Old Jul 16, 2012, 09:57 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Ok, thanks Jurgen.
I still remember emailing with you in the late 90's about the twinjet when you had a brushless one and had an article in a magazine about it.
So then are you stating that my amp use will be less at cruise with the eprops vs the slow flyers?
Shadrack is offline Find More Posts by Shadrack
Old Jul 16, 2012, 11:37 AM
hotspur is offline
Find More Posts by hotspur
Canada, BC, Vancouver
Joined Aug 2011
How balance power output
I am stumpted. I have a TS2 and I cant figure out how to balance the motor outputs. The left motor has about 10% more thrust than the right one. At higher power settings, the plane wants to pull right. The more power I apply, the more it pulls to a point where it is uncontrollable. Is their a way to calibrate the motors/esc so the output is the simular or is this just a attribute to flying multiengines? Both motors are the same, I use one batery with a "T" conector, and both ESC are the same brand (I realize that it the ESC that is the problem).
I have searched the forums in vain but I don't even know what you call this problem. Both ESC's are calibrated to match the Tx throttle and I have cut one of the power cables (red) coming from the esc to Rx. I am hoping their is a way to solve this either by changing my wiring setup or by using a setting in the Tx (Turnigy 9X).
Thanks is advance
hotspur is offline Find More Posts by hotspur
Old Jul 16, 2012, 11:44 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Confirm the motors are spinning in the right direction and the props are on the right way round.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Jul 16, 2012, 11:53 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I suggest using a BEC as well instead of power off one of the ESC's.
Don't know if it is related but I have both the power and ground of both of the esc's removed when using a BEC and just have the signal wires present as the ESC has a ground usually right to the battery. Avoids a ground loop.
Old Jul 16, 2012, 03:01 PM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Guernsey, Câtel
Joined Jan 2012
+1 on prop check. MUST face the same way.
Double check ESC setting/calibration.
Don't try to fix the problem by programming the Tx. That would be symptom treatment - find the cause instead and fix that.
Did you try switching the motors to exclude a motor problem?
mike_o is online now Find More Posts by mike_o
Old Jul 16, 2012, 03:14 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Even swap the motors from one esc to the other to see if the problem is the esc or the motor.
Old Jul 17, 2012, 01:28 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Shadrack View Post
Ok, thanks Jurgen.
Must have been early 00's, because the Twin-Jet was introduced in 2001.
Optimizing drive systems is a fairly complex subject. Without knowing the cruise speed of your FPV equipped TwinStar 2, the required thrust, and the prop characteristics at this speed, we can only guess.
Unless you have a wind tunnel to test props, you need to get several suitable props from various manufacturers and test them in flight. Cruise at the desired speed and your FPV system should tell you, which ones have the lowest current consumption.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 17, 2012, 09:19 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
That is what I have been doing.
Trying a different prop set each time.
I have video of some cruise speeds so I will check what was a comfortable speed if that helps with this heavy fpv tank. Have had it down to around 12 amps so far.
Old Jul 17, 2012, 09:37 AM
Joined Sep 2000
Most likely your motors are running noticeably below max. efficiency at 6A (each). It may be necessary to use smaller, lighter motors in order to optimize your setup.
Jürgen
Old Jul 18, 2012, 10:07 AM
hotspur is offline
Joined Aug 2011
Thanks for all the ideas on why one motor has more thrust. I know its the ESC for I have tried both motors on both ESC's and the thrust is still 10% more on one ESC than the other. Both motor have the same props in size, orientation and direction. I don't know I am expecting too much from a HK ESC in terms of tolerances, but I just wanted to know how others overcome this issue.
Old Jul 18, 2012, 03:24 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I always buy castle esc's.
Have never had an issue.
Don't know if there is a fix.
Can you calibrate the ESC's?
Old Jul 18, 2012, 03:37 PM
mike_o's Avatar
Guernsey, Câtel
Joined Jan 2012
I have at least 12 of HK's ESCs, and I have not experienced a 10% power deviation in any of them. I does sound as if something is wrong with one of yours. Does one of them get warm? (note : if only one is supplying 5V, this will get warmer)
Why not purchase one more of the same, and see if you get at least one balanced pair?
Old Jul 19, 2012, 12:19 PM
Air Cooled is offline
Find More Posts by Air Cooled
gravity is strong where I fly
Air Cooled's Avatar
United States, NY, Rochester
Joined Jul 2011
I just bought a used twinstar II, and it is 100% in stock form, and I just have some minor assembly to do to it to get it back up and flying. It came with one 2200 2-cell battery.....which is the ONLY 2 cell battery I now own.
I also own 2 e-flite 370 brushless outrunner motors (I think 1080kv), and I have a pair of matched 18A esc's as well. I have an assortment of various sized 3 cells I could use with this setup too.
My question is will these brushless 370 motors be a good upgrade from the stock brushed 400 motors? I beleive the 370's can handle a 8 or 9 inch prop, so I'm thinking that would be a good thing I'm thinking if I can use these 370's, then I would not have to invest in 2 cell batterys for my only plane that currently uses 2 cells
Air Cooled is offline Find More Posts by Air Cooled
Old Jul 19, 2012, 02:13 PM
Joined Sep 2000
A 2s/2200 mAh battery is way too light to ballance a TwinStar. It would be much better to use a bigger size (3200 to 4000mAh).
Your brushless motors would be a suitable upgrade, but you would need to do some re-wiring. Also ensure, that your 18A ESC can support 4 servos on 3s.
Jürgen
Old Jul 21, 2012, 06:12 PM
M4d_D is offline
Find More Posts by M4d_D
M4d_D's Avatar
Joined Dec 2006
on page one there is a post with all the weights of the foam parts , i am asking myself how light can it become ? i fly my twinstar with fpv equipment with about 1.4kg but if you would use 1300kv blue wonder ( 24g ) and 10A escs with 2200mAh 3s lipo one should be able to get a flying weight of under 900g .... has anyone ever tried to build that model really light ??? are there any flight videos ?
cheers
M4d_D is offline Find More Posts by M4d_D
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
