Old Nov 11, 2011, 08:08 AM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
It actually looks even better now, since I put some brushed aluminum spinners on instead of those stupid prop adapters. They look way better and work better too!
TexasAggie is offline Find More Posts by TexasAggie
Old Nov 12, 2011, 12:06 PM
Kaw1000 is offline
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
How did you get such crisp paint lines...what type of tape did you use?
Kaw1000 is offline Find More Posts by Kaw1000
Old Nov 12, 2011, 12:10 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Automotive striping tape. It's a thin vinyl tape. It actually worked pretty poorly and the paint leaked under it quite a lot. Painting foam is hard! I used a white sharpie paint pen to clean everything up. From any distance greater than about 6 inches you can't tell.
Old Nov 12, 2011, 05:54 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
What does the bottom look like?
Shadrack is offline Find More Posts by Shadrack
Old Nov 12, 2011, 08:17 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Just simple red tips:
Old Nov 12, 2011, 08:27 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
That "Cow" video was severely entertaining! Fun stuff, well done!
Bajora is offline Find More Posts by Bajora
Old Nov 12, 2011, 09:24 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
That is great.
I do black stripes on most of my planes for the bottom but like the paint job.
Great visibility.
Old Nov 13, 2011, 03:11 AM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by TexasAggie View Post
And getting very close to those cattle in the process.
Yes, I thought it was a rather ignorant thing to do.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Nov 17, 2011, 03:13 PM
theailer is online now
Find More Posts by theailer
Joined Apr 2006
Hi everybody!
I have ordered a Twinstar II so it's on it's way in the mail to me.
I have a little question if its allright. What about having two lipos, one for each engine and mount them on the wings ? What about pros and cons ?
I reckon it would put additional stress on some already frail wings, but it would cater for some much shorter batterywires.
theailer is online now Find More Posts by theailer
Old Nov 17, 2011, 03:34 PM
NeveSSL is offline
Find More Posts by NeveSSL
So many UMs, so little money.
Nashville
Joined Jun 2008
I don't think I'd do two batteries independently simply because they won't discharge at the same rate (although it would likely be close if everything else was equal). However, I do have a friend who runs two batteries in parallel with his Twinstar without any issues. It obviously makes it a little heavier and it handles a little differently, but this plane can take quite a bit of weight. Its not detrimental to its flying characteristics at all. And he gets like 40 minute flights!
Brandon
NeveSSL is offline Find More Posts by NeveSSL
Old Nov 17, 2011, 03:35 PM
rc-mike is offline
Find More Posts by rc-mike
Stay airborne my friends
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
Hey Brandon, did you get your wing fixed?
rc-mike is offline Find More Posts by rc-mike
Old Nov 17, 2011, 07:37 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I have run 2 x 3200 2S packs for a total of 2S 6400mA pack.
I ended up switching it up for a 3S 5100 mA pack.
To avoid the wiring issues, run 3 wires for the brushless motor wires into the fuselage and put both your ESC's in the fuselage.
No issues if you do it that way and if you run a higher Amped ESC (I run 40A ESC's when I pull about 15A from each) they don't even get warm.
I did a lot of reading and don't think the need is there to run the ESC in the wing behind the motors. Lot cleaner to do it the way I did.
Lots of room for battery especially if you carve a few areas before gluing together.
Old Nov 19, 2011, 12:41 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I finished building my camera mount from ReadyMadeRC tonight. Looks good and I can't wait to fly it!
Old Nov 19, 2011, 01:27 AM
Joined Apr 2006
Thanks for all the answers. Esc's in the fuse and one main flight pack it is.
Old Nov 19, 2011, 08:45 AM
thibaultvdb is offline
Find More Posts by thibaultvdb
Joined Jan 2009
Hi, I want to build an fpv plane which also records the flight with a goproHD. And I read alot that this is a good plane for that purpose. Is it easy to fit 2 brushless motors on this plane? Can I buy the foam only, and build the plane like that? Because I think brushed motor's aren't fast enough. I want it to really quickly go up, but when it's high, I'll fly it slowly. My goal is to get some amazing above the clouds footage. (when clouds are low, but still like 600 meters high )
thibaultvdb is offline Find More Posts by thibaultvdb
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
