Go Back   RC Groups > Article Archive > Liftzone Archive
Featured In
LiftZone
Intro
The Mini Ventura is a complete R/C park flyer/glider. It offers good performance for small fields.
Hobbico's Mini Ventura RTF Park Flyer/Glider Review
Article Stats
Hits:  37136
Ready to go in just minutes
Wingspan: 31.5"
Wing Area: 120 sq. in.
Weight: 9.1 oz.
Length: 20"
Wing Loading: 10.9 oz/sq. ft.
Servos: 2 Micro Servos
Transmitter: 27Mhz, 3 channel included
Receiver: 27MHz, 3 channel
Battery: 5x600mAhr NiMH (AAA size)
Motor: 180 class brushed motor
ESC: Included
Manufacturer: Hobbico
The Mini Ventura, like its big brother, is a complete R/C flight package. It includes everything you need, save 8 AA batteries for the transmitter, to get in the air. Sold under the FlyZone brand of Hobbico, it is a nice addition to their line of Ready to Fly airplanes.
Like I said, the Mini Ventura is a complete package and comes almost ready to fly. The only thing you will need in addition to the kit, are 8 AA batteries for the transmitter. Everything else is included, including a field charger and spare parts.
Opening the box, you'll find that everything is neatly packed. Major parts are bagged and the flight pack is secured in a separate compartment so it doesn't damage the rest of the airframe. The wing and tail surfaces are foam with a thin skin for extra toughness. The wing has a strip of fiber reinforced tape on the bottom for additional strength. The rudder and elevator are hinged with clear tape and come with the control horns installed. My wing arrived with a few creases in the top skin near each wing tip. While I didn't think that the strength of the wing was compromised, Hobbico sent out a replacement. The decals were already applied and dress up the all white airframe.
The fuselage is constructed from light plastic and comes with all of the electronics installed. Two micro servos are screwed to a plastic frame which in turn is screwed to the fuselage. Pre-bent music wire pushrods are hooked up and ready for the tail surfaces. The receiver is secured to the fuselage side with double sided foam tape. Right below the receiver is the ESC. The canopy is hinged at the rear and a rubber band keeps it closed during flight. Looking under the canopy, you'll find a 180 class motor with noise suppression caps. A piece of foam behind the motor protects it from the battery pack which is held in place with Velcro hook and loop material. The only complaint here is that the Velcro seems stronger than the adhesive holding it in place.
The ESC has a push button arming switch to help prevent motor startups while hooking up the battery or checking out the control throws. A folding propeller comes installed which should help to avoid breakage during landings. There was no information available on the propeller, but it is 4.75" in diameter and I would estimate the pitch at 3" to 4". This should get you in the ballpark if you want to experiment with propellers.
The transmitter unit is nicely made and of the single stick variety. A finger tip, proportional control is on the back for throttle control. An on/off switch is on the front and two LEDs report the battery status. Also on the front are servo reversing switches for the rudder and elevator. The radio system operates on the 27MHz band and 6 channels are available for the Mini Ventura. Since this is the same band used by surface craft (cars and boats), it would be prudent to check around your flying site for any R/C car drivers prior to your maiden flight. Since I sometimes fly in my front yard, I made sure to check with my neighbor who runs his cars down our street.
Rounding out the kit is a re-sealable bag of hardware and spare parts (propeller, rubber bands, and nuts), a 5x600mAhr battery pack (AAA size), a field charger (with spare fuses), an instructional DVD, and a 15 page manual. The manual covers assembly, safety, and basic flying. This kit is billed as a beginner R/C model, and Hobbico recommends joining the AMA and seeking out help of an experienced modeler. While park flyers offer the convenience of being able to fly at your local soccer field, we must also make sure we fly in a safe and controlled manner. I appreciated Hobbico's support of the AMA. The DVD offers the same information in the manual, and shows the Mini Ventura in action. The assembly is so easy and the video is very well done, that you could almost skip looking at the manual.
The assembly of the Mini Ventura consists of screwing the tail on, attaching the wing with rubber bands, installing the batteries and charging the flight pack. My 5 year old son helped me and it only took a few minutes to have it ready to go.
