Old Mar 11, 2006, 01:33 PM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
I don't think so, Bill! If run at or below the rated 12 A current, I don't think these motors are going to make 1:1 thrust, though they might come close.
Amazing how well that Twinstar II hovers, with those small control surfaces and zero elevator input to correct for that not quite 90-degree pitch angle.
-Flieslikeabeagle
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
Old Mar 11, 2006, 04:06 PM
THE WALRUS is offline
Find More Posts by THE WALRUS
halifax nova scotia canada
Joined Dec 2004
I am having trouble trimming out my TS ll. I am using four Hitec 81 mg servos and a Futaba R127DF receiver. The radio I am using is a Futaba 6EXAP 6 channel computer radio. The rudder and elevator are no problem to set but I am having trouble setting the ailerons. I am using channels 1 and 6 for the aileron servos . Should I use the flaperon mix for the two servos . The trouble I am having is to get the ailerons to go up 18mm. but down only 10mm. as the manual suggests. THE WALRUS
THE WALRUS is offline Find More Posts by THE WALRUS
Old Mar 11, 2006, 04:12 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Simply swing the servo arms forward so they are angled towards the wing leading edge by 30 degrees or so when the ailerons are neutral (centred).
Bill Glover is online now Find More Posts by Bill Glover
Old Mar 11, 2006, 04:14 PM
Joined Nov 2000
OK I confess, my Super Star does hover though
Old Mar 11, 2006, 06:03 PM
Treetop is offline
Find More Posts by Treetop
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
Bill, what is the deal on the hovering TSII? Nice pic. tt
Edit: You funny! got me!
beagle is so observant!
Treetop is offline Find More Posts by Treetop
Old Mar 11, 2006, 08:31 PM
jcosta is offline
Find More Posts by jcosta
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
Ok, just reread the manual.
1 - Use the flaperon mix
2 - Adjust up throw with the EPA (end point adjustment)
3 - Adjust the down throw with differential in the Flaperon mix. For the down throw you mention it should be 45%
Ask if you have any more doubts.
jcosta is offline Find More Posts by jcosta
Old Mar 12, 2006, 12:22 AM
Got shenpa?
Los Angeles
Joined May 2004
TT, us flying beagles have to be observant - it's necessary for survival. We beagles are poorly equipped by nature when it comes to weaponry, and between the continual threats of attack from hawks, vultures, and opinionated RC pilots, we have to be alert at all times!
Made some progress on my TS-II today. I cut and soldered extensions to the aileron servos, speed control signal leads, and speed control power leads. I finished routing channels in the wings for all the extra wire, cut away more foam to make room for the Spektrum AR6000 receiver in the center of the wing, and have just started to glue the two wing halves together.
Actually what I did was tack-glue the carbon spar into one wing half (without the foam retainer strip on the underside, wait a few hours for the CA to set, and now I've just positioned the second wing half onto the carbon shaft and applied CA to tack-glue it too to the shaft. I'm using masking tape at the TE and LE of the wing halves where they join to ensure both are at the same incidence angle (the TE's and LE's of the two halves mate up as they should).
Tomorrow I hope to finish routing and soldering up all the leads, and install the receiver. I still have to crimp and solder on some servo connectors and do some creative wiring - I have to make a final decision whether to use my switching BEC, or split up the load between the two BEC's in the two Thunderbird 18 ESC's, two servos to each.
If all goes *very* well I should have everything together and ready for a test flight by evening, but we'll see how many unexpected distractions come up.
Now it's off to hang out with the wife and watch a DVD together. It's a cold night by LA standards, good for snuggling with your honey!
-Flieslikeabeagle
Old Mar 12, 2006, 12:46 AM
Treetop is offline
Treetop's Avatar
Joined Feb 2004
Well, seems beagles like to fly "on the prop".
Old Mar 12, 2006, 04:35 AM
Joined Nov 2000
That will probably work, but if you're never going to deflect the ailerons fully down then it's mechanically more efficient to angle the servo output arms as I suggested.
Old Mar 12, 2006, 04:39 AM
Joined Nov 2000
All this mega-power brushless talk tempted me
I could easily have given it some control surface deflections - the TS2 was screen-grabbed from my AFPD sim.
But I thought leaving a clue or two was the decent thing to do
Old Mar 12, 2006, 11:35 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
Whatever you do, make sure you don't rush through this build.
Jeremy Z is offline Find More Posts by Jeremy Z
Old Mar 12, 2006, 12:21 PM
Got shenpa?
Los Angeles
Joined May 2004
Jeremy, I haven't heard all that much about you rushing through yours, either! What's the state of your TS-II at the moment?
Not to bore anyone with details, but in the last few weeks, when I haven't been working or asleep, I've been too exhausted to do any building.
-Flieslikeabeagle
Old Mar 12, 2006, 12:32 PM
Got shenpa?
Los Angeles
Joined May 2004
This comes down to opinion again, of course, but Franck's brushless setup (300W, IIRC) might reasonably count as mega-power.
But IIRC, it was mentioned earlier in this thread that the stock setup has each motor pulling some 12 A (and conseqently running at about 45% WOT efficiency), from, I think, a 7-cell pack. That's about 168 W into the motors. The twin 400XT setup (and the Typhoon setup just discussed) pull about the same or a bit less current - 10 A per motor for 400XT's - off a 3S lipo pack. That's about 200W into the motors, so these upgrades draw only about 20% more power from the batteries than the stock brushed setup. Not a huge increase, really.
Due to the poor efficiency of the stock motors, the actual power making it to the props at WOT will be only 45% of 168 W, or about 75W. The 400XT's run at about 75% efficiency WOT, so 75% of 200 W will make it to the props - that's 150W, or 200% more than the stock setup!
That's where these brushless hop-ups show their benefit: the battery isn't being asked to put out much more power than with the stock setup, but about twice the power consumed from the battery is actually making it to the props instead of heating up the motors.
-Flieslikeabeagle
Old Mar 12, 2006, 12:39 PM
Got shenpa?
Los Angeles
Joined May 2004
Dunno, TT, looks to me more like Snoopy's flying "on the roof"
-Flieslikeabeagle
Old Mar 12, 2006, 01:32 PM
kaiser_solsay is offline
Find More Posts by kaiser_solsay
Crieff, Perthshire, Scotland
Joined Jun 2005
Thanks for your advice Beagle, your knowledge never ceases to amaze!
Cheers
kaiser_solsay is offline Find More Posts by kaiser_solsay
The Mpx Micro-Jet has arrived! (Part II) flieslikeabeagle Foamies (Kits) 57 May 06, 2007 10:32 PM
Discussion MPX Twinstar II in Australia maxy333 Foamies (Kits) 1 Feb 25, 2006 03:25 PM
Yippee! MPX Twinstar II maidened today!! Chetto1965 Electric Plane Talk 10 Feb 08, 2006 01:09 AM
Discussion MPX Twinstar II configuration? Chetto1965 Electric Plane Talk 9 Jan 05, 2006 01:20 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
