Old Jun 05, 2005, 10:42 PM
50feet is offline
Find More Posts by 50feet
50feet's Avatar
DELAWARE
Joined Mar 2003
Anybody using a 3s Lipo in their Eco 8? Which one?
I'm going with a 3s pack and I wanted an opinion...
I cant choose between a
Kokam 3200 20c (64 amps)
Poly-tech 3600 12c (43 amps)
Poly-tech 2500 20c (50 amps)
If it matters, Im using a Mega 22/30/3h 1850 kv. Not flying hard or doing 3d. I just want light wieght and good flight time.
50feet is offline Find More Posts by 50feet
Old Jun 05, 2005, 10:54 PM
crashingagain is offline
Find More Posts by crashingagain
crashingagain's Avatar
Sacramento
Joined Nov 2003
I have a 3s2p 4190 Apogee pack in my Eco8, the motor is Jeti 30-3. It works pretty well, I used to use 10 cell 2400 nicads and this pack is much lighter so it seems to have more power. I did have to grind off the battery holders and make a new mount due to the width of the pack and I also had to put it all the way forward to balance.
crashingagain is offline Find More Posts by crashingagain
Old Jun 05, 2005, 11:12 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
I'm using a Polyquest 3S-3100
Art Newland is offline Find More Posts by Art Newland
Old Jun 05, 2005, 11:22 PM
50feet is offline
50feet's Avatar
DELAWARE
Joined Mar 2003
Is that a 12c rated pack? How long are yor flights and do the pack get hot?
Old Jun 06, 2005, 12:00 AM
CD-ROM Junkie
Joined Apr 2001
Getting about 12-13 minutes of SFF and hovering. Pack just moderatly warm.
Old Jun 06, 2005, 05:29 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The best is the new TP-4000 3s2p Pro Lite battery. It provides more power and flight time. It also has balancing taps for the new TP205 balancer this makes LiPo use much safer and it will last longer if you keep it in balance.
No matter which battery you choose you really need to use a balancer the TP205 will work with any battery pack (TP sells taps you can add if you battery does not already have them).
RC Man is online now Find More Posts by RC Man
Old Jun 06, 2005, 08:08 AM
pullin-gs is offline
Find More Posts by pullin-gs
Arlington,VA USA
Joined Jan 2001
Putting together a 3S4P pack using the 10C TrueRC 1000mah cells for my ECO this week. I'll post results soon....I dont expect any dissapointments.
I'm two cells short though.
I'll put my order in today.....thanks for the reminder.
Pullin'
pullin-gs is offline Find More Posts by pullin-gs
Old Jun 06, 2005, 08:12 AM
Kraeuterbutter is offline
Find More Posts by Kraeuterbutter
Kraeuterbutter's Avatar
Europe, Austria, Burgenland
Joined Mar 2002
@Art Newland:
3100mAh and "only" 12C..
it says: 45A bursts..
imo thats not enough for an eco8... ok: enough for flying softly around, but if you once will go over 1500rpm you would see peaks over 50A...
for long flying-time the Prolites 3s2p would be propably the best..
light and lot of capacity...
and good for peaks up to 70A or even more
for maximum Power the Kokam3200 3s1p would be best..
but flyingtime would be a lot less compared to prolites..
Kraeuterbutter is offline Find More Posts by Kraeuterbutter
Old Jun 08, 2005, 10:13 AM
woots is offline
Find More Posts by woots
woots's Avatar
Houston, Tx
Joined Sep 2004
My ECO-8 uses a TP 3S4P which gives 8000 Mah. It flies for 27 minutes.
http://wpenny.rchomepage.com/
woots is offline Find More Posts by woots
Using Ikarus Micro-Gyro with ECO-8? bacarter Electric Heli Talk 7 Dec 13, 2005 09:59 PM
axi in an eco 8 RCAddict Electric Heli Talk 3 Aug 09, 2002 02:26 PM
New figures for the Mega ACn22/20/4 in an Eco 8... LONG! gstew Electric Heli Talk 0 Jan 17, 2002 06:01 PM
Buying ECO 8, which gear? rgt Electric Heli Talk 1 Sep 27, 2001 09:47 PM
futaba s 133's in an ECO 8? HELP!!!! foss1997 Electric Heli Talk 7 Sep 09, 2001 11:33 AM
