I'm flying my MPX Micro Jet with the following
3 cell 2100mAh Lipo 16/15/7 APC 7x5 E prop Only pulls 9.5 amps static off the charger and the total weight is 15 ounces on the nose. It's not a blistering rocket ship but is pretty darn fast! Goes vertical no problem. It has very gentle stall characteristics. Pull off the power and it just poropuses along, landings are slow and gentle. Flies inverted very well, probably the best of any flying wing i've flown. I fly a bit of slope also and don't see any reason why it woulnd't fly well there either. Todd www.toddsmodels.com |
kdk
The answer to launch problems seems to be a catapault/bungy launcher like the one at:
http://www.geocities.com/stormeflyer...cher.html20052 I'm in the process of designing/building mine at the moment, based loosly on this one. Mine will have a bit of a ramp built in rather than flat like this one. Cheers Numb Thumbs PS I'll let you know how mine goes!
Norway
Joined Mar 2005
Hi all
I finally got to put the MJ together with the Justgofly 300DF motor. Yesterday the weather was good enough to give it a try. The setup was as follows, 3sp Etec 1250Mah, camspeed 4,7x4,7 prop, cc Phoenix 10 and the weight came out about 300 grams. On the maiden I had my doubts because I am used to a 660 grams MJ with Mega 16-15-3 motor and heavy PQ 3sp 2600 Mah packs. I worried for nothing, the plane almost went vertical out of my hand on 3/4 throttle and a it was a delight to fly. I didn`t think handlaunching the MJ could be so easy. With the Justgofly 300DF motor I got about 10 minutes of flying with some throttle management. This motor is very silent and you could only hear the prop working from distance. I am very pleased with this setup and the speed is very good, since I don`t have a radar gun it`s hard to say exactly but 80-90 kmh straight and in a shallow dive it will go a lot faster, but I was to nervous to try low passes on the maiden to check it out. The one thing that surprised me was that it wasn`t ducking in high speed, and i figured out it must be because I mounted the motor with a L bracket and it is seated about 5cm outside the body with lots of air for the prop to work with. All in all a great setup for the MJ. |
Norway
Joined Mar 2005
casioppc
I don`t have a digital camera but I will get one pretty soon so I can take some pics and maybe a little video. I can try to explain the mounting in words, but a picture say a lot more. I prepared the motormount/Lbracket with drilling holes for the motor with the standardmounting that follows as a guide. Then I made 4 slots in the Lbracketfor the tiewrap with a file. About 1cm deep so that the tiewrap would get a good hold. I used the standard mounting holes in the MJ frame and thats it, pretty easy with a good drill and a file. I have thougth of a setup with mounting of the engine outside the body for a long time, because i got those strange sounds from the prop in high speed turns, and later I have heard that it is because that the prop looses air to work with. With the motor/prop about 5cm outside the body, it seems that this problem is gone. I must say I am surprised that this tiny little motor can pack so much power, and because of the weight reduction from my former setup it is much like night and day to fly and not to forget handlaunch. |
| Thread Tools | |
| Sold NIB Walkera MPX Micro Jet Clone w/complete power system | punkindrublik | Aircraft - Electric - Airplanes (FS/W) | 4 | Sep 12, 2005 05:28 AM |
| Sold NIB Walkera MPX Micro Jet Clone w/complete power system | punkindrublik | Aircraft - Electric - Airplanes (FS/W) | 4 | Sep 02, 2005 01:27 PM |
| Sold NIB Walkera MPX Micro Jet Clone w/complete power system | punkindrublik | Aircraft - Electric - Airplanes (FS/W) | 8 | Aug 25, 2005 06:09 AM |
| Rave MPX Micro jet? | IloveFLIGHT! | Electric Plane Talk | 14 | Jul 25, 2005 03:30 AM |
| The Mpx Micro-Jet has arrived! | Jurgen Heilig | Foamies (Kits) | 655 | Jun 05, 2005 03:46 AM |
