Old Jun 09, 2005, 03:38 AM
philipnow is offline
Find More Posts by philipnow
S. Calif.
Joined Mar 2005
Mega 16/7/6, 16/7/10, or 16/15/5?
I've spent several evenings reading through many threads in this forum and playing with MotoCalc, trying to decide on a brushless setup to replace the speed 400 in my T-Hawk. Although it might be reasonable to question putting a brushless in this sort of model, I do enjoy flying it and want to use the experience of upgrading my T-Hawk's power system to prepare me for work with future models.
Anyway, the T-Hawk, like the Easy Star and other pusher models, is limited to a propeller of no greater diameter than 6 inches. I want good solid performance, but am not trying to break any speed records. I think I want to use a can type non-outrunner motor. I like the looks of the Mega's.
Experimenting with newly acquired MotoCalc has raised several questions, the answers of which I seek from the many experts in this forum:
1.) Within a given motor series, the Mega 16/07/x series, for example, and given an approximately constant propeller size and pitch (due to my model's constraints), is it best to choose A.) a motor with less turns/higher Kv run at lower voltage (e.g. Mega 16/07/06, 2s Lipo) or B.) a motor with more turns/lower Kv at higher voltage (e.g. Mega 16/07/10, 3s Lipo), and why?
MotoCalc Details:
A.)
Motor: Mega ACn 16-7-6; 2850rpm/V; 0.9A no-load; 0.041 Ohms.
Battery: Apogee 1570; 2 cells; 1570mAh @ 3.7V; 0.012 Ohms/cell.
Speed Control: Castle Creations Phoenix 25; 0.0065 Ohms; High rate.
Drive System: 6x3 Propeller; 6x3 (Pconst=1.31; Tconst=0.95) direct drive.
Airframe: T-Hawk; 217sq.in; 16.1oz; 10.7oz/sq.ft; Cd=0.05; Cl=0.42; Clopt=0.72; Clmax=1.05.
Stats: 113 W/lb in; 95 W/lb out; 17mph stall; 21mph opt @ 57% (47:27, 90F); 27mph level @ 71% (33:32, 93F); 1109ft/min @ 37.5; -172ft/min @ -5.4.
B.)
Motor: Mega ACn 16-7-10; 1700rpm/V; 0.45A no-load; 0.0975 Ohms.
Battery: Apogee 1570; 3 cells; 1570mAh @ 3.7V; 0.012 Ohms/cell.
Airframe: T-Hawk; 217sq.in; 17.4oz; 11.5oz/sq.ft; Cd=0.05; Cl=0.42; Clopt=0.72; Clmax=1.05.
Stats: 88 W/lb in; 76 W/lb out; 18mph stall; 22mph opt @ 65% (68:05, 89F); 28mph level @ 81% (48:07, 91F); 853ft/min @ 26.8; -179ft/min @ -5.4.
2.) Or would it be better to accept the slight weight penalty and chose a motor from the 16-15-x series, such as the 16-15-5, and why?
MotoCalc Details:
Motor: Mega ACn 16-15-5; 1800rpm/V; 0.8A no-load; 0.068 Ohms.
Airframe: T-Hawk; 217sq.in; 18.4oz; 12.2oz/sq.ft; Cd=0.05; Cl=0.42; Clopt=0.72; Clmax=1.05.
Stats: 101 W/lb in; 86 W/lb out; 18mph stall; 22mph opt @ 63% (56:39, 91F); 29mph level @ 79% (38:49, 93F); 982ft/min @ 30.3; -184ft/min @ -5.4.
3.) For some scenarios in the MotOpinion readout it says "The static pitch speed is greater than 3 times the model's stall speed..." How important is that?
4.) When I plug in the numbers for certain propellers, such as a 5.5 X 4.5, the MotOpinion indicates that "The diameter (5.5in) to pitch (4.5in) ratio is less than 1.5:1, which will result in reduced propeller efficiency at low speeds (the propeller is stalled). Although this is not likely to affect flying characteristics, it may make take-off or hand launching difficult." How important is this? I see many individuals describing successful setups with propellers with ratios less than 1.5:1.
Thank you for any advice!
philipnow is offline Find More Posts by philipnow
Old Jun 10, 2005, 11:52 AM
S. Calif.
Joined Mar 2005
Any opinions on possible setups?
Old Sep 19, 2005, 11:07 PM
S. Calif.
Joined Mar 2005
Since my query didn't seem to generate a great deal of interest in this subforum, I have posted my experiences upgrading the power system of my T-hawk here (post 69).
Old Sep 20, 2005, 08:17 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
There are other motors of the "Speed 400" form factor besides the Megas - RCer Warp4 and Medusa 028-032-xxxx to name two. The two ourunner-in-a-can motors from Ultrafly also - one of these is probably the right Kv to work with the prop size limitation in the T-hawk.
BEC is offline Find More Posts by BEC
Old Sep 21, 2005, 12:12 AM
S. Calif.
Joined Mar 2005
Thanks for your suggestions BEC... I was strongly considering the Medusa MR-028-032-1900. I ended up getting a Mega 16-7-10, because the MotoCalc numbers gave it the edge (I don't yet have enough experience to know how much credance to give to the Motocalc results). It gives good power -- all the power I want -- with a PQ 1800 lipo and a Aero-naut 6.5 X 4 prop I managed to squeeze in with a little Dremeling.
Discussion Please advise on brushless setup for ehawk 1400 nickchew Sailplane Talk 3 May 10, 2007 02:37 AM
Discussion Feigao brushless setup for T-IFO Alan T. Scratchbuilt Indoor and Micro Models 3 Mar 28, 2007 10:07 AM
Question advice on brushless setup for FVK Spitfire kipduff Electric Warbirds 1 Aug 31, 2006 06:47 PM
Brushless setup for Corona. Please help! larsen2000 Electric Heli Talk 5 Jul 03, 2005 02:24 PM
WTB EDF brushless setup for T-33 Vamooska Aircraft - Electric - Airplanes (FS/W) 4 May 10, 2004 09:00 PM
