Old Sep 15, 2012, 04:37 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by CurrentDude View Post
Ahhhh... but orange is the most visible colour. It'll offer a great chance to turn TS II into a dot in the sky
Cheers
The human eye can't discern colour at that kind of range.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Sep 15, 2012, 07:11 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
May be on a bright sunlight but orange/ amber has overall superior visibility to human eyes even in fog or mist. All traffic lights have amber lights to warn light is going to change and so on.
Cheers
True, in those conditions, you have me beat!
Shadrack is offline Find More Posts by Shadrack
Old Sep 15, 2012, 07:32 PM
CurrentDude is offline
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
Gerry_ The human eye can't discern colour at that kind of range
and
Originally Posted by Bill Glover View Post
It'd just be a silhouette then - you wouldn't be able to see what colour it was
Pure white is about as bad as it gets up against cloud though - anything is better than that!
Relatively speaking (colourwise)..
Cheers
CurrentDude is offline Find More Posts by CurrentDude
Old Sep 17, 2012, 02:42 AM
Virgil Kee is offline
Find More Posts by Virgil Kee
Kill Devil Hills, NC
Joined Jun 2002
TS-2 Controller Question
My TS-2 has developed a problem: after connecting the flight battery, I first check the aileron, rudder and elevator functions. These all check out as normal. When I then check the throttle, however, the motors stop after a short run. Repeated tries give the same result, regardless of the throttle position ..... can't fly!
I have brushed motors (480 Long Can) and a compatible ESC (35A, I believe.)
I think I can rule out ESC overheating, since run time is only about 10-15 seconds before the motors cut out.
Any help, or, should I post on the POWER SYSTEMS forum?
Virg.
Virgil Kee is offline Find More Posts by Virgil Kee
Old Sep 17, 2012, 05:11 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Virg.
Sounds like LVC.
What pack are you using, and what are the settings on the ESC? Have you tried more than one pack? Has it worked ok before?
Bill Glover is online now Find More Posts by Bill Glover
Old Sep 17, 2012, 12:42 PM
Air Cooled is online now
Find More Posts by Air Cooled
gravity is strong where I fly
Air Cooled's Avatar
United States, NY, Rochester
Joined Jul 2011
I thought one ESC and 2 motors were a no-no......... is this why?
I never tried it - because I was told not to
Air Cooled is online now Find More Posts by Air Cooled
Old Sep 17, 2012, 12:54 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
On a brushed it is fine.
Brushless it is a no no.
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Make sure you have your LVC set right.
Should be 9V for a 3S pack. I have flown the TS with a 2S pack and had success with bigger props on the brushed motors, but had to set the lvc to 6V.
Old Sep 19, 2012, 01:59 PM
Ginger Adam is offline
Find More Posts by Ginger Adam
I'm Ginger & called Adam
Ginger Adam's Avatar
Hereford, UK
Joined Oct 2002
It could also be happening if the motor/prop combo is drawing too much for the ESC rating.
Ginger Adam is offline Find More Posts by Ginger Adam
Old Sep 19, 2012, 08:23 PM
Fviking is offline
Find More Posts by Fviking
Fly Seaplanes
Fviking's Avatar
Sandy Hook, CT.
Joined Jun 2009
One ESC 2 motors
You can run 2 motors from the same ESC, The motors need to be identical and the ESC rated for enough amperage.
I have done it on planes and Boats.
Fviking is offline Find More Posts by Fviking
Old Sep 19, 2012, 09:30 PM
Stantheman is offline
Find More Posts by Stantheman
Stantheman
LaGrange, Ky.
Joined May 2004
and
Cheers
When I was in the Air Force, ahem, years ago, the Air Force did a study pertaining to what color was most visible at great distances. The winner?
FLORESCENT ORANGE.
Stantheman is offline Find More Posts by Stantheman
Old Sep 20, 2012, 10:30 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Makes sense to me.
Old Sep 20, 2012, 07:16 PM
Joined Jun 2011
^^ Well said and I wasn't going to show off my background in aviation. Now you know why windsock and VFR airport symbols are in orange.
Fluorescent orange is the most visible I agree but I don't thing CAA has accepted it yet. May be someone can correct me.
Cheers
Old Sep 20, 2012, 09:19 PM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
Well this color thing is very dependent on angle and distance, weather..
I fly gliders and have no problem seeing 2 m glider as long as it is black. At 1400 ft and higher all colors fade to gray or darker at an angle, looking directly from the bottom all colors turn variation of black, the background sky is always brighter causing this effect. Just like trying to take a picture of a person in front of back lit window.
I can only judge what the plane is doing at this height if I paint it all black on the bottom, top can be orange or red or what ever but if I am very high and roll or loop I loose the view of the plane until the black side is facing me, then the plane is clearly outlined again. I wander what the distance was navy used in their tests. It is also different when you are flying and looking down with the sun behind or above you, then colors are visible much longer, however that is not what we do.
ddruck is offline Find More Posts by ddruck
Old Sep 20, 2012, 10:19 PM
Joined Jun 2002
Sounds like LVC.
What pack? ...... 2S Lipo
ESC settings? ...... Here are the Mfr's (GWS) specs:
[I]["NOTES FROM OUR TECH DEPARTMENT" (Tower Hobbies)
This is the GWS High Frequency 30A Electronic Speed Control
for LiPo battery packs.
FEATURES: Forward only (no brake)
2-3 cell input
Lightweight
Futaba J style radio connector
Bare wire for motor and batttery allows you to choose your connector
Instructions on back of header card
INCLUDES: One 30A LiPo compatible ESC
REQUIRES: Motor, Battery and connectors
SPECS: Auto Cut (V): 5.4V and 8.1V
BEC: 5V/1.2A
Current: 30A continuous/45A max
Weight: 20g (.71oz) with wire 6g (.21oz) without wire
Length: 38mm (1.5") ESC 19mm (.75") HEATSINK
Width: 23mm (.91") ESC 31mm (1.22") HEATSINK
Heigth: 9mm (.35") ESC 6mm (.24") HEATSINK/I]
With 30A available, I shouldn't be hitting LVC since the 480 Long Cans only want 12A ea.
Tried more than one pack? ..... Yes, I have an identical one, but haven't tried it since the problem began.
Has it worked OK before? ..... Yes, the problem just began.
I'll charge up the batts and see what happens.
Thanks all, Virg.
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 11:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 04:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 02:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 02:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 04:46 AM
