w - 13A
The stock Permax 400 weighs 73g, so with around 58g for motor and 22g for ESC (if I place this in the wings) I end up with around 7 grams more weight.
To sum it up:
2x NTM 28-26A 1200kv / 250w
2x Plush 25amp ESC
1x HobbyKing HKU5 5V/5A UBEC
For servo's I'll go with the recommanded Hitec hs-81's
Props: I think about 8x6 or Graupner 8x5
Lipo's I have: Nanotech 3S 3300 (could also try 2x Nanotech 3S 2650 but I guess the 3300's are fine)
Tx/Rx: Hitec Aurora 9 / Optima 7 - and I think I will test this OrangeRX 3-Axis Flight Stabilizer that I just got plenty of room for this as well. (first time I will try a gyro)
I'm not yet into FPV yet, but I probable will make some mods to the fuselage so I can get more stuff in the spare room at the back when needed.
Any suggestions what more to think off ? Any reinforcements nessesary with the build besides the usual tape under the fuselage? Wing looks like the spar is very small, did anyone add some carbon there?
Justapoke is offline Find More Posts by Justapoke
Old Feb 24, 2013, 12:04 PM
aRCee Moron
Justapoke's Avatar
The Netherlands
Joined Jun 2012
By the way I also looked at this, but than again I allready have a single NTM and ESC
Power set Brushless TwinStar II - Natterer Modellbau
They do not mention the prop size.. the included motor mounts look nice, but the NTM's just fit with the standard mount if I reverse them.
Old Feb 24, 2013, 03:02 PM
Joined Jun 2011
How about a Guardian "Autopilot" ?
Since members here are raving about FPV so I thought I mention it. Two weeks ago I started using it in one of my models - well what can I say "It's the FUTURE" in RC flying.
More I use it, the more I XXXX it.
Mike_o do I correctly remember that you tried it? If you haven't then order one tonight ...
The best GBP I spent on a RC "Gudget".Thinking about installing it in all of my scale and precious models.
Cheers
Old Mar 02, 2013, 01:33 PM
yakav is offline
Find More Posts by yakav
Russian Federation, St Petersburg
Joined Jul 2012
Twinstar II excellent aircraft for the video. It flies very smoothly and predictably.
TwinStar II & GoPro (3 min 41 sec)
yakav is offline Find More Posts by yakav
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
