Old Jun 07, 2005, 12:11 PM
Brad S is offline
Find More Posts by Brad S
Arab, AL
Joined Jan 2002
Kontronik gearbox on Aveox 27/xx/x motor?
I've got a couple of Aveox motors that have been used with MEC gearboxes in sport plane applications. Now I want to use one of them (probably a 27/26/1.5) in an entry level hotliner/warmliner, so need a planetary. I prefer deeper gearing than the 4.4:1 provided by the maxon gearbox and Kontronik offers a 5.2:1. Can a Kontronik planetary gearbox be installed on an Aveox 27 series motor? If so, what would be involved in doing this? Are there other planetary gearboxes with high ratios that would work well with the Aveox 27 series motors?
Brad
Brad S is offline Find More Posts by Brad S
Old Jun 07, 2005, 03:10 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
S400/480 GBs; bolts spacing is the same, though shafts are 2.3 & 3.2mm (1/8”) respectively.
Looks like the PGM have pinions for both and will do 6:1:
http://www.hobby-lobby.com/gear400.htm
http://www.hobby-lobby.com/gear480.htm
jrb is offline Find More Posts by jrb
Old Jun 07, 2005, 05:11 PM
Brad S is offline
Arab, AL
Joined Jan 2002
Thanks for the suggestions Jim. Wouldn't you be a little concerned about running the kind of power levels commonly used in hotliners through those gearboxes? I probably should have provided more details - I expect my initial setup, using the 27/26/1.5, to be somewhere in the 500-600W input range. I've considered using a 27/39/2 set up for ~800W input, but would have to buy another high voltage ESC to do so. I would prefer to find a gearbox that could handle either setup. The Maxon or Promaxx gearboxes are what's commonly used on Aveox motors, but I want deeper gearing to run higher voltage/large prop combinations.
Brad
Old Jun 07, 2005, 10:13 PM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
I have a 27 39 1 with the 5.2 kontronic box . It comes with a 480 size plate for a small extre charge, the problem is the aveox screws are to small to center right in the holes , there is a bit of play . A machinest friend drilled smaller holes 90 degrees from the stock holes .
jmolwitz is offline Find More Posts by jmolwitz
Old Jun 08, 2005, 08:42 AM
Brad S is offline
Arab, AL
Joined Jan 2002
Yep, I thought this might be the case, since the Kontronik motors use 3mm screws while the Aveox uses 2mm. I have access and basic skills with a mill, so think I can handle this issue. What about the shaft length/pinion axial position - any issues there? If you had it to do over again, would you buy and retrofit the Kontronik gb, or opt for a different one? Thanks for the info!
Brad
Old Jun 08, 2005, 02:18 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Brad,
I use a piece of tubing to make the 2mm screws fit snuggly in larger diameter holes; then they’re loaded in shear and be able to handle the loads between the motor and GB.
Wonder if the 450W limit is for the GB, or max of the Mini AC?
I think they can probably handle the loads with a bit of a soft start; a real hard brake – ok too?
Jim
Old Jun 08, 2005, 05:56 PM
Brad S is offline
Arab, AL
Joined Jan 2002
Thanks for the tip on the tubing screw sleeves Jim. Might even take this idea a step further and turn some T-sleeves on the lathe to provide improved load distribution on the screw head.
Brad
Old Jun 08, 2005, 10:36 PM
jmolwitz is offline
Fairfield Ct USA
Joined Apr 2002
Brad
Its easy to trim the shaft with a grinding wheel if you have to and the pinion goes on with loctite so the rest was easy and the kontronic box is second to none in quality , and with parts avalible it should wear well . I'm sure this box can handle 1000+ whatts
WTB: Gearbox for Aveox 27/39/xx Cas123 Aircraft - Electric - Airplanes (FS/W) 6 May 26, 2004 09:47 PM
WTB: Aveox 27/26/1 motor kyril Aircraft - Electric - Airplanes (FS/W) 0 Sep 17, 2003 08:50 PM
How to install a VMG gearbox on a Mega 22/30/x Bill Germanson Power Systems 2 Jul 15, 2003 08:42 PM
Question KOKAM 3270 on AVEOX 27/13/3 SL-18 ESC ramses787 Batteries and Chargers 1 Dec 31, 2002 09:35 AM
WTB Aveox 27/13/3 Motor or simular jsc Aircraft - Electric - Airplanes (FS/W) 0 Jun 24, 2002 09:31 PM
