Old Jun 10, 2005, 01:56 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
I am thinking which model I will build next:
Mpx Twin Star II
Mpx Sonic Liner
FreeAir SU-27
FreeAir F-15
FreeAir F-16
Flymex F-16
Graupner Super Decathlon
Graupner Nemesis
or, shall I convert my Easy Glider Electric to brushless power first?
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 10, 2005, 05:20 PM
maverick6 is offline
Find More Posts by maverick6
Joined Feb 2005
twinstar 2 !!! twinstar 2 !!! twinstar 2 !!! ...
maverick6 is offline Find More Posts by maverick6
Old Jun 11, 2005, 08:57 AM
Joined Sep 2000
Some more pictures first :
Old Jun 11, 2005, 03:50 PM
Joined Sep 2000
Started building my TS2 today. Instead of building the fuselage first, I started with the wing(s):
Old Jun 11, 2005, 03:52 PM
Joined Sep 2000
The Permax 400 comes with two internal capacitors installed. It won't harm to add a third one between the connectors.
Old Jun 11, 2005, 03:54 PM
Joined Sep 2000
With the wing complete, I started working on the fuselage. Here you can see the wing retainer nut plates installed in the right fuselage half:
Old Jun 12, 2005, 02:43 AM
Joined Feb 2005
hi ! naro std for the ailerons, that is enough??? and http://aircraft-world.com/shopexd.asp?id=2241 for the elevator and the rudder, that is enough too???
I will order the radio equipment but before, I check if they are good for this plane
Old Jun 12, 2005, 04:10 AM
Treetop is offline
Find More Posts by Treetop
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
Twin Star I weights for comparison
Just weighed the components:
(Twin Star II)
Fuselage: 162.2g
Vertical stabilizer: 23.2g
Horizontal stabilizer: 40.5g
Left wing panel: 118.3g
Right wing panel: 118.4g
Wing joiner/control rods: 66.0g
Accessories: 41.7g
Jürgen
Perhaps somebody has the weights of the "old" Twin-Star (for comparison)?
Twin Star I:
Fuselage: 158g ----(with canopy)
Vertical stabilizer: 17g ---(w/ dorsal strake)
Horizontal stabilizer: 24g
Left wing panel: 112g
Right wing panel: 115g
Wood parts: 75g
control rods: 16g
accessories: 56g
motors: (72g x 2) 144g
motor wires: 36g
props: (gunthers w/rubber hub 3g x 2) 6g
This is everything that came in the box, except the decals, no servos, y-connectors, etc.
Treetop
Treetop is offline Find More Posts by Treetop
Old Jun 12, 2005, 07:19 AM
Joined Sep 2000
Originally Posted by maverick6
hi ! naro std for the ailerons, that is enough??? and http://aircraft-world.com/shopexd.asp?id=2241 for the elevator and the rudder, that is enough too???...
As Multiplex recommends their Tiny-S (= HiTec HS-81), I would not use NARO Std for a model of that size. Why don't you use 4 NARO MAX BB? (I use HiTec HS-81 for the ailerons and GWS IQ140 BB (= NARO MAX BB) for rudder and elevator.
Jürgen
Old Jun 12, 2005, 07:31 AM
Joined Sep 2000
Updated weights:
Model without ESC, rx and flight battery: 845g
Due to the longer nose and the longer nacelles, even a very light (Lipo-)battery of just 160g would be enough to achieve the correct CofG. Some guys had trouble ballancing the old TwinStar with 7 cell Sub-C size!
With my old trusted 7/RC2000 pack (413g), and 60g for rx and ESC, my projected RTF weight is approx. 1318g - pretty much the same as my old Twin-Star and a lot less than the 1500g quoted by Multiplex.
Jürgen
Old Jun 12, 2005, 11:55 AM
Joined Feb 2005
what is the format of the battery?? (http://www.aircraft-world.com/shopexd.asp?id=2634 or http://www.aircraft-world.com/shopexd.asp?id=2633)
Old Jun 12, 2005, 12:02 PM
Joined Feb 2005
in fact, if I wanted to use naro std, it was because I had 2 of them and that I didn't use of it . But finally, I will buy naro pro
Old Jun 12, 2005, 02:55 PM
Joined Sep 2000
It's a standard 7 cell Sub-C pack (Sanyo NiCd RC2000).
Jürgen
Old Jun 12, 2005, 02:57 PM
Joined Sep 2000
Don't forget that the servo bays are made for HiTec HS-81 servos (dimensions: 29.8/12/29.6 mm). The Naro Max BB comes pretty close at 27/12.7/24.95 mm.
Jürgen
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