The control rods are attached to the control horns on the rudder and elevator. The fin comes with two threaded rods installed. These rods go through the stabilizer and the fuselage and the whole assembly is secured with two thumb nuts. No tools are required! The only thing you may want to do is cut off the excess threaded rods, but it is not necessary. Two spare nuts are included, just in case. Later, after mounting the wing I noticed that the fin and stabilizer were not square with the wing. There was no mention of this possibility in the manual. I simply twisted the fin and stabilizer until they lined up properly. I recommend that you make sure everything is lined up before flying.
After installing the batteries in the transmitter, any necessary adjustments to the controls are made. I needed to bend the elevator control wire a bit to center the elevator, so you may want to have some needle nose pliers on hand for assembly. There are three holes on each of the control horns. The outer hole should be used for beginners, the middle for intermediate flyers, and the inner hole for advances pilots. I started with the middle hole for the initial flights. The control linkages and hinges are very smooth with no binding or excessive drag.
The final assembly task is to balance the model. The wing is held in place with 4 rubber bands (2 spares are included). I marked the bottom of the wing at 1" and 1.25" behind the leading edge as called out in the manual and put the battery pack in place. My Mini Ventura balanced near 1.25" with no adjustments. The manual covers what to do if you are outside of this range. If you are a beginner, I would recommend adding some weight to the nose if necessary to keep the balance point at 1".
With absolutely no modifications or additional balancing weight, my Mini Ventura weighs in at 9.1oz. This is a bit more than the 6.7oz. advertised on the box. It only took a few minutes to get to this point, so it is very possible to fly within moments of opening the box. The assembly is so quick, that you may want to start charging the battery first.
The charger included is a basic constant current charger. It comes with a cigarette lighter adapter and the connector for the battery pack can be swapped out for other Hobbico products. A mechanical timer sets the amount of charge into the battery. Before I charged the pack, I had read the manual and listened to the DVD and there was a conflict on the time necessary for a full charge. The manual said 40 minutes and the DVD said 20 minutes. There was not too much information on the charger, so I put in a call to the product support line. The charger puts out 1.5A, so to fully charge the 600mAhr pack will take about 20 minutes (1.5A x 1/3hr = 500mAhr). Since this is a constant current charger, the manual strongly recommends that you closely monitor the battery pack during charging and stop charging immediately if the pack gets hot. Keep in mind, that if you don't start with a fully discharged pack, it will take less time to fully charge it. Also, make sure you have the correct voltage setting on the charger before you start. While I wouldn't expect a full blown peak detecting charge with such a package, beginners should understand that this type of charger can be hard on your battery packs if you charge too long.
The Mini Ventura came with two spare fuses, but there was no mention in the manual of what they were for, and nothing obvious on the plane. After asking the tech support guy at Hobbico, I noticed the removable tip of the cigarette lighter adapter on the charger, Doh!
I was unable to get a good current reading of the power system, but the manual claims that the motor can draw about 7A. With the 5 cell pack this would give an input power of 35W. With the 9.1oz flying weight, that gives a respectable 61W/lbs. power loading. While this won't be a hotliner, it should have sufficient power to fly well. With a freshly charged pack, the direct drive motor spun up the propeller at a little over 12,000 rpm, which gives a motor Kv of approximately 2400rpm/V.
After a quick ground check, and making sure the guy next door wasn't running his cars, I was ready for the first flight. It was less than optimal conditions with a damp overcast and a gusty breeze. I applied full throttle and gave the Mini Ventura a quick toss into the wind. What resulted was a quick test of the durability of the airframe. The gusts toss the plane around a bit and my mild toss did not give it enough airspeed to overcome it. It teetered on the edge of a stall, caught a wing tip and cartwheeled in. I walked over, picked it up and gave it a good going over. The wing had shifted a bit, but otherwise there was no damage.
For the next attempt, I gave it a firmer toss and the Mini Ventura climbed out nicely. At full throttle, it settled into a nice climb and I added in a bit of down trim to level it out. There is a noticeable change in trim from full throttle to glide. It may be desirable to put in some down thrust in the motor. I gained some altitude for some stall tests. I always like to get this out of the way, so I know what to expect when coming in for a landing. I throttled back and increased the elevator input until the motor stopped and I was holding full up. The Mini Ventura tracked straight ahead and started to porpoise a bit and then suddenly it dropped a wing tip. To recover I just needed to let off the elevator, let it pick up some speed and pulled out of the dive. This is with the balance point at the aft end of the recommended range. I added some weight to the nose which resulted in a small improvement to the stall. I would recommend that beginners keep the the balance point at the forward edge of the recommended range.
