Old Apr 17, 2002, 02:54 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Need ball bearing help
I need some ball bearings. I've been looking in Tower Hobbies catalog.
When they give a specification of 3/16 x 3/8" is that the ID x OD?
Thanks!
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Apr 17, 2002, 05:53 AM
FlyinBrian is offline
Find More Posts by FlyinBrian
Northampton, UK
Joined Jan 2001
Yes thats what it will be, you also may need to know the width of the bearing to check it will fit in the housing.
There is a good discussion on bearings (allbeit in reference to IC motors) on the UK based RC Flyers web site, see > http://www.websherpa.co.uk/cgi-bin/yabb/YaBB.cgi#quest
You will find your bearings much cheaper from a bearing suppler rather than a hobby outlet.
Brian
FlyinBrian is offline Find More Posts by FlyinBrian
Old Apr 17, 2002, 11:48 AM
Duke58 is offline
Find More Posts by Duke58
Whispers in the Wind
Duke58's Avatar
Hayward, CA
Joined Apr 2001
RB if you go to a supplier be prepaired to work in metric , bearings don't really come in fractional sizes.
Duke58 is offline Find More Posts by Duke58
Old Apr 17, 2002, 01:00 PM
JimO is offline
Find More Posts by JimO
Hacienda Heights, CA
Joined Sep 2000
RB
Here's a good source for bearings, both inch and metric sizes, once you've determined the size you need.
http://www.bocabearings.com/
Jim
JimO is offline Find More Posts by JimO
Old Apr 17, 2002, 02:33 PM
Newark, DE USA
Joined May 2001
Hi guys,
Thanks for the help. I want to get them from Towers since I can get other things to make shipping worthwhile. I don't need exact dimensions such as thickness since I'll be using them to cobble together chain drive propellers for a Wright Flyer.
RB
Old Apr 17, 2002, 03:18 PM
Rekit is offline
Find More Posts by Rekit
Garland, Texas
Joined Jul 2000
Bearings also have a speed rating, if the bearing will be subjected to high speeds or excessive side loads some bearings will not support those situations. Just make sure and check with the supplier to see if the bearing will be satisfactory for your application
Rekit is offline Find More Posts by Rekit
Old Apr 17, 2002, 05:34 PM
Newark, DE USA
Joined May 2001
Thanks for the tip Rekit. So far I've been looking at RC car wheel bearings. I think they'll be ok.
RB
Help! Need ball bearings for GWS 300 gear boxes poobs Power Systems 4 May 17, 2008 09:53 PM
Need Some PC Help Sligh Life, The Universe, and Politics 10 Oct 02, 2001 08:27 AM
Need A New Battery! Help! AirVenture Beginner Training Area (Aircraft-Electric) 11 Jul 14, 2001 02:12 PM
Ball bearing verses sleeved gearbox mudhead Power Systems 3 May 31, 2001 09:15 PM
Need power connector help Red Baron 47 Parkflyers 10 May 30, 2001 01:24 AM
