Old Jul 18, 2005, 10:06 AM
agapornis is offline
Find More Posts by agapornis
agapornis
italy
Joined Jul 2004
Jurgen ....Thank you for your Help !
agapornis is offline Find More Posts by agapornis
Old Jul 19, 2005, 01:54 AM
Numb Thumbs is offline
Find More Posts by Numb Thumbs
Does it come in Flouro??
Numb Thumbs's Avatar
Melbourne, Australia
Joined Sep 2004
Muckin' about with outrunners
I have been playing around with a pair of Himark C2808-1360 outrunners on the TwinStar.
I am using a pair of Castle Creations 10 amp ESC's mounted at the motors and a PolyQuest 2600 mAh 3S LiPo. All up flying weight is 1080 grams.
Using a 6x4 APC prop (I can't get a Graupner in Oz around that size! ) I get:
750 grams Thrust / 11,200 RPM / 12.3 Amps (Total)
Using a 7x4 APC (no Graupner available ) I get:
970 grams Thrust / 10,000 RPM / 16.2 amps
Using the brushed 8.4 volt Speed400 motors I get:
Stock Props
660 grams / 13,000 RPM / 19.1 amps
Graupner 5.3x4.5
710 grams / 12,600 RPM / 19.5 amps
So on 7x4 prop I am getting 260 grams more thrust at 3 less amps than the Graupner prop on Speed400's. Or on a 6x4 prop, roughly the same thrust as the Graupner props on the brushed motors and 6 less amps.
Hmmm... Wish I could get more sizes in a Graupner here...
Cheers
Numb Thumbs
Numb Thumbs is offline Find More Posts by Numb Thumbs
Old Jul 19, 2005, 02:51 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Stock Props
Cheers
Numb Thumbs
Standard Permax 400, 6V for comparison:
8,8V - 25,6A - 220W - 14520 rpm
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 19, 2005, 04:36 PM
Joined Sep 2004
Oops
The numbers weren't quite correct for the outrunners...
The outrunner was rubbing slightly on the motor mount!
Actual figures, after abit of dremel work (I feel like a dentist!):
7x4 APC : 1080 grams thrust / 10,000 RPM / 15 amps
It is a 1 to 1 trust to weight ratio now. And I am saving a heap of amps!
It would be interesting to know how the "Watts" calculations convert to real energy available! If I am pulling 15 amps at 11 volts that is a theoretical 165 Watts, but I'd bet it has a heck of a lot more grunt than the 220 Watts of the stock setup! So is that where the "efficiency" of brushless comes in???
Cheers
Numb Thumbs
Old Jul 19, 2005, 06:53 PM
mickydee is offline
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi Numbs,
Can you tell me who carries the "Highmark" outrunners?
Thanks! Mickydee
mickydee is offline Find More Posts by mickydee
Old Jul 19, 2005, 08:40 PM
Joined Sep 2004
Mickydee
G'Day
I got them locally here DownUnder so I guess you want a US source???
They are a tiny little motors about half the size of a Speed400. They rub slightly on the plastic motor mounts - they were designed to hold a Speed400 firmly so I am not really surprised. Only took 2 minutes with a Dremel to grind off the bits that touched. A sharp blade would do the job.
I'm at work at present - don't tell the boss! - but as soon as I get home I think I can put my hands on a magazine with ads for companies selling the brand in the USA.
I'll also post a flight test as soon as I can find the time to toss it in the air!
I'll also put a video on my web site as soon as I can:
http://www.numbthumbsandloopy.net
Cheers
Numb Thumbs
Ps My 12 year old son is Loopy and I am sure he will THOUROUGHLY test the TwinStar II with these motors!
Old Jul 19, 2005, 09:56 PM
dmiller is offline
Find More Posts by dmiller
We got planes to build
dmiller's Avatar
Dallas, TX
Joined Sep 2001
...........It would be interesting to know how the "Watts" calculations convert to real energy available! If I am pulling 15 amps at 11 volts that is a theoretical 165 Watts, but I'd bet it has a heck of a lot more grunt than the 220 Watts of the stock setup! So is that where the "efficiency" of brushless comes in???