With the control rods in the intermediate setting, it is hard to get into trouble with the Mini Ventura. This is not to say that it is not fun. Full left or right results in a nice turn and does not come close to stalling it. While I will eventually move to the "advanced" settings, I think the intermediate setting should be sufficient for most newer pilots. With the power off, the glide angle is relatively steep. You need to keep up the speed or it will start to mush along, this is your warning to pick up some speed before it stalls. The manual talks about it being a park glider, but I think you would need some strong lift to keep it up. Also, the climb rate is not all that great, so getting up to an altitude where you could hunt for thermals may take a while. With the motor running the Mini Ventura handles nicely and I noticed no bad tendencies. The throttle resolution is very course. At full throttle the model is climbing, and one notch less is not enough to keep it in level flight. It moves out fast for its size and will tolerate a moderate amount of wind. You need to keep up the speed on landings until you are lined up on final, but the Mini Ventura will tell you when it is flying too slow. Just keep the wings level and flair a bit before touch down. The airframe has proved durable and rugged.
Aerobatics
While this is a beginners park flyer, it is capable of basic rudder/elevator aerobatics. Loops require a bit of a dive on entering. If you don't have enough speed to carry you through the loop, the Mini Ventura will fall out at the top. Stall turns are fine, but again you will need some speed to help with the vertical. Snap rolls are surprisingly good. Just use full up and full right or left and it will snap right around. Releasing the controls stops the the roll immediately. I have not tried inverted flight due to the under cambered wing.
Is this for Beginners?
This is a hard question to answer. In general I don't recommend that anyone try to learn to fly without a qualified instructor. The Mini Ventura is not a difficult airplane to fly, and with proper instruction a beginner could expect to use this airplane as an introduction to the hobby. This is a rather small airplane and as such it is affected by the wind. I would recommend that beginners wait for calm winds so they can learn what their control inputs do and not have to worry about fighting the wind. The Mini Ventura also has the advantage of traditional control functions and it handles like most R/C airplanes as opposed to some of the other "beginner" type R/C toys.
Flight Video
Type Name
Size
The Mini Ventura in Action (High Res.)
4.80 MB
The Mini Ventura in Action (Low Res.)
612.4 KB
Hits
  • Ease of Assembly
  • Completeness
  • Stock flight performance
Misses
  • Low resolution throttle response
  • Mistakes in manual, conflicts with DVD
The Mini Ventura is a fine performer. This very complete package will get anyone in the air in a hurry. The stock performance is adequate, and will not leave you looking for more power to get the thing to fly. There were some minor typos in the manual, but the ease of assembly really makes this a non-issue. Hobbico has put together a nice package that will satisfy the park flying needs of beginners and advanced pilots alike.
Thanks to Keith Shaw for helping with the flight video!
Old Jun 06, 2005, 02:53 PM   #2
TIA
Walk??? Snack??? Ball???
TIA's Avatar
Looks really neet!
Would love to see it move after adding Lipo's, Brushless motor, and some carbon wing support.
TIA is offline Find More Posts by TIA   Reply With Quote
Old Jun 06, 2005, 07:21 PM   #3
Just killed one mini v
Last Sat I took the mini V for it,s maiden and it flew ok the first time., had to quit because of the wind.
Today I took it to fly again it gained height (about 30 feet), then stop responding commands (interference?) and just went for a dive from level flight, i cut throtle and tried to apply full up elevator to no avail.
The plane structure is intact but the motor wont run, I notice little green chips from a very little brake in one capacitor.
gcedillo is offline Find More Posts by gcedillo   Reply With Quote
Old Jun 06, 2005, 09:20 PM   #4
Designer/Builder
Jim Young's Avatar
Sorry to hear about your mishap. If possible, try to cut off the capacitor to see if this will correct the motor run problem. The cap may be shorted. You can find replacements at Radio Shack. 0.1uF ceramic disk caps should work fine. If you have a multimeter, check to see if there is any voltage getting through to the motor. This will tell you if the ESC is working. If the ESC is working, I'm sure Hobbico will be glad to sell you a replacement motor.
If had mine at the local flying field with no interference problems. Was there any chance that someone was running an R/C car nearby?
On the hop up side, I think an astroFlight 010 and 2S LiPo would be a cool setup. Can you say one design pylon racing?
