Old Jul 26, 2005, 01:53 AM
Numb Thumbs is offline
Find More Posts by Numb Thumbs
Does it come in Flouro??
Numb Thumbs's Avatar
Melbourne, Australia
Joined Sep 2004
Jurgen
Thanks, that is EXCELLENT information!!!
Looks like 6x6 it is!!!
How does one determine the CI numbers??
I am truely facinated by this new calculation!
Numb Thumbs
Numb Thumbs is offline Find More Posts by Numb Thumbs
Old Jul 26, 2005, 03:50 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Originally Posted by Jurgen Heilig
When you "play around" with EZ-Calc (8 cells, 6x3") you get the following figures:
Turbo 450, 7.2V - 16551rpm - 71.4% efficiency
Jürgen
That's incredible efficiency for a brushed motor operating above its nominal voltage !
My idea of using the the 8.4v LRP Zenit was to get higher efficiency by operating it closer to its nominal rating (as compared to a 6v or 7.2v can 400). An extra 21g 'well spent', in my opinion.
ChrisP is offline Find More Posts by ChrisP
Old Jul 26, 2005, 06:47 AM
Scramble is offline
Find More Posts by Scramble
Belgium
Joined Jun 2004
Gaelic flyer
I am not too sure it would be easy to fit standard size servos inside the TS II fuselage. The moulded pockets have been designed for perfect drop-in MPX Tiny S servos, apparently (or so it seems to me) with a lot of consideration for space management. Problems might come from control rods position relative to servo arm position with higher servos, also from available space in which to house the battery pack between wider servos.
Concerning the one stick eight cells pack, weight would be alright but perhaps it might prove difficult to move the pack sufficiently forward or backward to hit the right CG spot.
Various : I think 5x5 black 'hard' Gunther props (on 8 cells) will rev too high and draw too much on 480 motors which are an option precisely retained to benefit from a higher torque and a lower current draw. They would be an improvement on the white ones on 400 motors. My electric specialist also tells me 450 motors will draw a lot of current, not an interesting solution.
Scramble is offline Find More Posts by Scramble
Old Jul 26, 2005, 10:52 AM
Sooty100 is offline
Find More Posts by Sooty100
elaporaholic
Sooty100's Avatar
Staffordshire, England
Joined Aug 2004
Hi folks,
Could anyone tell me which is the better choice for 7/8 cells with the white gunthers standard 6v or 7.2v s400?
Called into Punkies today (ModelSpot), came back with a nice new TS11.
Sooty100 is offline Find More Posts by Sooty100
Sooty100 is offline
elaporaholic
Sooty100's Avatar
Joined Aug 2004
And a Cargo
Old Jul 26, 2005, 12:02 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by ChrisP
Jürgen
Hi Chris,
High voltage - within reason - is always good for efficiency. The Turbo 450 has its max. efficiency at approx. 10A, while the Permax 400 peaks at approx. 4A (at 10A their efficiency is down to approx. 50%!). Nominal voltage is not important - it is Amps you have to worry about.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 26, 2005, 12:05 PM
Joined Sep 2000
Your "electric specialist" is obviously not an expert.
Jürgen
Old Jul 26, 2005, 12:42 PM
Crazyrcer is offline
Find More Posts by Crazyrcer
Crazyrcer's Avatar
Pleasant Hill, Missouri
Joined Jun 2004
Does the Twinstar 2 have any flying problems? As I recall the original Twinstar had some problems with the motors being aimed too far up.
Crazyrcer is offline Find More Posts by Crazyrcer
Old Jul 26, 2005, 02:05 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
The upthrust on the TS1 doesn't cause any problems, it's just there to make hand launches even easier. I removed it from mine when I fitted geared motors and it made no difference in flight whatsoever (I never hand launch my TS).
Bill Glover is online now Find More Posts by Bill Glover
Old Jul 26, 2005, 03:32 PM
Joined Sep 2000
Maidened my TwinStar II with a 2s1p Kokam 3200 this evening. New RTF is now 1070g (37.75 oz). Max. static current of the two Permax 400 with CAM 5.5x4.3" is approx. 24A.
I made three flights with one charge - total flight time 20 minutes - with plenty of aerobatics. When the ESC indicated that the battery was getting empty, I still had the feeling of plenty of power left, but recharge took 3066mAh.
20 minutes with 3Ah means 9A average, i.e. 4,5A per motor - nice setup.
How does the TS II perform with Lipos? Very agile - best compared to an A-10 "Warthog". Also the glide rate is fantastic - almost like a glider - glad that I've got spoilerons.
I have to get Jim to do some video.
Jürgen
Old Jul 26, 2005, 03:57 PM
Treetop is offline
Find More Posts by Treetop
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
And a cargo
Sooty went shopping!
Treetop is offline Find More Posts by Treetop
Old Jul 26, 2005, 09:42 PM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
Originally Posted by Sooty100
Hi folks,
Absolutely the 6v motor; the 7.2v motor is lacklustre on anything under 9 cells (or 3s lipo).
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old Jul 27, 2005, 02:11 PM
Joined Sep 2000
Got a second Permax 450 Turbo today. Before I change motors, I will do some static testing - Permax 400 versus Permax 480 versus Permax 450 Turbo - at various voltages. Might take some time, as I will be at the E-Meeting in Rothenburg, Bavaria this weekend.
Jürgen
Old Jul 27, 2005, 03:42 PM
Sooty100 is offline
elaporaholic
Sooty100's Avatar
Joined Aug 2004
Thanks Mike,
Ill go with the stock 6v then with a totally stock build. Any nasties I need to look out for Jurgen during the build?
TT,
its a good job Punkies were waiting on a shipment of EZ Stars (they only had the ARF version inc. radio) Im selling my gliders to please my credit card.
Old Jul 28, 2005, 12:17 AM
Joined Sep 2000
Thanks Mike,
The only change I did was shortening the outer tubes of the rudder linkage by 5mm and mounting the rudder horn connector upside down (you need to shorten the hex key to get to the scrub scew then).
Jürgen
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
