Old Mar 22, 2006, 09:49 AM
TonyBAMF is offline
Find More Posts by TonyBAMF
Sureflite
TonyBAMF's Avatar
Joined Jan 2006
He could just not have the right CG
If anything I am just guessing but, a 370 might be a 300size with the kick of a 400.
The permax 400 is a speed 400.
TonyBAMF is offline Find More Posts by TonyBAMF
Old Mar 22, 2006, 11:40 AM
jcosta is offline
Find More Posts by jcosta
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
I think Jeremy has probably checked the CG correctly.
A 370 is a Mabuchi 370, AKA Speed 400. The Speed 400 and the Permax 400 have some differences, as they both are built, AFAIK, to Multiplex and Graupner's own specs. I can tell you the Permax 400 has built in condensers, which I think is not true of the Speed 400 (Graupner).
From Multiplex site:
Permax 400 6V
Dimensions: 27.5 Ø x 40.5 mm
Weight: 73 g
No-load speed: 17,400 rpm
No-load current drain: 0.7 A
Maximum current: 8 A
Current drain at max. efficiency: 3.5 A
From Graupner site:
No-load rpm 18000 min–1
No-load current drain 0,7 A
Current drain at max. efficiency 4 A
Current drain when stalled 25 A
Max. efficiency without gearbox 70 %
Length of case, excl. shaft 37,8 mm
Diameter 27,7 mm
Free shaft length 13,8 mm
Shaft diameter 2,3 mm
Weight 73 g
As you can see there are quite a few differences. Even the dimensions are not exactly the same.
BTW, notice the efficiency figures from Graupner? Those are measured, not calculated by some software guy... The Permax 400 is, at least, as efficient as the Speed 400. So those 30-40% efficiency claims by some less informed people are obviously wrong... Still, a brushless motor is typically more efficient, around 75-85% for an outrunner and above 85% for an inrunner. This of course for the good brushless motors(Axi, Electronic Models, Kontronik, Hacker, Lehner, Mega, Jeti, Plettenberg, etc), not some cheap chinese products going around with wild claims about performance and efficiency.
jcosta is offline Find More Posts by jcosta
Old Mar 22, 2006, 11:52 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Jeremy Z
Forgive my ignorance in brushed motor nomenclature. I thought they were the same? I remember reading somewhere that a 6V 370 motor is really a speed 400. Does that mean a speed 400 is a weaker motor than a permax 400 6V?
Speed 400 is the Graupner name for a Mabuchi RS380 motor, and I know some guys at Multiplex get upset when you call their Permax motors "Speed".
The Permax 400 and the Speed 400 were once the same motors, but Multiplex seems to have changed their supplier. If you play with EZ-Calc, you get pretty different figures for basically the same motor:
http://brantuas.com/ezcalc/dma1.asp
Try: Mpx Permax 400, 6V / Grp Speed 400, 6V / Robbe Power 400/35
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Mar 22, 2006, 11:55 AM
Joined Sep 2000
The Mabuchi 370 is actually a Speed 300.
All Graupner Speed 400 have integrated capacitors.
Jürgen
Old Mar 22, 2006, 11:58 AM
Joined Sep 2000
These figures are manufacturer (Mabuchi) data - but the Mabuchi data are very precise.
Jürgen
Old Mar 22, 2006, 12:02 PM
Joined Sep 2000
Regarding the angle of attack comment: You said that if you climb at 20°, your AOA is only 5°. Does this mean the wing is angled down at 15°?
No, the model may climb at an angle of 20°, but the wing will be at an angle of approx. 25° measured to the horizon. At 5° AOA, a Clark Y type wing section will provide a lift coefficient of approx. 0.7.
Jürgen
Old Mar 22, 2006, 12:14 PM
Joined Sep 2000
- How much wind can it handle before it starts to make very slow progress for you? i.e. it takes a lot longer to fly upwind than downwind?...
Hi Jeremy,
perhaps you meant something like this?:
see attachment.
Jürgen
Old Mar 22, 2006, 12:33 PM
jcosta is offline
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
Jürgen
Sorry, right, its the Mabuchi 380 that is the Speed 400..
And thanks for the info on the Graupner motors. My experience with Speed motors is limited to the 300Plus on my Mini Piper...
Old Mar 22, 2006, 12:36 PM
jcosta is offline
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
Jürgen
Definitely more precise than Motocalc...
Old Mar 22, 2006, 09:13 PM
THE WALRUS is offline
Find More Posts by THE WALRUS
halifax nova scotia canada
Joined Dec 2004
I finally got to fly my TS ll last weekend and I was really impressed with its performance. I let my buddy who has much more experience than me fly the plane for a bit and he was also impressed but thought the CG should be moved forward a bit. I am using 8 sub c 3300mah battery packs which weigh about 18 oz. The plane seemed to zoom up with the CG set at 85 mm. I was thinking of adding a little down elevator to keep the plane flying level when you add throttle. Other than that I was very pleased with the plane and can't wait till next weekend to fly it again. I would like to thank all the people on this site who helped me with their knowledge and experience and I will try to send some flight video. THE WALRUS
THE WALRUS is offline Find More Posts by THE WALRUS
Old Mar 22, 2006, 09:28 PM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Thanks for the info Jürgen & jcosta!
Jeremy Z is offline Find More Posts by Jeremy Z
Old Mar 23, 2006, 04:08 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
If you mean that when the plane speeds up it wants to climb excessively then you need to move the CG back, not forward.
Bill Glover is offline Find More Posts by Bill Glover
Old Mar 24, 2006, 06:32 AM
05raptor660r is offline
Find More Posts by 05raptor660r
05raptor660r's Avatar
Buffalo, NY
Joined Mar 2006
Hello, all!
I just received my Twinstar II yesterday as my first foamy, second electric. Can't wait to get it airborne after watching all your videos. Looks like it flies great.
Unfortunately, my kit did not come with the circiut board. Does anyone know if I could just hardwire the motors to the ESC or does the board contain necessary components for proper current to the motors? I'll be using a completely stock system for now, with 7-8c NiMHs, 2500 to 3500mAh range, 30a max draw. The ESC is a GP C-35 brushed w/BEC.
Hopefully I can maiden it this weekend if I can bypass the board. Thanks for any advice you can give.
05raptor660r is offline Find More Posts by 05raptor660r
Old Mar 24, 2006, 07:02 AM
Jeremy Z is offline
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
The circuit board is just for convenience of removing/reattaching the wing.
After a few times doing this, the strands of wire of the aileron extension start to fray where they exit the board. You could just use another set of servo extensions to replace this and it would be better. You could just use Deans connectors to do the motors. Bullet connectors would work too, but take care to make sure they stay insulated and that they can't bang against something else in there.
After I did my brushless upgrade, I pulled those leads out of the wing anyhow. I've left the wing on ever since. It fits in my trunk just fine.
Old Mar 24, 2006, 07:27 AM
Buffalo, NY
Joined Mar 2006
Thanks for the good news!
I'll get a few Deans froms the LHS today. Hopefully it will be in the air by Sunday.
Lots of good info here. Thanks!
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
