Old Jun 05, 2005, 03:45 AM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
The Mpx Micro-Jet has arrived! (Part II)
This is the continuation of "The Mpx Micro-Jet has arrived!", part I, which can be found here:
http://www.rcgroups.com/forums/showthread.php?t=96321
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
Old Jun 05, 2005, 03:48 AM
Got shenpa?
Los Angeles
Joined May 2004
Let's get this Part II thread rolling:
Has anyone tried the Micro Jet as a slope soarer? With the good aerodynamics of the airframe, and a low AUW (no heavy motor or large battery pack to carry) I would think it would perform well. The tough Elapor foam would be icing on the cake.
-Flieslikeabeagle
Old Jun 05, 2005, 03:50 AM
Numb Thumbs is offline
Find More Posts by Numb Thumbs
Does it come in Flouro??
Numb Thumbs's Avatar
Melbourne, Australia
Joined Sep 2004
I haven't yet, but I must give it a try next time the wind is around 20 knots.
Cheers
Numb Thumbs
Numb Thumbs is offline Find More Posts by Numb Thumbs
Old Jun 05, 2005, 03:57 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
-Flieslikeabeagle
I hate to disagree, but the MJ having good aerodynamics? You must be kidding.
The Twin-Jet would be much more suitable for the slope.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 05, 2005, 07:57 AM
I Crash Often
I Crash Often
Guest
n/a Posts
I was just wanting to give the specs from mine.
I have a Himax 2815-2000, PHX-25, TP-2100, HS-55's and a APC 6x4.
It rolls off to the left pretty good but you have time to catch it.
It RIPS too!! I use full rates and when it is rocketing up and I give it full right stick, it spins around 400-500 rpm.
Also it is so cool to come out of a power dive and go over your head at 100mph.
It sounds just like a F1 race car.
One last thing it does is climbs straight up just as fast as it does level.
Well enough blabing, you guys already know how cool this plane is.
Old Jun 05, 2005, 01:17 PM
Got shenpa?
Los Angeles
Joined May 2004
Jurgen, disagreement is the spice of life, so by all means, disagree, especially if I might learn something from it!
What bad aerodynamic characteristic does the MJ have? I know it likes to torque roll left under power, and stall the air over the top of the LE if too much up elevator is applied, but the first problem will go away with no motor torque, and the second should go away as the wing loading of a slope version will be a lot lower??
I have no doubt the Twin-Jet would be more fun (bigger and easier to see, for one), but the MJ was on sale recently for $34... that's a whole lot less $$$ than the Twin-Jet, hence my interest.
-Flieslikeabeagle
Old Jun 05, 2005, 01:44 PM
Joined Sep 2000
-Flieslikeabeagle
You were asking about the suitability of the Micro-Jet as a slope soarer. I am sure if you have a look at some PSS (Power Slope Soarers) models, you will see what it takes for good performance (Hint: high aspect wing ratio, glider wing section, etc. ).
Jürgen
Old Jun 05, 2005, 02:03 PM
iceman3 is offline
Find More Posts by iceman3
Norway
Joined Mar 2005
Hi all
I just wondered if anyone have tried an outrunner on the MJ? I have got a 300df motor that I have planned to use, but I am unsure about how to mount it properly. Anyone got a suggestion? If I can get this to fit, my MJ will weigh only about 250-260 grams, and that will give much easier handling/launching and maybe characteristics in the air, especially when I get 390 grams of thrust and a pitchspeed of about 70mph according to the test tables I have read.
iceman3 is offline Find More Posts by iceman3
Old Jun 05, 2005, 04:21 PM
Got shenpa?
Los Angeles
Joined May 2004
Hmm. I have no doubt that for high performance sloping something along those lines is the way to go, but I see folks around here sloping EPP flying wings routinely, and they have moderate wing aspect ratios and often dubious airfoils. I have also sloped a $5 foam chuck glider converted to 2-channel RC and had lots of fun with it ... it has little penetration, but it soars, and that is enough for me!
Do you not think the MJ would be better than my $5 foam toy glider? Is the delta planform that much draggier than those cheap EPP flying wings?
-Flieslikeabeagle
Old Jun 05, 2005, 04:25 PM
Got shenpa?
Los Angeles
Joined May 2004
iceman - how big a prop does that 300 DF want to swing? If it's bigger than the stock direct-drive inrunner setups, that "torque roll of death on launch" that the MJ is famous for will get worse...
One of my flying buddies is using the Skatty 400XT on an EPP flying wing. I believe it's manufactured by the same company as your 300DF, but is slightly larger and much lower Kv. He mounts it to a short piece of aluminum right-angle bracket, which in turn is glued down to the wing.
I believe the 300 DF is smaller in diameter than the stock Speed 400, so it should fit in the MJ, you just need to make up some sort of mount for it.
-Flieslikeabeagle
Old Jun 05, 2005, 11:11 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
MY microjet weighs 10oz flying. I fly it in the foothills and have brought it in for a landing several times when it just flew right by, power off and soared along the ridge. On one windy day, it took 6 attemps to land to get it in, it just wouldn't come down. But, I changed my airfoil to semi-semmeterical, that may have helped. Butch
Butch777 is offline Find More Posts by Butch777
Old Jun 06, 2005, 12:28 AM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Originally Posted by Butch777
But, I changed my airfoil to semi-symmetrical, that may have helped. Butch
How did you make it semi-symmetrical? Did you shave off or sand down the bottom?
erashby is offline Find More Posts by erashby
Old Jun 06, 2005, 02:29 AM
Got shenpa?
Los Angeles
Joined May 2004
That's just what I was going to ask!
-Flieslikeabeagle
Old Jun 06, 2005, 09:44 AM
iceman3 is offline
Norway
Joined Mar 2005
flieslikeabagl
I have plans on using a 5x4.3 or maybe a camspeed 4.7x4.7. What do you think about that?
Old Jun 06, 2005, 11:16 AM
kdk is offline
kdk
Find More Posts by kdk
kdk
NJ USA
Joined Mar 2005
I flew mine for the first time this morning and it's real hard to hand launch. it seems very underpowered. I'm thinking its because im using 2 cell 1320 TP packs instead of 3 cell packs maybe. I'm using the stock motor and prop too. I had a friend give it a good right handed toss and with me already on the sticks it flew away ok and flew real nice once it got going.
kdk is offline Find More Posts by kdk
Sold NIB Walkera MPX Micro Jet Clone w/complete power system punkindrublik Aircraft - Electric - Airplanes (FS/W) 4 Sep 12, 2005 05:28 AM
Sold NIB Walkera MPX Micro Jet Clone w/complete power system punkindrublik Aircraft - Electric - Airplanes (FS/W) 4 Sep 02, 2005 01:27 PM
Sold NIB Walkera MPX Micro Jet Clone w/complete power system punkindrublik Aircraft - Electric - Airplanes (FS/W) 8 Aug 25, 2005 06:09 AM
Rave MPX Micro jet? IloveFLIGHT! Electric Plane Talk 14 Jul 25, 2005 03:30 AM
The Mpx Micro-Jet has arrived! Jurgen Heilig Foamies (Kits) 655 Jun 05, 2005 03:46 AM