-Jim
Jim Young is offline Find More Posts by Jim Young   Reply With Quote
Old Jun 06, 2005, 10:50 PM   #5
Jim I think that maybe someone was using another vehicle with the frequency since the plane was flyng level and sudenly dived.
I,ll try to get the capacitor at RS while my order for two new motors come.
Thanks for your orientation
Old Jun 16, 2005, 11:20 PM   #6
I bought my nephew this plane and we only had it out once. On trying out some hand tosses it would glide in a slight downward path for a LONG time. So we hit the motor switch and flew it for half the field and attempted to land, if we let it continue on the downward path it seemed like we would hit terra firma way to fast, way to hard so I pulled up the nose and it would roll over very quick! Happened several times. We checked balance point and control horn/ pushrod locations and all seems well. The only thing I could think to do was to change the incidence on the tail. After all those handy little thumb screws makes it so easy. Raised up the front of the elevator - that was dumb! Raised the back up the thickness of a paper match [ remember those?] and it helped only a little as it would porpise at a glide. Next attempt was to raise the leading edge a little [ the match thing again ] WHAM hit the sweet spot!!! Now it glides without power or flitting around like a butterfly. Sure it climbs on power but isnt that the idea?
Fly like no one is watching.
Bob
bobby legue is offline Find More Posts by bobby legue   Reply With Quote
Old Jun 17, 2005, 12:26 PM   #7
Designer/Builder
Jim Young's Avatar
Hi Bob,
Thanks for your input on the MV. I found that the Mini Ventura does snap roll if slowed down too much or you put in too much elevator. By shimming up the L.E. of the stab, I think you just limited the amount of up you could up in, and thereby keep it away from stalling. What do you think?
-Jim
Old Jun 19, 2005, 08:21 PM   #8
Similar issue and I don't understand?
Jim, We just purchased this from our local shop today and had a rough landing, not too bad but rough. Immediately it seems the motor is dead (less than 5 minutes air time ) I don't understand what you are talking about the below, I unhooked the motor and attached the multimeter and when I throtled up, the power on the multimeter went down to 0, is this what I should expect, I thought it would be reversed ? More throttle, more power?
Thanks for any insight you can provide!!!
-steve
-Jim
pwcoach is offline Find More Posts by pwcoach   Reply With Quote
Old Jun 20, 2005, 07:07 AM   #9
Designer/Builder
Jim Young's Avatar
Hi Steve,
If you hook up a VOLTmeter to the out of the ESC, it should read close to 0V at low throttle, and for the MiniV it should readover 5V at full throttle. Make sure you have the correct throttle direction on the transmitter.
Other things to check:
1.) Check the motor for physical damage. Will the output shaft turn?
2.) Check the battery voltage, it may have gotten damaged in the crash.
3.) Check the capacitors for shorts.
I hope this helps.
-Jim
Old Jun 20, 2005, 09:42 AM   #10
re: motor voltage
Thanks Jim, that helps.
I may be reading my voltmeter in reverse, as when the throttle is off or prior to pressing the motor start button my voltmeter reads 4 this morning. Then when I throttle up, (after pressing the start), it goes to 0, if I throttle up without pressing the start it stays at 4. Since a voltmeter reads the drop between the leads, is that correct? Or would you say I have a problem with the ESC? (it seems backward to me intuitively)
The capacitors seem fine when looking at them, but then again I've never played with electronics much so ... I'm assuming the capacitors are the green tick size pieces on the motor correct?
I'll be buying a couple of motors today, just to try them out at the worst, I found one for 7.99 so it's worth the $ and time.
Thanks for your patience and knowledge!
Old Jun 21, 2005, 07:23 PM   #11
Designer/Builder
Jim Young's Avatar
Hi Steve,
You are correct about the capacitors.
I'm not exactly sure what is going on with your ESC. I'm an electrical engineer and I have a few ideas, but I don't want to confuse you more with speculation. I'm out of town right now, but will try a few measurements on my MV this weekend.
One more question for you: was the motor running when you crashed? If it was running, how fast did you turn off the motor? If you left the motor on, while the propeller was stopped by the ground, you may have burnt out the ESC. This may explain the wierd readings on your volt meter.
Electric motors are voltage to RPM converters, with a given voltage across the motor, it will draw whatever current it needs to spin at it's design speed. If the motor shaft is stopped, the motor will draw a lot of current to try and get the shaft spinning. The ESC in the MV is only rated for ~10A, so if the motor was stalled for a long time it could have overheated the ESC. If you can get the ESC out of the model, look for signs that the magic smoke was released.
