Old Apr 16, 2002, 10:06 AM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
Jeti 500 vs Kontronic 4001: Can't Make Up My Mind
I need to buy a 40 amp ESC for my LT-25 powered with a Turbo 10 Plus, 6:1 gearbox, 10 cell 2400 Nicads and 10 cell 3000 Nimh, 12X8 or 13X8 prop and 3 HS-81MG and 1 HS-81.
I'm torn between these two ESCs.
The Jeti is slightly heavier, but has an on/off switch. It is more expensive $79 vs $45 for Kontronic.
I don't mind spending more if the Jeti is better. I've read the throttle management with the Kontronics 4001 doesn't appeal to some. Slight movements in the stick cause big changes in power.
If I do spend $80 I guess I would consider the Kontronics Star ESCs.
Should I consider the Great Plane Electrifly C-50?
I need help deciding.
Kelvin
kelvin is offline Find More Posts by kelvin
Old Apr 16, 2002, 10:55 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
I went with the Kontronik, which will be shared between an LT-25 & an E3d.
I chose it partly because I hadn't heard anything negative, but mainly because it appears to have a more robust BEC - 2A, 4 servos to 12 cells. I'll probably only use 8-10 cells, so it fit my need well (and cost less )
Haven't had a chance to use it yet, so that's all I can offer
good luck
Al
scirocco is offline Find More Posts by scirocco
Old Apr 16, 2002, 12:26 PM
oded mazor is offline
Find More Posts by oded mazor
oded mazor's Avatar
Tel Aviv-Yafo Sde Dov, Israel
Joined Apr 1999
I use both the kontronik sun 4001 & the kontronik star 40 bec. both work very well. the star esc can be programed for sailplanes, competition, helicopter... the bec of the star 40 is rated at 1.5A against 2A of the sun 4001, both OK for four servos but I suppose you'll feel more secure with the 2A bec.
both controllers are very light & small, no problem here.
I am not familiar with the Jeti line of esc's.
Oded.
oded mazor is offline Find More Posts by oded mazor
Discussion can't make up my mind, help me out guys! dutchalltheway 3D Flying 8 Nov 08, 2006 11:06 PM
Help! Can't Make Up My Mind!!! jmroscoe Mini Helis 11 Sep 02, 2006 08:30 AM
Discussion You just can't make up stuff this good... lrsudog Life, The Universe, and Politics 35 Aug 17, 2006 04:03 PM
Can't make up my mind... Honey Bee CP2 or Jabo2 or ?? sideburn Micro Helis 2 Dec 06, 2005 07:42 AM
CG on newbuild wing...can't make up my mind.. Franck Flying Wings 10 Aug 09, 2004 10:23 AM