Cheers
Numb Thumbs
Part of the equation is efficiency, but you said you are now spinning a 7x4 prop at 10,000 rpm. The stock motors and props were spinning at ~13,000 and are a 4.5inch pitch. So what you are trading is pitch speed for more thrust. You can spin a large prop real slow and get plenty of thrust, but pitch speed will be real slow, or on the same wattage you can spin a small diameter prop real fast with low (relatively) thrust but high pitch speed. The trick is matching speed and thrust to your plane.
Dave
dmiller is offline Find More Posts by dmiller
Old Jul 19, 2005, 11:52 PM
Joined Sep 2000
Cheers
Numb Thumbs
Strange - same rpm more thrust? Your rpm figure should be higher now.
The 220W is "Power in". At 12.8A the motors are running at less than 50% efficiency, i.e. motor shaft power per motor is less than 50W.
Your brushless motors at 7.5A probably run at approx. 75%, i.e. you have almost 62W motor shaft power per motor.
Bigger props are usually also more efficient than smaller props, but also the pitch speed needs to suit the model for good performance.
During launch at full throttle the standard Permax 400 are pretty inefficient with the Günther props. Cruising along at 30mph at half throttle things look a lot better. Current per motor is now down to a mere 5A and the motors run at approx. 70% efficiency - even the brushless motor is not that much better here (but stills turns the more efficient bigger prop).
Jürgen
Old Jul 20, 2005, 12:26 AM
Joined Sep 2000
Cheers
Numb Thumbs
Warning: I wouldn't consider the BEC of a 10A ESC capable to support 4 powerful servos in such a model. With 2 Lipos Ok, but with 3?
Jürgen
Old Jul 20, 2005, 04:19 AM
Joined Sep 2004
Himark outrunners
Mickydee
I got mine from Roj's Hobbies:
http://www.rojshobbies.com/Electric%20planes.html
If necessary I'm sure he could send you some! Bottom of this page, right hand side called Himark C2808 - 26.
There is a pile of figures on them here:
http://www.daddyhobby.com/forum/showthread.php?t=3021
I have not seen them on any USA sites yet, but I can't say I have been looking all that hard! They may well be called something else in the USA.
Aircraft World might be worth a try, but their web site seems to be down at present so I can't look for you.
http://www.aircraft-world.com
There are bound to be other outrunners with similar figures to the Himark ones.
Good luck!
Cheers
Numb Thumbs
Old Jul 20, 2005, 06:11 AM
maverick6 is offline
Find More Posts by maverick6
Joined Feb 2005
Hello !!
Here is my twinstar 2 : http://img301.imageshack.us/my.php?i...tar20030qe.jpg
It it weighs approximately 1350g with my 8/kan2000 pack.
maverick6 is offline Find More Posts by maverick6
Old Jul 20, 2005, 06:19 AM
Joined Feb 2005
it's an old photography, since, I completely sandpapered it
sorry for my english ...
Old Jul 20, 2005, 06:40 AM
Treetop is offline
Find More Posts by Treetop
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
maverick6, nice pic, your English is fine, where are you from?
Does the TSII fly well with the Kan2000 8cell? I am estimating about 350 grams for that pack, do you get much flight time? tt
Treetop is offline Find More Posts by Treetop
Old Jul 20, 2005, 06:55 AM
Joined Feb 2005
My ts2 didn't fly for the moment.
I bought 2 8/kan2000 pack, that will give me a sufficient autonomy ( I think ). ( a good time of flight ??? ).
I study Russian in first language and I am study in the college (in France).
Old Jul 20, 2005, 07:24 AM
Treetop is offline
Treetop's Avatar
Joined Feb 2004
Thank you, keep us informed when you have the maiden voyage! tt
(speaks only English )
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