On electric powered airplanes if it looks like you're about to crash, shut down the motor. There is no reason to make the crash power assisted, and it will save your ESC if you don't have a fuse in your power system.
-Jim
Old Jul 03, 2005, 01:50 PM   #12
My experience trying to fly the Mini Ventura was exciting to say the least.
Yesterday I tried to fly it in a slight wind with poor results. It would fly
straight into the wind and upon trying to turn, it would roll over and head
right into the ground. This happened about 10 times.
Upon returning after a second charge to try again, I sprained my ankle
hopping the fence to get to the field. I trudged on any ways. 10 more
flights with the same results but this time I had managed to make at least
one respectable turn until it flipped into the ground again.
I hobbled home, put an ice pack on my swollen ankle, and went over what
went wrong. I came to the conclusion that I must be tail heavy.
So today I added some weight to the nose and set out to the field again.
This time I parked in a different lot to avoid the fence. No way I can climb
a fence now, my ankle is the size of an orange.
After limping out to the field I gave the plane a good toss and it sailed
out across the field, made a nice left, sailed back nice and steady, but
upon making another left it suddenly went for the ground again.
I think I got it now I thought. I launched it again. It sailed out, made a
left, but for some reason I pulled the stick right and before I could correct
myself, it went right into a tree.
There it sat, about 35 feet up in a dead tree. I sized up the situation. It
looked hopeless. I went back home to get a chainsaw but thought it might
be too loud and the houses nearby might hear me so I grabbed a couple
of hand axes and headed back.
After chopping into a two foot wide tree for half an hour I only managed
to cut about 3 inches around the trunk. It's hot and I'm getting careless.
The axe is slipping and near misses to my leg are not making matters better.
What to do next? Throw the axe at the plane of course. I figure the
equipment inside is better than nothing.
So after about 20 some flings I managed to hit the branch and the plane slid
down about 6 inches. This is possible I thought! 20 some more flings, more
branches busting off, and finally the plane fell to the ground!
Upon inspection I found only a slight slice to the wing.
I'll say one thing, the plane sure can take a beating!
That's enough for one day. Who says RC planes aren't fun!
Neurotex is offline Find More Posts by Neurotex   Reply With Quote
Old Jul 08, 2005, 10:52 AM   #13
Flaw in design?
My son just bought one of these last week and we haven't had good luck with it yet. It is built sturdy, but he called me at work and said the motor wouldn't run. Since I'm an Electrical Engineer I started looking into it, measuring voltages and battery capacity. The NiMH were completly discharged, even though my son said he had just charged them. When I went to disconnect the motor to do a direct test on it I found that the power connectors to the motor were not insulated and had shorted together (probably on one of the nose dives)! It appears that the speed control (ESC) is blown from the dead short across its output. We'll be taking it back to the shop that we purchased it from and see what they will do about it (it's obviously a manufacturing defect).
lstevens is offline Find More Posts by lstevens   Reply With Quote
Old Jul 09, 2005, 07:04 AM   #14
Designer/Builder
Jim Young's Avatar
Flaw?
I just checked my MV, and both power connections coming from the ESC have clear heat shrink tubing over them. These connections were hidden under the Velcro for the battery pack on mine. If yours was missing this, then I would call that poor quality control and not a flaw in the design. Under these circumstances, I would think that Hobbico should stand by their product. Please let us know how this issue is resolved.
-Jim
Old Jul 11, 2005, 10:23 AM   #15
Warranty Service
Jim, you're correct, this is a quality control issue - NOT a design issue.
I called Hobbico today and they are sending a new motor and speed control unit, no questions, no hassle!
Article Hobby Lobby's TB-20 Brushless RTF Park Flyer Review dawnron1 Parkflyers 335 Jan 15, 2010 10:12 PM
Article Parkflyers.com's Cessna 182 27mHz RTF Park Flyer Review tailskid2 Ezonemag Archive 22 Sep 23, 2009 02:15 PM
Article Hobbico's Mini Ventura RTF Park Flier Review Jim Young Ezonemag Archive 0 Jun 06, 2005 02:00 AM
Article Hacker Model's Pitts Specialized Profile Park Flyer ARF Review Shoutbanger Ezonemag Archive 4 Feb 03, 2005 08:38 AM
Congratulations SimpleM!
