Old May 20, 2011, 02:06 PM
danny.act is online now
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
BelgiŽ, Vlaams Gewest, Putte
Joined Jun 2004
The control horns delivered with the TS2 are just fine for normal use of the TS.
Just be shure they are mounted properly.
It's a good thing to lightly sanding the gluecontact surfaces with a 400 or 600 sandpaper before glueing them to the elapor.
I'm also using normal CA glue for them. Not medium, slow, or foam safe CA.
Mounting them this way I've Never had any problems with them.
danny.act is online now Find More Posts by danny.act
Old May 20, 2011, 04:22 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Not only on the TwinStar II, but other Elapor models as well:
http://www.rcgroups.com/forums/showp...15&postcount=4
JŁrgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 20, 2011, 06:59 PM
SmartMartY is offline
Find More Posts by SmartMartY
York, England
Joined Jan 2010
Thanks for the feedback regarding the horns guys, I have the CA that's recommended for MPX foam, and I'll remember to key the surfaces first. Now about those pushrods?
SmartMartY is offline Find More Posts by SmartMartY
Old May 20, 2011, 07:18 PM
danny.act's Avatar
Joined Jun 2004
Same as for the control horns, the original TS pushrods works just fine.
Just carefully read and follow the manual on installation and You can't go wrong. It's all in the effort You want to put in.
Old May 20, 2011, 08:41 PM
York, England
Joined Jan 2010
Cheers Danny, I'll do my best and report back
Old May 21, 2011, 02:57 AM
danny.act's Avatar
Joined Jun 2004
Good luck and enjoy completing Your TS SmartMartY !
Old May 23, 2011, 03:24 PM
jpgcag is offline
Find More Posts by jpgcag
The desert collection
jpgcag's Avatar
Yuma AZ/Puyallup WA
Joined Jun 2006
Flew my TSII in the highest winds so far for me. 12mph! They were in direct cross to my sort of runway. When it came time to land, the winds started to gust, but the TS (totally stock) handled the cross winds fine. It wasn't the most gracefull of landings, but hey no extra pieces!
I have all the parts for an upgrade to brushless, in fact I've had the parts for over a year, but the bird flies just fine stock, so at this point the upgrade will just have to wait.
Its totally fun to fly.
Jack
jpgcag is offline Find More Posts by jpgcag
Old May 25, 2011, 11:11 AM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Finally got my Twinstar 2 ready to FPV but I had a quick question.
I am using this motor:
http://www.headsuprc.com/servlet/the...lectric/Detail
With these props:
GWS 8040X3 Standard Rotation Propeller
GWS 8040X3R Reverse Rotation Propeller
Doing a watt test the plane wanted to move forward so I think my props are on right and my motors are spinning in the right directions.
But just to be clear, which direction are each of the motors supposed to spin and which motor gets the reverse rotation prop?
Also isnt the reverse rotation prop going to unscrew itself?
airbagit13 is offline Find More Posts by airbagit13
Old May 25, 2011, 01:35 PM
antonlubo is offline
Find More Posts by antonlubo
antonlubo's Avatar
East SF bay
Joined Apr 2007
With these props:
Hi, I have seen the props turn both ways on real aircraft, it doesn't seem to matter, though, I am sure someone will argue with that. Be sure to use Locktite, or simalr on the reverse pictch propnut. Have fun...Tony
antonlubo is offline Find More Posts by antonlubo
Old May 25, 2011, 01:43 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
But should one motor spin one way and the other motor spin the other way or can both be spinning the same way?
Old May 25, 2011, 01:59 PM
lledwod is offline
Find More Posts by lledwod
yukon canada
Joined Aug 2007
Both can spin the same way.
lledwod is offline Find More Posts by lledwod
Old May 25, 2011, 02:14 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
sweet, thanks.
Old May 25, 2011, 02:24 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
If you're using one each of the props you have described (i.e. one standard rotation and one reverse) the motors have to turn in opposite directions.
The one with the standard rotation prop should turn counterclockwise as you look at it from the front of the plane.
Edit: hard to be sure from your pics., but it looks like you might have reverse rotation props on both motors ... mounted back to front?
Bill Glover is offline Find More Posts by Bill Glover
Old May 25, 2011, 03:24 PM
bobber is offline
Find More Posts by bobber
Flyin brick
bobber's Avatar
Joined Feb 2005
Numbers molded on your props should face forward, you've got to see them if you look at them from the front of your TSII. If you use one normal and one reverse prop they have to turn in opposite directions. If both are either normal or reverse ones than they have to turn the same direction.
bobber is offline Find More Posts by bobber
Old May 25, 2011, 11:51 PM
airbagit13's Avatar
Miami, FL
Joined May 2009
Thanks guys, I am using one normal and one reverse. They are both facing forward. I will be sure to make sure they turn in opposite directions with the standard prop spinning counter clockwise.
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 11:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 04:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 02:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 02:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 04:46 AM
