Old Jul 28, 2005, 12:41 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Bill,
Thanks for the data!
Mike,
Thanks for sharing this link so, I can take notes!
I rather was curious since my new AXI 2820/10 and 2826/10 felt rather light? I purchased these two motors during the big sale at Hobby Lobby and saved Big!
From all the data above, seems like the these two motors are going to be perfect for my planned applications.
Thanks guys!
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Jul 28, 2005, 01:39 PM
Stevens AeroModel is offline
Find More Posts by Stevens AeroModel
Truss-Loc Monkey
Stevens AeroModel's Avatar
Colorado Springs, CO
Joined Feb 2002
Remember, these are High Alt numbers - at Sea Level you're going to see the similar numbers with 1" less diameter and 1-2" less pitch.
-Bill
Originally Posted by guapoman2000
Bill,
Mike,
Thanks guys!
Carlos
Stevens AeroModel is offline Find More Posts by Stevens AeroModel
Old Jul 28, 2005, 02:41 PM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Bill,
So based on the fact that I am close to sea level (664ft. msl) I could go with an apc 12x6e and get similiar numbers as a 13x6, 13x8 at 6,000ft? Just wondering because the 12x6e was what I was going to use to start and then move up to a 13x6.5 after the batteries were broke in. But it sounds like the 13x6.5 may be to much prop with my planned setup with phx-45 when it comes to amp draw maybe. I know I am looking to get unlimited vertical from the plane and would like to do pattern/little 3d with the setup that I am trying to work out.
Thanks for the feedback Bill it has been a pleasure working with you through several threads here on rcgroups as well as the feedback I have received from your website(Regards, Hos). Not often do you find a plane manufacture taking time to help others build and fly there products like you have with so many. Much Appreciated!!
Tim
-Bill
sun.flyer is offline Find More Posts by sun.flyer
Old Jul 28, 2005, 08:36 PM
Account closed
Joined Oct 2002
Question about Radial Mount for 2820 & 2826
I heard that if you don't install that aluminum securing coller that the C-Clip was not strong enough such that the motor housing will slide out when operating the motor in the butt first way?
Therefore, at the hobby store they told me it is very important to have this securing coller installed otherwise you may lose motor and model.
Correct?
Old Jul 28, 2005, 11:46 PM
mrm1 is offline
Find More Posts by mrm1
Fly a LiL' Lower Will Ya!
mrm1's Avatar
North Central Florida
Joined Sep 2004
Covering the Tail Feathers - Easier than You Think
Well Just came in from the shop. Had time to get the Elevator and Horizontal stab completed. Total time on these pieces - 4 hrs -
OK, so no speed record were set. But I was in a learning curve.
I am very happy with the finish product. I wish that the yellow was less transparent. But the sacrifice is weight, and I am going for a "light as possible" ship.
Any way, here are the pics. Covering is really quite simple - at least with this low heat, thin Solite Film.
mrm1 is offline Find More Posts by mrm1
Old Jul 28, 2005, 11:48 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
On the blue meets blue, the seams blended to a near invisable state.
If you look close at the elevator, you will see where I did the blue underside first and then the yellow. on the Stab I did the yellow first and then the blue bottom. Results was a much nicer look doing yellow first.
Old Jul 29, 2005, 06:54 AM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Mike, nice work!! Looks great so far, who says you need a "master craftsman" to cover the plane. I agree on the dark color over the light, hides a little more. Thanks for the pics. looking forward to seeing the final product (as I'm sure you are to).
Tim
Old Jul 29, 2005, 09:00 AM
Account closed
Joined Oct 2002
Super Job Mike!
I know now where to take my models for covering
Old Jul 29, 2005, 09:16 AM
unbalanced prop is offline
Find More Posts by unbalanced prop
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
Yeah.................REAL nice job Mike. Looks like you been covering for years.
Doug
unbalanced prop is offline Find More Posts by unbalanced prop
Old Jul 29, 2005, 12:04 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
Tail Ready
Thanks everyone.
Times are coming down as I do more and more pieces. I think the Rudder and Vert Stab took me about half as long as the Horizontal Stab and Elebator. And the Rudder/Vert had curved ends too. (though not sure if they are suppost to be curved or not - But I like it)
My only problem was that while applying the red to the tip of the Rudder/Stab, I dropped the knife and poked a hole thru both sides. fortunately it was the blue, and the Solite blue blends and hides seams real well, so 2 small patches are hardly noticable.
So far I could not be happier with my first attempt at a cover job.
Old Jul 29, 2005, 12:09 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
I especially liked the challenge the of 2 color rudder. What I did was size up a piece of blue and straight cut the bottom edge where I wanted the seam. Then cut a piece of yellow large enough to finish the rudder side.
Taped the yellow finish side up tight to my cutting mat, and then pealed the clear plastic off the blue. Seamed the 2 peices. Flipped them over and cut to shape leaving about 1 inch over laps.
pealed off the clear from the yellow and tacked everything lining up the seam with the lowest horizontal support in the rudder. This made it straight to the model.
And now when I add that blue to the fuse, it will cut thru the fuse and meet the rudder just under the elevtor - basicly splitting the servo trays.
Old Jul 29, 2005, 12:15 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
And you were concerned about what? Covering, good one Mike you almost had us fooled that you had never covered a plane before Looking mighty pretty! Question is the balsa sheeting above the horizontal stab not glued in yet? As I see you have placed the stab/elevator underneath it in the first pic. Thanks
Tim
Old Jul 29, 2005, 12:21 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
Here is a shot of the washer used to make the curve in the blue wing stripes. Notice the larger washer. This is the one I will use to make the curve in the blue stripes on the main wings.
Old Jul 29, 2005, 12:49 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
mrm1 - Great work! If that's your first covering job, I can't wait to see your 2nd or third!
Just read all the motor talk above and thought I'd throw my sea level (~600msl) numbers in:
Old AXI 2820/10 12X6 ~42A 420W
New AXI 2820/10 12X6 ~50A 505-510W
The old AXI I have in my CAP232 40e and it has GOBS of power. I don't hover it. I rarely use WOT except to impress the glow guys.
The new AXI - I use 2 on the Siamese CAP:
http://www.rcgroups.com/forums/showthread.php?t=352940
Last page has link to videos
With a twin there is some synergy so you can afford to be over propped some. Also it's 5lb and 1020W so you don't have to work it very hard.
I've had 10min flights and only used half the battery (batteries).
It's at least twice as much fun to fly.
If I were to install a new AXI in the CAP40e I'd have to go with an 11" prop.
feathermerchant is offline Find More Posts by feathermerchant
Old Jul 29, 2005, 01:24 PM
mrm1 is offline
mrm1's Avatar
Joined Sep 2004
Helpful Guide
I got this about 3 months ago. It has been helpful, but not overly so. Just basicly served to fill in some of the gaps and teach some shortcuts.
I think Monocote alos has a guide to covering on their main web site. That was useful too.
Yippee! My First Kit Build And EDF Plane! ollytindall Electric Ducted Fan Jet Talk 7 Aug 03, 2007 05:35 AM
Discussion What should my first Kit build be??? Merkaba Fuel Plane Talk 4 Apr 30, 2006 06:55 PM
My SA CAP 232 GalantVR4 Parkflyers 10 Sep 17, 2005 06:51 PM
My SA Cap 232 S300 Build Desertraptor Parkflyers 31 Jul 08, 2005 09:02 AM
Got my SA CAP 232 today! EKI16 Parkflyers 5 Mar 16, 2004 07:17 AM
